16-bit CPU built in Logisim
[Redesign]: A 16 bit RISC processor built with a logic simulator
I started this project wanting to better understand how computers work at the logic level. I originally bit off more than I could chew, attempting to implement what I called RISC, which was really more CISC, and a pipeline (the pipeline was the biggest oops). That being said, I am building a simpler design that is still quite functional.
The processor deals with data in 16-bit words. All scalar values are represented in 16 bits.
My instruction word is 16 bits, 4 of which are opcode, the next two define whether or not the operands are immediate values. The final 9 bits are divided into two or three parts. When the operation is unary, the upper 6 bits of the twelve are used as a cache address or immediate value (depending on the opcode), and the other 3 a register address. When the operation is binary, the 9 bits are divided into 3 chunks of 3 bits, the first being operand1, the second operand2, and the third a register address for the result.
Peabody1929 wrote 11/26/2022 at 18:31 • point
I realize this work was done a while ago, but it caught my interest.  Do you have anymore GUI images?  A page with the ALU and registers and a page showing the instruction bit allocation would be great to see.
Thanks!
Richard Milward wrote 06/17/2017 at 20:04 • point
Reed, I think prijazendom is asking for the Logisim .circ file of the design. I'd be interested in it too.
Reed Foster wrote 09/16/2015 at 04:48 • point
Hi @prijazendom,
Because the cpu was built in a graphical user interface, there isn't necessarily any code. Also, since the project isn't actually complete (I've stopped working on it), I don't have any file that you could load into the simulator.
prijazendom wrote 09/15/2015 at 21:18 • point
Probabl stupid question - can I get code somewhere ?
jay_zee102188 wrote 12/27/2014 at 21:39 • point
Logisim, that is the name of the application.
Here is a download link:
http://download.cnet.com/Logisim/3001-20414_4-75305696.html?hasJs=n&hlndr=1&dlm=0
Hacker404 wrote 12/13/2014 at 22:06 • point
What logic simulator are you using?
