The LTC4162 ICs are attractive as they provide the following benefits:
- Wide Charging Input Voltage Range: 4.5V to 35V
- High Efficiency Synchronous Operation>16-Bit Digital Telemetry System Monitors VBAT, IBAT, RBAT, TBAT, TDIE, VIN, IIN, VOUT
- Charges multiple cell batteries
- Input Undervoltage Charge Current Limit Loop>Input MPPT for Solar Panel Inputs
- Input Current Limit Prioritizes System Load Output>Low Loss PowerPath™
- Instant-On Operation with Discharged or Missing Battery
- JEITA Temperature Controlled Charging
Source [ https://www.analog.com/en/products/ltc4162-f.html.html#product-overview ]
I am currently sourcing parts from Mouser and building the sample circuit in KiCad
kaustubh
akbarhash
Anuradha Gunawardhana
ROFLhoff
Hi @Kaustubh in this project, we might end up using the LTC4162 as well
https://github.com/SensorsIot/SuperPower
