Gantry and testing
09/30/2014 at 01:43 • 0 commentsThe rails, gantry, and timing belt have been installed on the laser machine. Thanks to a volunteer (Shawn) we are currently developing a more advanced optics system that allows increased precision and deeper cuts. We are testing CNC functionality using mock Gcode. The small laser cutter also joined our booth at the NYC Makerfaire.
Partially assembled gantry.
X Axis motor with timing gear and ribbon cable for hall effect encoder.
X and Y axis Closeup.
X and Y axis assembled. Ready for timing Belt
Ready for a trip to NYC Makerfaire.
The Router (Bottom right) at the NYC Makerfaire.
Cabinet Assembly
07/14/2014 at 00:41 • 0 commentsThe Cabinet has begun being assembled. Once completed we will begin assembling the electronics and gantry. Below is a picture of the large laser cabinet. I will be adding pictures of the small cabinet shortly.
Finally Cut
06/29/2014 at 21:29 • 0 commentsAll the parts for the laser machine are finally cut and ready for assembly. We are currently printing all the motor and pulley mounts. We are hoping to have this machine up and cutting in the next 2-4 weeks.
sporkius
