Prototyping starts tonight
08/21/2019 at 21:36 • 0 commentsAnd, my prototyping order arrived! I'll use these to test the Arduino Code / CircuitPython and the whole idea. Then I'll design a circuit and PCB using just the necessary components.
These are basically the parts used in the AdaFruit Trinket Sound-Reactive LED Color Organ and FFT: Fun with Fourier Transforms projects.
Prototype parts are ordered
08/21/2019 at 20:47 • 0 commentsI've ordered the parts to build AdaFruit's Tone Detection project. It's just two parts plus LEDs, and it can detect the Close Encounters tones. I'm going to use this as a jumping off point for coding an instrument tuner.
I also ordered a NeoPixel Ring, which will open up great possibilities for showing when a played note is out of tune, and how far off it is. E.g., a rotating light pattern that can slow down as the note gets closer to A-440.
