Servo Mount Plate.svg
The mounting shield that holds that servo motor and slides down the slot in the faceplate fixture. 3.516 x 1.95 in (To be laser cut through 1/8" acrylic. File units in inches.)
svg+xml -
1.07 kB -
09/22/2019 at 03:50
Preview
Servo Mount Plate.ai
[Adobe Illustrator source file] The mounting shield that holds that servo motor and slides down the slot in the faceplate fixture. 3.516 x 1.95 in (To be laser cut through 1/8" acrylic. File units in inches.)
postscript -
589.47 kB -
09/22/2019 at 03:50
Download
Servo Mount Faceplate Fixture.stl
The servo motor mounting fixture that screws over the lockset's faceplate. 190 x 60 x 38 mm (To be 3D printed. File units in meters.)
Standard Tesselated Geometry -
114.93 kB -
09/22/2019 at 03:50
Download
Servo Arm Thumbturn Rotator.stl
The rotator disk that attaches to the arm included with the servo motor and loosely fits around the lock thumbturn to spin it. 41 x 41 x 16 mm (To be 3D printed. File units in meters.)
47.54 kB -
09/22/2019 at 03:50
Download
Door Handle Backer Large.stl
The larger half of the backer ring that bolts together with the door handle lever. 77 x 68 x 10 mm (To be 3D printed. File units in meters.)
361.12 kB -
09/22/2019 at 03:50
Download
Door Handle Backer Small.stl
The smaller half of the backer ring that bolts together with the door handle lever. 33.6 x 45.4 x 10 mm (To be 3D printed. File units in meters.)
120.00 kB -
09/22/2019 at 03:50
Download
Door Handle Lever.stl
The door handle lever that bolts together with the two backer ring pieces. 180 x 68 x 18 mm (To be 3D printed. File units in meters.)
1.49 MB -
09/22/2019 at 03:50
Download
NFC Door Unlocker - Source Parts.blend
[Blender source file] Contains the untriangulated source meshes for the five STLs. (To be 3D printed. File units in meters.)
blend -
2.42 MB -
09/22/2019 at 03:50
Download
