Here is the Open Source laser cutter
Hardware:
The entire machine is moved by low cost servo motors with a close-loop encoder feedback. mxl timing belt and printed sprockets are used for movement.
The machines have a cutting size of 2'x3' for the smaller machine and 4'x4' for the larger machine. We are currently working on additional upgrade features such as adjustable Z for parts bending, and upgraded optics that don't require lens focusing.
The entire laser tube and optics are encased in the machine.The small laser is capable of housing up to a 80w CO2 laser the large laser can house up to an 120w CO2 laser. An additional feature we are currently working on is laser detection. This will disable the laser if the beam is not contacting the cutting area.
Once the machine has been assembled and tested all parts will be available open source under a creative commons license.
Software/Communications:
This project uses the same electronics hardware and software platform as the Servostock, Flower Router and open face mill.
http://hackaday.io/project/962-Servo-Stock
http://hackaday.io/project/1665-Open-Source-Router%2FLaser%2FLathe-(Flower-Router)
http://hackaday.io/project/1698-Open-Face-Router
The system we developed over 4 years and have now applied to the flower router is an extensible, namespaced communication protocol. Think of it like a domain specific language over a generic serialized communication link. The protocol allows devices to report to the computer their capabilities, then the computer can generate packets based on that report. We have complete implementations in Java and C99. Clojure, Jython, Jruby and Matlab have been tested working with this library. There is a partial implementation in pure Ruby as well.
Electronics:
We have redesigned the entire control system from the ground up. From the get-go we started using magnet orientation encoders plus low cost continuous servos. The motherboard is a Pic32mx440f128h with each axis receiving a servo pulse and an SPI channel for the encoder. The motherboard uses a 7x2 ribbon cable to connect to each axis. Each axis has a small board with the encoder chip and the connector for the servo.
Firmware:
The control loop runs at 20 ms for the servo pulse calculation, interpolation and forward/inverse kinematics. The device identifies itself as having the PID control namespace, the kinematics namespace, and the router configuration namespace. Through the communication layer you can change kinematics models, change PID constants and store all the configurations. The configurations are stored non-volatile in Flash and travel with the printer to be read at runtime. NO MORE CONFIG FILES!!
The firmware also has auto-config system. The servo dead band is measured at boot time. The end stops are measured using the encoder with no limit switches.
Bootloader:
a (new to you guys) bootloader that i developed for the DyIO controller. It is a serial bootloader that uses the same communication protocol as the printer or any other device for that matter. The bootloading interface is just another namespace that any device can implement. The toolchain for generating bootloader file is all written in Java and attaches to any Makefile build chain.
sporkius
Josh Campbell
MaximumMark
AltMarcxs
