v3 was indeed final...
12/01/2020 at 19:59 • 0 comments -
v3: Final?
08/09/2019 at 05:08 • 0 comments- Switched from 10-teat rectangular to 5-teat hex format
- Redesigned hinges with a rectangular moving part to restrict motion
- Designed the movement in python, by plotting the union of the rectamgles on the path
- Goal: upper part can only enter from an angle it cannot be in when the lower part is installed (locked in)
- Goal: goes a little over 90 degrees
- After some attempts, had the following path as a union of a straight movement and a rotation around a point below the rectangle in the horizontal position
- Redesigned lock to stay put on the lower side
v2: Laser-cut hinges and lock, better design
08/09/2019 at 04:11 • 0 commentsGiven the feedback, redesigned the hinges and lock, and also made the outer frame shape nicer, without trying for as much symmetry.
Feedback:
- Works much better
- This version was in use for about a month
- The asymmetric lock placement is not nice
- The lock and hinges are not yet good enough
- Hinge was just a hole
v1: Laser cut POM + stainless steel filler rod hinge
08/09/2019 at 03:35 • 0 commentsFirst truly functional version.
Laser cut from food-safe 3mm POM plastic, filler rod wrapped around the extensions for hinge and locks.
Feedback:
- It does work
- The 3mm x 3mm POM is definitely robust enough
- The hinge / lock system is not very good yet
- Squishes the teats, water doesn't get to wash between the holder and the teat
- It is a bit large
v0: Stainless steel TIG filler
08/09/2019 at 03:33 • 0 commentsv0.
Trying to make out of 2.4mm stainless TIG welding filler rod. With bending was able to hold some teats but the results were not spectacular and the construction was not up to scratch. Also tried welding but the wire was a bit too difficult a target for my current welding skills
