Eyelid Track.step3D printed parts for the eyelids to open and close. The eyelid is attached to the small slider, and the track is glued into the inside of the outer eye part.step - 70.99 kB - 04/25/2020 at 17:48 |
Wheatly_Sound_Slave.inoThis code takes input from the Master Arduino and gives data to the adafruit soundboard.- 1.29 kB - 06/14/2017 at 12:24 |
Wheatly_Motor_Slave.inoThis code takes input from the Master Arduino and writes data to the motors. This also reads data from the potentiometer.- 4.20 kB - 06/14/2017 at 12:26 |
Wheatly_Master_Ardunio.inoThis code takes input from the remote receiver and sends data to the other two arduinos over I2C.- 19.02 kB - 02/25/2017 at 13:48 |
completed frame.123dxA design of the frame. The mechanical workings are not complete.123dx - 2.31 MB - 11/23/2016 at 20:16 |
TAD design.123dxAutodesk 123D design of the track attachment device. STL downloads are available on thiniverse: http://www.thingiverse.com/thing:1913433123dx - 921.27 kB - 11/23/2016 at 20:15 |
