Assembled third version of PCB:
- Added current monitor (in theory, should help to autodetect retract size).
- Fixed BOOT pin control, to allow firmware upload via USB.
- Added holes for wire pins to lock plastic supports.
- Debug pins grouped in line.
My friend, second author of our sensor-less speed control for grinder decided to join this project too. He will help with drivers debug (current firmware runs in simulator only). And i will continue with reflow micro table for this time.
Sorry for slow updates - that's specific of OSS development. Instead of doing single project, i prefer to do multiple things in parallel. This allows to share efforts, and each can pick preferable parts where he is most qualified.
Good Day
How is progress going on this project, love the look of this. Very keen to put one together. I have just received the motor.
Wanting to know if you have had any other issues with the board before i order a board.
Thanks, great work.
Hi! Development process is open, you can see every change on github. At current moment indicator/joystick/usb are alive, i will post new log record soon. Motor bridges and current sensor not tested yet.
If you are going to develop - PCB is ok. In other case i'd suggest to wait for sure.
