Hackaday.io Hackaday.io
Sign up Log in
xzwXzw
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2.3k views
11 comments
1.9k followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 11
2.3k
11
1.9k
34
Team (1)
  • xzwXzw
Join this project's team
completed project
MISC
completed prDRONoject drone Motor ROBOT 3dprint
This project is submitted for
  • Hackaday.com Tip Line
  • Connected World Contest
This project was created on 09/10/2019 and last updated 8 months ago.
Description
Details
Log In/Sign up to comment
Sign up with Github
OR
Jay Young wrote 07/08/2020 at 14:01 • point
The website is down, and the 3DP files don't seem to be available.  I think this would make a fantastic bow thruster for smaller boats, or an excellent option for electric kayak.  Are the files still available?
dima-ch wrote 12/16/2019 at 15:46 • point
Контактируют ли в данной конструкции моторы с водой?
Xzw wrote 06/26/2020 at 11:13 • point
Да, контактируют, но установлены моторы с заводской водозащитой.
SmallDevices wrote 09/23/2019 at 16:00 • point
What's the targeted depth? I am very interested in 150m operation depth with at least 30m margin (max 180m) or 100m operation depth with at least 20m margin (max 120m).
Xzw wrote 09/23/2019 at 17:06 • point
I tested it's motor only at a depth of 50 meters.
7kadzumi7 wrote 09/17/2019 at 15:15 • point
that if you connect several motors to a 12-watt battery, print the case on the printer. Make it the equivalent of a water scooter
Xzw wrote 09/23/2019 at 17:08 • point
Yes it is possible. I can design models with more thrust.
Dan Maloney wrote 09/10/2019 at 15:51 • point
Moves a lot of water for such a small engine. I'm impressed!
Xzw wrote 09/10/2019 at 17:29 • point
Tom Nardi wrote 09/10/2019 at 04:44 • point
Certainly looks very cool. Are there any numbers on thrust? Is the performance actually improved by the "jet" design versus just putting a prop on the bare motor?
Xzw wrote 09/10/2019 at 17:28 • point
Thanks :) Thrust - 1.3 kg. It's design allows to better control under difficult conditions  -  wind, waves, flow on the river.
IKTA is a mobile game that gamifies the process of quitting nicotine.
Project Owner Contributor
IKTA
stevenkennedysteven.kennedy
The 2017 Hackaday Prize
Vibhear, as assistive hearing device, ensures safeness for people with hearing loss, when hearing aid is not used or is not working.
Vibhear
srdjan-pavlovicSrdjan Pavlovic
Replica of Broken Narsil sword from LOTR, equipped with electronics.
Narsil - LOTR
arnov-sharmaArnov Sharma
Lets make the Pi truly independent. This Hat is design to take the Pi of the grid.
Pi0W Solar Hat
mr-spriggsMr. Spriggs
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "-", please tell us the reason.
Send message
Remove Member
