V-Tech Genius Leader / PreComputer Hacking
Turning a toy into a hardware tinkering platform
Those childhood learning computers can be turned into pretty nice Z80 hacking stations!
This project describes a journey into vintage Z80 based learning computers manufactured by "V-Tech" in the 80s and 90s. Starting with some reverse engineering information, PCBs for interfacing the cartridge port and software development notes.
Currently, there is proof-of-concept support for enabling MIDI in/out, or using it as a terminal for a Raspberry Pi, interfacing a PC using FTDI and the printer port, and even some DOS or CP/M like functionality using a SD card and an Arduino.
The goal of this project is to create a set of hardware and software tools to "hack" the 1000/2000/4000 and 6000 series of VTech 8-bit learning computers ("PreComputer").
Current status:
  • The hardware is well understood: Z80 CPU, HD44780 LCD controller, keyboard matrix, printer port, bank switching, sound, LED, ROM, RAM and cartridge port.
  • The firmware has been reverse engineered to a degree that allows writing custom system ROMs, as well as compiling ROM images that are recognized as cartridges and run by unmodified systems.
  • Software can be compiled using SDCC and emulated using MAME.
  • The printer port can be retrofitted to systems that don't natively have one.
  • Cartridge PCBs have been designed to allow using (E)EPROMs and memory mapped I/O.
  • By using "bit banging", the printer port can be used as a 9600 baud serial port without any hardware modifications.
  • Using a small hardware modification (soldering wires to ChipSelect pins) it is even possible to run a proof-of-concept CP/M system!
  • A dedicated VGLDK (VTech Genius LEADER Development Kit) is currently being developed, to provide a low barrier for developing own programs for the system.
VGL_CPM_0.0.7_WIP_20191202.zip
Minimal CP/M operating system implementation that can actually run ZORK. Work in progress!
Zip Archive - 60.83 kB - 12/03/2019 at 00:18
Download
VTech_SDCC_20190803_headers-includes.zip
All files needed to develop your own cartridge ROMS using the SDCC compiler. Using stock firmware hooks.
Zip Archive - 269.29 kB - 08/03/2019 at 15:44
Download
VTechCartridge_RevD_20190731_KiCAD-Gerber.zip
KiCAD design files for the "BusF###er" cartridge. Rev D. Work in progress!
Zip Archive - 305.44 kB - 08/03/2019 at 15:42
Download
  • 1 × EEPROM 8kB AT28C64B
  • 1 × Arduino UNO
  • Sierra AGI Games on VTech!
    Bernhard "HotKey" Slawik10/14/2024 at 10:46 0 comments
    During the last weeks I tried porting the Sierra Adventure Game Interpreter (AGI) to the VTech platform! At first it seemed impossible, since each displayed screen consists of two bitmaps of 160x168 pixels, which by itself would be more than the 32KB RAM we have on board the GL6006SL/GL7007SL.
    But after some brainstorming, I came up with a two-step approach: First, render one bitmap in full res at 4bit (which fits into 16 KB), then convert it down to 160x100 which fits into the remaining 8KB page. Then, do the same for the other bitmap (and overwrite parts of the 16KB region in the process)
    Well, that worked! 🥰
    …and "Space Quest II" looked so cute on the LCD using a bit of dithering, that I tried to port the rest of the engine as well...
    Thanks to the previous work of ScummVM and GBAGI, I ported module by module to VGLDK, alsways keeping a close watch on RAM and ROM usage.
    But finally, after some twiddling (splitting the 64KB engine into two 32KB segments and bank-switching back and forth), it was possible to have the engine residing in lower system ROM, while the game files (~700KB) are put into a big external cartridge ROM.
    The result: Hello, VAGI!
    Okay, I must admit, there are a lot of shortcuts and little bugs remaining, and the performance is really bad at times. But you CAN indeed play SQ1 / SQ2 / KQ1 and KQ2 for a few minutes and it's fun! There's still a little bug that doesn't let you enter the castle in "King's Quest I", but that seems fixable.
    You can find the code in the VGLDK Github repo inside the "examples/agi" directory, but I might fork a separate project.
  • CP/M encore!
    Bernhard "HotKey" Slawik08/24/2023 at 16:49 2 comments
    During the summer break I have completely re-written CP/M for VTech Genius Leader computers!
    The procedure is now simpler (better documentation, better Python based build system, better emulation options) and compatibility is much improved (ZORK1-3 and BBCBASIC work perfectly)
    So check it out at my VGLDK Github at https://github.com/hotkeymuc/vgldk/tree/master/examples/cpm
    A great next step now would be to create a combined ROM+RAM cartridge for a low entry barrier for any enthusiastic VTech fan. Or... maybe even a Tindie campaign for a complete self-contained "VTech CP/M Cartridge"...? What do you think?
    CP/M 2013-08-23 running on GL4000
    CP/M running on a Genius Leader 4000 (MAME emulation)
  • Factoid: Guess where ZiLOG is located...
    Bernhard "HotKey" Slawik10/08/2020 at 17:43 0 comments
    While skimming through the local business register I stumbled upon the entry "ZiLOG International Ltd."...
    ZiLOG —the Californian company that created the Z80 processor used in all the VTechs— is now part of Littelfuse and IXYS which in turn is c/o AVNET (big electronics distributor) which is literally around the corner of my house!
    But so far I seem to be the only Z80 nerd around here (that I know of).
    🌈 *The more you know!* 🌠
  • But does it run Doom?
    Bernhard "HotKey" Slawik09/30/2020 at 22:43 0 comments
    well... sort of... ;-)
    Crappy Raycaster Demo
    Crappy Raycaster Demo running on an emulated GL6000SL
    ...and if you don't have a graphical LCD:
    Raycaster on Genius Leader 4000
    Raycaster in 20x4 text mode
    There is also no game logic whatsoever, tho. Just a proof of concept.
    Check it out at https://github.com/hotkeymuc/vgldk/tree/master/examples/raycast
  • ParallelBuddy: DIY periphery add-on for everyone!
    Bernhard "HotKey" Slawik09/06/2020 at 21:31 3 comments
    I've been using the past months to get a new focus for the project.
    Hardware hacking is fine and dandy, but the practical use for the "average Joe/Jane" is quite limited. After all, manufacturing PCBs, sourcing 74-series logic and debugging everything is not for the faint of heart.
    So I came up with a new goal: Lowering the entry bar for anyone trying to run own code on an old V-Tech computer. That means: allowing unmodified C programs to just work on the VTech without hassle. Just "make" to compile, "make emu" to simulate and "make burn" to burn a finished EEPROM.
    There is no easy way of sticking your own EEPROM into the computer, yet. For now you have to "sacrifice" a working cartridge and properly attach your own EEPROM to it. But it's very doable.
    EEPROM Adaptor
    Custom EEPROM attached to a stock ROM cartridge using a piece of proto board and a ZIF socket
    After having done this, you should be able to simply compile, test, burn and run your code on a 2000, 4000 or 6000 series V-Tech computer. This is already working fine using the latest version of the VGLDK.
    So far, so good. But then what?
    It would be soooo nice to have just a little bit more periphery to play with, like "real files", network, LEDs etc.
    Following the same direction as my older "BusFicker" cartridge, I thought of the simplest way to extend the periphery by using just an Arduino. This time, instead of doctoring around with the Z80 bus, I re-visited my "Software Serial" code, completely re-wrote it in C and optimized the crap out of it. Not only is the new "Software UART" smaller than its assembly predecessor (C optimization ftw), it can even handle serial speeds of up to 19200 baud now!
    Throw in an Arduino, an SD card and some wires and —voilá— say hello to the Parallel Buddy!
    Parallel Buddy
    Just connect 3 wires from the printer port to an Arduino for a world of endless possibilities!
    What can it do? Well, I'm glad you asked☺In theory it can do whatever an Arduino can do. But to keep things neat and extendable, I opted to create the concept of file systems and mounts inside the VGLDK. So with the usual "fopen()" syntax, you can now access files baked into your ROM as well as accessing any remote file system mounted on the ParallelBuddy Arduino (the Arduino sketch actually uses the same source code for its own local file system).
    So: Connect the Arduino, fire up the "monitor" ROM, "cd" into the ParallelBuddy mount, and from there into the SD card or anything else you decide to put in. Your monitor can simply "cat" or "run" files directly from there! "fopen()" doesn't know the difference! ☺
    Browsing file systems
    Running a program from an SD card connected to an Arduino. There are actually 4 different file system drivers in action to allow this.
    I also added a rudimentary Ethernet file system through the use of a standard Ethernet shield. Just fopen("/pb/eth/google.com") and you're golden!
    Be warned that the ParallelBuddy code is quite big, so you'll have to disable some other functionality to make the monitor program fit a standard 8KB / 64 Kb EEPROM. The makefile will warn you if you run out of space.
    Oh, uploading files from a computer to the monitor still works as before: After power-up the ParallelBuddy Arduino sketch will stay in "bootloader mode" for some seconds, simply passing all data between the VTech and your computer, before switching over to "ParallelBuddy mode". So you can also use the Arduino as a USB-serial converter.
    So: Head over to the VGLDK GitHub and give it a try! You'll find the Arduino sketch "VTechParallelBuddy.zip" inside the "tools" folder.
    Cheeeeeers!
  • Prestige!
    Bernhard "HotKey" Slawik05/16/2020 at 21:35 1 comment
    The other day, I decided to do something "completely different" for a change. So I went to my wall of VTech Genius Notebooks and grabbed a random one from the pile that had the same cartridge port as the 4000, but a larger screen.
    My pick: the Genius Leader 6000SL aka. Genius PreComputer Prestige.
    This time around I wanted to cheat a bit, since I didn't want to spend another 2 years analyzing it (as I did with the 1000/2000/4000 series). Instead of building a debugging cartridge and finding all the memory and port mappings myself, I just searched for some emulation source. And I found a driver in the trusty old MAME repository (src/mame/drivers/prestige.cpp). It is missing some functions (printer port, sound), but the basic stuff is there.
    First thing that sparked my interest: The machine seemed to use a DMA based LCD (240x100, graphical), so there is no need for weird LCD initialization code and software frame buffer stuff. It's as simple as poking bitmap data into memory at 0xE000-0xEBB8 and it gets drawn on the screen automagically!
    The keyboard is also pretty straight forward (matrix at ports 0x40, 0x41, 0x42) and didn't take much effort to get working. And even the mouse (yes, it has an external mouse!) is directly mapped to ports 0x04 and 0x05 for the X and Y positions. Nice!
    I must say, I am quite impressed about how much easier it is to work with the 6000 compared to the 1000/2000 and 4000 series. It took just one day to write my first "Hello World" from scratch (including custom font rendering). I would call that an "instant gratification" :-)
    The bank switching / memory mapping in the Prestige is also quite nice: It allows for the cartridge to be mapped to lower memory at address 0x0000. This means that a CP/M style system could run on that machine without any hardware modifications (i.e. no "Chip Select hack" needed)!
    So maybe I'll just give it a try and create a Plug & Play CP/M cartridge for that machine!
    Stay healthy!
    Update: I have updated the VGLDK Github repository to allow compilation against the new "gl6000sl" target. Cheers!
  • VGLDK
    Bernhard "HotKey" Slawik01/24/2020 at 22:46 0 comments
    Just a little status update:
    With CP/M working as a proof-of-concept, an important personal milestone has been reached.
    While doing so, a lot of new interesting ideas came up. That's why I am now spending a little time incorporating all the development so far into a VTech Genius LEADER Development Kit - the VGLDK.
    Even though I would very much appreciate it, if the VGL support for the Z88DK would improve, I feel like it is a little bit too over-engineered and complicated for the rather "simple things" I try to accomplish. Those being: Enabling everyone to develop software for the system quickly and hassle free.
    So I created a Github repo at https://github.com/hotkeymuc/vgldk and started filling it with some initial content. My current focus lies on smooth portability between the 1000, 2000 and 4000 series. (Series 3000, 5000, 6000, 7000 and 8000 may follow eventually.) Additionally, the build process must allow compiling programs for use in a cartridge ROM, as system replacement ROMs, and also for runtime-linking (e.g. when using CP/M or some sort of DOS). I might also migrate the VGL CP/M project right into the VGLDK.
  • "You are standing in an open field..."
    Bernhard "HotKey" Slawik12/02/2019 at 22:22 3 comments
    I had the feeling that I was going around in circles: Adjusting some assembly code, compiling, burning an EEPROM, inserting it, bootstrapping the RAM cartridge for CP/M, switching from ROM to RAM, booting CP/M, loading a .COM-file over serial, running it, ... and crashing.
    This became very tiresome quickly, as you can imagine.
    "Emulation to the rescue!", I thought. So I took a deep dive into the MAME source code and patched the PC2000 emulator: I changed the memory banks to be write enabled to simulate the RAM-switching hardware mod needed for running CP/M. I also added a debug port that allows sending and receiving data to/from MAME via stdin/stdout.
    That worked like a breeze. Now it's only one click to compile and pack the CP/M ROM, fire up MAME, load CP/M and open a data channel between the emulated CP/M machine and a python "host" script. This really speeds up the process of loading and altering code for debugging. I also added a TRAP function to BDOS, which allows stopping the program flow at a desired address, dumping registers+stack, and continuing with the execution.
    Having these tools at hand, I quickly identified a bank-switching bug and an error when reading records from files.
    I crossed my fingers, uploaded "ZORK1" to the emulated CP/M and gave it a try...
    ...it opened the "ZORK1.DAT" file...
    ...read some records...
    ...then some more...
    ...and even more...
    ...and more...
    ...until finally:
    ZORK - on a VTech Genius Leader 4000 running CP/M inside MAME
    ZORK - On a VTech Genius Leader 4000 running CP/M inside MAME
    Yeeeeha! I've never felt better, standing in an open field on a cold night like this :-D
    Don't get too excited, yet, because I immediately ran into the next 2-3 bugs with the keyboard handler. So it is not really playable at the moment. But this has been a really big milestone.
    Update: It's usable!
    A little fix in memory layout here, a change in keyboard layout there and...
    ZORK on a toy computer, anyone?
    Christmas may come! :-)
  • >RUN
    Bernhard "HotKey" Slawik11/15/2019 at 12:07 3 comments
    Yesterday night I pulled out my oscilloscope and tweaked the timings used by the software serial implementation. I noticed some bits getting lost and tracked it down to the "edge delay" used to sync up with the start bit.
    Now data transmission is much more reliable than before. Nonetheless, it is recommended to employ a protocol with checksums and re-transmit to ensure binary proof data transmission.
    So, what should we do with it?
    Maybe... allow the CP/M BDOS to load files via serial from a computer?
    >python bdos_companion.py /dev/ttyUSB0 ZORK1.COM
    Ready.
    ...and then on the Genius Leader 4000:
    32K VGL CP/M 0.0.4
    2019-11-14 by HotKey
    >SERIALLOAD
    LOADING...
    OK
    >RUN
    ZORK1 on VGL CP/M
    ZORK starts up! I think we need to implement proper virtual disk access next!
    Oooooooohhhhh!
    I think we're on-track to playing ZORK during the holidays! :-)
  • CP/M on V-Tech Genius Leader 4000: It... works!!!
    Bernhard "HotKey" Slawik11/05/2019 at 15:26 0 comments
    This is worth another project log...
    Since I got "boot from RAM" working yesterday, I eagerly started implementing the basic BIOS/BDOS functions of CP/M 2.2. No disk access, yet, but just the standard console input/output and housekeeping functions.
    Fortunately, CP/M is well documented and there aren't actually that many functions that need to be implemented for a basic system.
    So, I fixed my broken LCD DDRAM mapping and optimized the keyboard handler a little and added the most important CP/M BDOS functions.
    Then I took a small .COM file (SYSGEN), placed it into RAM and jumped to it...
    First CP/M program running on a Genius Leader 4000
    Houston, we have a code execution!
    I was greeted by the program banner! It works!
    That was really unexpectedly simple! The next 1-2 weeks will be used to implement a simple file system and all the necessary open/close/read/write functions, so we all can play ZORK before the year is over! :-)
    Stay tuned!
View all 17 project logs
Chris Belcher wrote 01/18/2025 at 16:24 point
Hey - I just posted my PCB to recreate the 32K Super Memory Expander for the VTech Precomputer 2000 / Genius Leader 2000. If you just want to have some place to store/load BASIC programs check it out.
https://www.pcbway.com/project/shareproject/32K_Super_Memory_Expander_for_the_VTech_Precomputer_2000_Genius_Leader_2000_314819d6.html
Bernhard "HotKey" Slawik wrote 01/20/2025 at 17:25 point
This is great! I am going to need a few of these for my next project: A Sierra "Space Quest" VTech cartridge. Code runs in emulation, but it requires all the RAM it can get. I need to combine RAM and ROM on one cart to achieve this, but that should be possible with some 74xxx logic magic ;-)
mutantcamel1979 wrote 10/03/2024 at 16:47 point
I own various Vtech computers and also own a 32K Memory Expansion Cartridge and PC Link. Both allow you to save and load Basic Programs/Word Processing files. Sadly the 32K Cartridge doesn't allow you to add physical memory to the computer, just to save files sadly. I am therefore restricted to the actual RAM of the individual VTech Computer, which seems to vary slightly, but does not seem to exceed 4K. I hope one day a ROM/RAM Cartridge is produced in order to program bigger Basic Programs. I would love to get my text adventure game working. Fingers crossed something like this gets released one day!
Bernhard "HotKey" Slawik wrote 01/20/2025 at 17:23 point
Good news: I actually got the Sierra AGI engine working! :-D
You *can* use the 32K memory expansion in your code. Depending on your model, there are ports you can write to (bankswitch) to map the cartridge to any of the 4 16KB memory regions (0x0000 / 0x4000 / 0x8000 / 0xC000). Check out my Github (example/agi) for some code or DM me for details.
You can also make simple changes to the MAME emulation core for pc1000/gl (just make all RAM writable) to test your adventure in emulation without requiring hardware.
J.A. Rubio wrote 08/30/2024 at 07:25 point
Hello! I just wonder if there is any way of dumping BIOSes from Navigator or Genius 5000 (I still have to check... this is a Spanish model and probably has another name). Since they are the Spanish version and they seem not to be dumped.
Val Polyakh wrote 02/20/2021 at 06:36 point
I've just got a PreComputer Prestige (in addition to my PreComputer 1000)
Wanted to do a proper teardown but it's "child-proofed" by gluing many components to the case so I couldn't even see what's on the board. Do you have any information on CPU/RAM/ROM parameters for PreComputer Prestige
It looks like it's significantly more advanced than 1000 (graphical display, voice support, many applications, more advanced BASIC, printer port), I wonder what hardware they used and how to make a "jailbreak" cartridge that would allow to use it as a more general purpose computer with access to memory, etc.
Bernhard "HotKey" Slawik wrote 03/03/2021 at 17:01 point
Hi Val! The Prestige looks like a "Genius Leader 6000SL" for which I actually do have support for in the VGL! No sound, yet, but the LCD works!
See: https://github.com/hotkeymuc/vgldk/tree/master/include/arch/gl6000sl
nemoskull wrote 07/11/2020 at 08:21 point
working on a precomputer 1000. link to what i got. working on a hardware schematic first.
https://www.reddit.com/r/Z80/comments/hnbrux/precomputer_1000_reverse_engineering/
Bernhard "HotKey" Slawik wrote 09/08/2020 at 19:12 point
Nice work! Have a look at my thingiverse and the "BusFicker" KiCad-Project. The PinOut of the PreComputer 1000 and GL 2000 are pretty similar. But I am still not 100% sure about the outer most pins, as they seem to do completely different things between the models, although some cartridges work on all of them... Quite weird...
Have you found a Pin that corresponds to the Z80 "port access" pin? (My guess is that they mask it with their custom PCB somehow)
pulppure wrote 11/23/2019 at 10:00 point
Would something in the idea of the chipwhisperer be of any help to understand the innards of our little machines ? It is pretty expensive for our aims, so maybe we could build something cheap with arduino or raspi... https://hackaday.io/project/956-chipwhisperer-security-research Also I will try to see what peek and poke commands do in the basic. (edit : they are not available :( )
Evan Allen wrote 11/25/2019 at 15:44 point
I'm working on restoring peek and poke commands to the roms, if you can get your french rom out and dump it that would be the easy way, but I think I can manage a cartridge that you can plug in and it will either dump the internal rom to a serial port or dump it to an SD card.
pulppure wrote 11/23/2019 at 09:41 point
Hello, yesterday I dug out my french Vtech Genius 4000. I bought it at french salvation army back in 2011 for two euros while picking up some toys for a circuit bending workshop. Later decided that it would not bend properly and was put into storage after the workshop, First, I managed to make it run from nimh batteries, but found some activity buttons did not respond. So I opened it and had a look at the motherboard. I found some insulating cardboard which might be albestos (pretty sad for a kid toys, but if you don't tear it, it doesn't release that much particules) between the battery holder and the MB, so I will replace that, there are also some underneath. There is a little battery leakage, that hopefully did not touch the MB, and I will have to resolder the corroded battery holder. After taking it apart, I did not find the z80 inside, just a Winbond 8ko memory, a Vtech chip, and a bulb chip stuck onto a larger chip like pcb soldered in the middle of  the MB (maybe the z80). Everything is neatly stuck with hot glue the old chinese way, so it's not easy to take pictures (maybe later). Anyway it looks a lot like yours. After putting all back together it no longer powered from batteries, so I dug out a wallwart. Then it still refused to power on, so I had to add some pencil graphite to the traces of the keyboard activity menbrane, that has the power on button. Then it worked, and I also recovered the missing activity buttons on the way. I've tried some basic programming. I've found that it's not compatible with some of the examples I've found on basic learning websites. Anyways I'm amazed at all the progress you've made so far. I'm not much of a hardware tinkerer myself, but I will look forward to try a cartridge, and I will soon provide pictures of  my model's MB.
Bernhard "HotKey" Slawik wrote 10/22/2019 at 15:09 point
@Evan Allen CollapseOS looks EXACTLY like the thing we were looking for! It seems we can save A LOT of work by "just" trying to get CollapseOS to work on the GL! Thank you for the hint! The community already paid off! :-D
Evan Allen wrote 10/23/2019 at 02:47 point
I wonder about having a section of memory that's re-writable and bootable, it would be in the spirit of Collapse OS to have it assemble the operating system and then just boot that.  Maybe a flash rom that doesn't need funky programming voltages.
Bernhard "HotKey" Slawik wrote 10/28/2019 at 19:16 point
Yes, that would be great. Wither using FRAM or by somehow setting the Z80's "WAIT" / "MEMREQ" / "BUSREQ" pins to slow it down far enough that an Arduino can inject the boot code....? Hmmmm.... Help is greatly appreciated!
Bernhard "HotKey" Slawik wrote 10/22/2019 at 14:53 point
@Evan Allen yes, the missing DIP20 is a "DM 74LS244N". @olsen also wanted to give the retro-fit a try! FYI: The port is not a fully working parallel port. It only offers 8-bit output and 1-bit input. Enough for printing and for a "bit banged" serial connection (which I have successfully working at 9600 baud)
Evan Allen wrote 10/23/2019 at 02:40 point
when I'm back from my business trip I'll want to know values of passives I'm missing.  Here's my board's top side, can you help me fill in the blanks? https://imgur.com/a/Smgf1ar
I'm planning on modifying the power section so I can switch between alkaline batteries and NiMHs and the barrel jack on the back either switching over power or charging the rechargables, also making sure the rom is in MAME
Bernhard "HotKey" Slawik wrote 10/28/2019 at 19:17 point
Thanx for the photo! I have created a "project log" containing a list of the missing components. I hope I haven't forgotten any - let me know if so!
Evan Allen wrote 10/20/2019 at 15:22 point
is the dip20 a 74ls244? My american equivalent is missing that, the parallel port, and some passives/transistors in that circuit and I want to restore the functionality
Evan Allen wrote 10/16/2019 at 15:34 point
I have a precomputer power pad on the way, I think it's the same model you're working with, just available in the United States.  I want to see this thing run CollapseOS
Tom Nardi wrote 08/05/2019 at 02:07 point
Very interesting project. I had several computers like this when I was young, though none nice enough to have the mouse or printer (not for lack of me asking every Christmas, though). Never even occurred to me that they could potentially be put to use.
