To simplify the communication interface this unit is designed to emulate a COM port in the host terminal. Because of this feature, this module can work with many systems without having any additional device driver(s).
To extend the scope of this unit, it also comes with an option to switch between "direct mode" and "API mode". In "direct mode" application or host device can directly send characters to the display unit over the emulated serial communication channel.
The "API mode" is intended to provide more extensive features with this unit. All the "API mode" functionalities of this display module are described in the API mode section of this documentation.
This USB external display unit is designed around STM32F103CB MCU. The firmware of this display unit operates with most of the STM32F103 series MCUs, which including STM32F103C8T6 based Blue Pill board.
The dimensions of the PCB is 149.6mm × 44mm and designed as two layer board. To overcome the PCB manufacturing cost, we employ many surface-mounted components into the design.
Dilshan Jayakody
Ai-Thinker
pammyleong
Splendide_Mendax
