LoRa Testing
03/12/2023 at 22:38 • 0 commentsThis project log is sort of announcing a new path for the project. I have decided to further refine this project to the point where it could be considered a product. I am going to use this hackaday page as a place to contain a version that will use solely DIY tools (Arduino, Raspberry Pi, etc.) and a minimal amount of specialty products.
This new direction has resulted in me also deciding to use LoRa as the communication protocol. This is because I want the product to be battery powered and my province does not currently have widely available LTE-M. My first testing of LoRa went ok and I'll detail it more below.
My first attempts were bad because I was using MKRWAN_v2 to update the firmware so that I could use the examples in, https://github.com/sandeepmistry/arduino-LoRa, and it would appears that the firmware MKRWAN_v2 uses is not compatible with that library. Eventually, I used the MKRWAN library to update the firmware and it worked well. The reception between two Arduinos was definitely acceptable.
My current development plan is roughly as follows:
- Communication between Arduino and Raspberry Pi hub
- Curate the Arduino data sensibly so that it is easy for the pi to understand (JSON or some other format?)
- Create an App and/or database to display the data for the farmer.
- Set the Arduino to be battery/solar powered
- Polish this proof of concept before starting to create specialized hardware for the final product.
Now that is a lot simpler of a plan than it will really be, but it gives an idea of what to look forward to.
Putting All pieces together
12/03/2021 at 23:46 • 0 commentsI am just working towards getting some very nice instructions created and creating some instructional videos as well. I also still need to do some investigating on what resistor is best for each distance.
After reviewing my instructional video below I found that I also need to add a few things to the silkscreen and should consider making the board symetric. -
Assembled Second PCB Revision
11/05/2021 at 15:15 • 0 commentsThe second PCB Revision was assembly and it is currently deployed and reporting the temperatures from 4 bins. Some things have been learned and have to improved again.
The two that come to mind are:
- A guide for pull-up resistor values need to be made. The standard 4.7K ohm does not work for the two bins I have further away from the MKR 1010 since the capacitance of the wire grows with length an that capacitor (the wire) has to be charged to transmit a 'high' voltage signal. If the resistor is too large the 'capacitor' will not be charged in time. I will give a more detailed description in some sort of document being that a log or a tutorial, but it will be done.
- Not pertaining to the PCB the distance of the temperature sensors need to be changed to give better/more usable temperature readings of the grain temperature. Either 4 will be placed 4 feet apart or 3 will be placed 5 feet apart, as opposed to 3 placed 7 feet apart.
I think there is some PCB changes that I am forgetting to mention, but I will add them after I review my PCB assembly video.
Completion Nearing
08/27/2021 at 15:30 • 0 commentsFirst I should apologize about the lack of updates, and for my next project I intend to to logs more often.
The first iteration of this project is more or less completed. I am currently waiting for what I hope to be the final PCB design to arrive from Oshpark, and one of the earlier PCBs is connected to 3 bins that each have a cable and are reporting well.
At the moment it is just a monitoring system (no alerts) where current and past temperature data can be viewed on the Arduino cloud. I know when the project started it was going to be 100% alert based, but that changed when I realized how easy it was to launch things on the Arduino cloud.
The current monitoring is going well, except that some of my dad's peas were increasing in temperature drastically for a while, so it would seem that the design works well.
One thing that may have to be changed varying on deployments is the size of the pull-up resistor on the PCB board for the DS18B20 sensors. If too large a resistor is used on the long cables then the sensors will not read, and for one of my dad's bins this was the case for the standard 4.7K ohm resistor. In this case a smaller resistor needs to be used, and I will describe this in the instructions in more detail.
That brings me to the last major work that needs to be done ..... documentation. It is not my favourite part but it is very necessary, and I hope to have very descriptive documents for this project. The instructions on this project page will be how to build the device from scratch, but there will be other documents on the GitHub on how to build each part of the project separately. Also in the GitHub will be a document describing how to simply assemble the grain sensor with finished cables, an Arduino MKR board, and an assembled PCB board.
Of interest to some people might be that I plan to sell kits with all the disassembled components, as well as assembled monitoring cables and assembled PCB boards. The price for the disassembled components will be just above what I paid for them (enough to cover my time of packing it up), so maybe around $550 or so (all together separately the components are $500 or so). A kit with the cables and PCB assembled it will be about $1000 (I calculated this price roughly by paying myself $50 an hour). Both of these kits are to monitor four 5000 bushel bins. A wild card in the price is how spread out your bins are since if the two bins are close together and another two bins are further apart (like my dad's) they way it is set up now a lot more wire will be needed. In a different project log I will give a more updated explanation of pricing.
The price to run the system once it is assembled is the price of an Arduino IoT account, which for up to two devices is free, and the price of communication. When I was using the GSM Arduino the communication costs were about $10 CAD per month using hologram, but it will vary based on how often you want to report the temperature.
For anyone interested in this project please do not hesitate to contact me, or to express interest in purchasing the kits.
Update to the Instructions and Materials
02/28/2021 at 01:19 • 0 commentsI have updated the instructions and the materials list. I know it needs a lot of work, and probably next weekend I'll add more detailed instructions and photos.
Major Updates Needed
02/28/2021 at 00:23 • 0 commentsSo the project has changed significantly since I last updated this page. I'll list the major news below:
- The wooden box is no longer being used and instead, a waterproof junction box is being used. In particular, this one from Amazon is being used: https://www.amazon.ca/gp/product/B075DJQJVY/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1. I made this change since the wooden box was never really a good option, and it fried the Arduino I had inside.
- The project is no using the Arduino cloud to monitor the grain and that code can be seen here: https://github.com/PhysicsUofRAUI/binTempSensor/tree/master/code/ArduinoCloud. I will be adding more code there and eventually will be adding a webhook so that an alert is sent if the grain starts heating
- A different sensor might be used. The DS18B20 is the sensor that might be used instead and that is because it is waterproof, cheaper, and all three can be wired on one wire. Given that it has not been tested yet I may only deploy it in a few of the bins.
- It is up and running and has been for several months now so that is great!
Operating in a bin
09/28/2020 at 17:36 • 0 commentsThe set up is currently collecting data from within a bin filled with canola. It is operating as expected, and I will continue to monitor the temperature variations so that I can best decide when a text alert should be sent out.
For the most part the project is done and working!
Later, could be awhile, I will give a more descriptive update and more in depth instructions of how to build.
Not Working in low temperatures
11/20/2019 at 01:30 • 0 commentsHey.
So I put the current build outside to see how long it would run for in the cold weather.
I did not do good. It sent me the first message but then six hours later (what I had set it to send the temperature at) there was silence.
I think it is a combination of the battery not being charged very much before and that the battery does not like the cold weather.
The next update will be switching gears a bit. I will be constructing a 40 foot usb cable to power the arduino off of (this will replace the solar panel and the battery), and then I will put it and the sensors into operation in an empty bin. This will be the first iteration of tests that will be done on a wired version.
The wired version is being further pursued at this point because it will be cheaper and will operate at the low temperatures better.
A bit off topic, but a contest where a friend and mine were going to present this project has been postponed till March or April.
Cheers,
We are outside wherever now!
11/11/2019 at 02:13 • 0 commentsHey!
I have made an enclosure for the Arduino. Before this enclosure I just left the Arduino in a BBQ to see how long it would work on the solar panel. I also am using a more powerful solar panel. Right now I am mostly testing whether or not the poor battery will freeze in the cold even though it is inside an enclosure (does the Arduino dissipate enough power to keep it warm). My guess is it will freeze.
Cheers,
The project has went Solar!
09/01/2019 at 02:58 • 0 commentsHey!
I have the BinTempSensor inside the BBQ at home right now attached to a solar panel. Attaching a solar panel is an important step because it is needed to keep the project off the grid and able to be used in any bin.
It has been running for almost 3 days now and when it was running only on battery it only lasted two days at most. I have been checking it during the day and it seems to get fully charged (the battery) around noon each day. I would consider it a success.
The next steps are:
- Make an enclosure for the Arduino: made of wood at first, but likely will be a 3D printable enclosure in the end
- Move the temperature sensors off of the breadboard onto wires and eventually those wires will be wrapped around a rope or cable that will be dropped into the bin.
- The final step for this version will be adding a heating mechanism inside the enclosure (I'm from Canada and it gets cold here). Right now it is planned to be a separate circuit that will be switched on and off by the Arduino.
I am hoping to list step by step instructions to build the device to the point it is within the next week, but harvest and the new semester are starting so it may not be for a bit longer. For now the instructable I wrote a while back has the set up with the battery and I'll give a bit of a blurb below of how to extend it.
Instructable: https://www.instructables.com/id/Remote-Temperature-Sensing/
Next steps are:
- Buy the needed supplies: solar panel charging kit, the solar panel, DC jack adapter, and an extra battery is also needed
- Cut the wires off the extra battery (we need them)
- Now solder the wires from the extra battery to the wires from the charging kit
- Plug the battery into the charging port of the solar panel charger
- Take one end of the wires that were soldered together and plug it into the load end of the solar panel charger
- Plug the other end of the soldered wires into the Arduino
- Plug the solar panel into the DC jack of the solar panel charger
Remember that the set up should be placed in a rain proof, but not water proof, enclosure to ensure that water does not mess things up.
Sorry for such a brief description I promise that within a month I will have better instructions (hopefully within a week!), but I thought it be good to give an update of where things are at.
Thanks for reading!
