Hackaday.io Hackaday.io
Sign up Log in
xzwXzw
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2.2k views
11 comments
1.9k followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 11
2.2k
11
1.9k
34
Team (1)
  • xzwXzw
Join this project's team
completed project
MISC
completed prDRONoject drone Motor ROBOT 3dprint
This project is submitted for
  • Hackaday.com Tip Line
  • Connected World Contest
This project was created on 09/10/2019 and last updated 24 天前.
Description
Details
Log In/Sign up to comment
Sign up with Github
OR
Jay Young wrote 07/08/2020 at 14:01 • point
The website is down, and the 3DP files don't seem to be available.  I think this would make a fantastic bow thruster for smaller boats, or an excellent option for electric kayak.  Are the files still available?
dima-ch wrote 12/16/2019 at 15:46 • point
Контактируют ли в данной конструкции моторы с водой?
Xzw wrote 06/26/2020 at 11:13 • point
Да, контактируют, но установлены моторы с заводской водозащитой.
SmallDevices wrote 09/23/2019 at 16:00 • point
What's the targeted depth? I am very interested in 150m operation depth with at least 30m margin (max 180m) or 100m operation depth with at least 20m margin (max 120m).
Xzw wrote 09/23/2019 at 17:06 • point
I tested it's motor only at a depth of 50 meters.
7kadzumi7 wrote 09/17/2019 at 15:15 • point
that if you connect several motors to a 12-watt battery, print the case on the printer. Make it the equivalent of a water scooter
Xzw wrote 09/23/2019 at 17:08 • point
Yes it is possible. I can design models with more thrust.
Dan Maloney wrote 09/10/2019 at 15:51 • point
Moves a lot of water for such a small engine. I'm impressed!
Xzw wrote 09/10/2019 at 17:29 • point
Tom Nardi wrote 09/10/2019 at 04:44 • point
Certainly looks very cool. Are there any numbers on thrust? Is the performance actually improved by the "jet" design versus just putting a prop on the bare motor?
Xzw wrote 09/10/2019 at 17:28 • point
Thanks :) Thrust - 1.3 kg. It's design allows to better control under difficult conditions  -  wind, waves, flow on the river.
A nicer version of my AT90S1200 binary clock
Project Owner Contributor
Binary clock rebuild
danielDaniel
Decal Evolved-Composite Application Layer for robotics
DECAL
morningstarMorning.Star
A first attempt at a garden fountain
Garden Fountain
bharbourBharbour
Portable groove box that can be thrown in backpack, set up quickly and produce music on the fly.
Sample.Loop.Repeat
geraGera
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "-", please tell us the reason.
Send message
Remove Member
