Submitted 2/7/2020
02/07/2020 at 17:06 • 0 commentsDiscussion
On my two axis testbed with two motors spun up to average throttle of 1450 (close to what it would hover at with 4 motors) seem to be enjoying a 1 sigma attitude control of better than 0.1 degrees after a half hour of playing with tuning. It is impressive how hard you have to push these things to get them to move. Also included a graph of what the recovery looks like in time with the contributions from the proportional, integral and derivative components of the PID control loop. In attached files have included a video of recovery from a pretty good push on my two axis test setup.
In gallery have included a closeup picture of flight controller board. The two other modules on the breadboard are the MPU9250 with SPI interface wiring back to the ESP. The ESCs required a 5 volt servo input and are being routed through a 4 port 3 to 5 volt level converter, with wires heading off to the four ESCs. The usb plug heads back to my desktop monitor where I can modify parameters (PID gains, throttle speed, etc) and monitor state.
So far I have learned a bit from this project, it's my first exposure to drones, but I do have other relevant experience and think this procedure an informative introduction to the subject. I feel pretty good about being able to make a flight controller at least as good as the CC3D that came with my drone kit. I have gathered info from the web but the code is 100% mine except for the device drivers contained in the esp-idf framework.
Next Steps
Think up tethering scheme for 'safety conscious' indoor hover testing
Free up other drone axis for actual flight (no more metal rod or testbed)
Modify testing software for other 2 motors, yaw and altitude PID loops
Integrate 4 inner PID loops (currently just using 1) into ESC servo commands
Hover!
UPDATE -- Received my much nicer joysticks Saturday morning and mounted them in cigar box. I was expecting the process of getting these working to go smoother than it ended up being. Turns out the ESP8266 briefly uses more than an amp of current when transmitting wifi packets. This resulted in bad adc readings (~5% worst case) during wifi transmits. At first I tried to clean up the power supply going to a battery and further power filtering for the adc and joystick and managed to cut the errors only by less than half - I feel I could have done better with some good 1mF low esr caps which I don't have. Decided to try synchronize adc data acquisition to when wifi transmit is quiet and get rid of the wiring complexity of the filtering effort. The espnow example that I used to start my code with uses an event queue to schedule both espnow transmits and receives, I couldn't find a way to predict when the scheduled transmit would be unspooled from the event queue (even after waiting 100msec). Ended up pulling the transmit out of the event handler and issuing it directly with a 40msec vTaskDelay prior to starting the next adc reads. The 40msec delay seems to have eliminated (none in an hour) the adc interference (a 20msec delay gave me a little noise on one or two of the adc readings every minute or so).Tethering drone by hanging it from ceiling for the time being cradling two arms - need to get to single point (and to a point further from my desk). The metal rod is gone, other two motors incorporated into software. Currently have yaw, pitch and roll inner control loop PIDs tested and tuned for just hanging there at a relatively low throttle, but disturbances to yaw, pitch and roll do correct nicely.
Next going to integrate transmitter commands into flight control PIDs by summing transmitter commands with error input to PIDs (already have communication between boards setup and working on 40msec loop).
Update - Drone hanging from much nicer cradle about 15 feet from desk. Made changes to flight controller to receive flight controller data. In progress of doing some tethered maneuvers. When processing the espnow packets the mpu9250 fifo would overrun (only takes 30msec) and data would be lost and become misaligned, pinning the imu data aquistion and processing to the second core fixed this problem and freed up a lot of headroom - the compiler apparently does not do this automatically. So - it is looking pretty good, I have my transmitter controls doing what I want on the drone. The sensitivity and range of the transmitter controls need to be tamed and further PID tuning and data analysis are on going. Also need to start thinking about some sort of arming procedure to implement as well as fail-safe and disarming procedures.
Log prior to 10-24-19
10/24/2019 at 13:54 • 0 commentsI recently started a project with a kit containing f450 frame, brushless motors, electronic speed controllers and props for a little over $50. They even threw in a CC3D flight controller module, which while not part of the original plan helped firm up a development strategy. My plan is to develop stable platform that will hover (and return) to one spot before trying to focus on 'flight' concerns. The logs contain a story of several implementation attempts that did not pan out. This description is of the current status and direction.
Components :
F450 frame, motors and ESCs
ESP8266 with resistive joysticks and analog to digital converter
ESP32 with MPU9250Transmitter :
The transmitter gathers voltage reading from the joysticks every 10 msec, they are encoded into a string as throttle, yaw, pitch and roll state. This string is transmitted as an ESPNOW packet. For ease of use, the espnow link between transmitter and receiver are hard-coded with each-other's MAC address, discovery and turn on sequence are not an issue. The espnow between the two devices works reliably up to maybe 200 feet with the two devices tested - planning to probably replace these with a couple nrf24l01 (pa+lna) recently ordered. The joysticks that I currently have are barely usable - plan to replace these with a couple jh-d202x recently ordered. A display was originally included bit interrupted some of the espnow packets being sent at 10 msec intervals (access later). Blackbox logging will be looked into later.Receiver :
Hardware development is proceeding using a CC3D flight controller contained in the f450 kit, my daughter has taken lead on mechanical/soldering and test flights (pic included). Currently, the ESP32 on the quadcopter is receiving espnow packets from the transmitter and converting these to SBUS format to communicate with the CC3D flight controller. We used cleanflight to setup the CC3D and then to program the ESC's and make sure the motors were turning the correct direction, allowing us to proceed with mechanical build and soldering. We have armed the quadcopter and had several test flights out in the yard and everything is working pretty well.note : Getting ESP32 to SBUS communications up to the CC3D was not trivial - couldn't really find any starting point except SBUS specs and CC3D/cleanflight does not really support diagnostics. A linux program was written that writes and also monitors SBUS traffic that helped a lot in the development of this code.
ESP32 Flight Controller and Receiver :
The real goal of this project is to write the flight control software from scratch and host it one the ESP32 with a view toward maybe adding a barometer, gps, magnetometer, tof altitude monitor or camera to the platform to keep me busy this winter (and keeping to $100 budget). Progress on the IMU software has been good so far and I'm hoping the high resolution led timers will handle the ESC servo commands at a 10 msec update rate.
Status of IMU software :
- MPU9250 (not using magnetometer)
- ESP32 module SPI interface
- reading 8K gyroscope samples per second
- reading 1K accelerometer samples per second
- simple one-pole low pass on accelerometer x, y and z axes
- simple one-pole high pass filter on gyroscope z axis (yaw)
- trig functions to convert accelerometer data into pitch
and roll data in degrees
- Complementary filter fusion of gyroscope and accelerometer
x and y axes (pitch and roll) (output is angle in degrees)
- start-up calibration
- Inner control loop error estimaters and PID controllers
(pitch, roll and yaw)
Currently the program is working to the point where it outputs to the console the speed commands to each of the four motors as a result of changing the attitude of the board or commands from the transmitter joysticks.Plans :
- more test flights with CC3D
- finding out what can be found out about PID gains prior to first flight, a basic simulation?
- replace those damn joysticks and build a nice transmitter enclosure
- hook up ESP32 to ESC's
- upgrade transmitter with ESP32 - use built-in ADCs and support telemetry display
- add nrf24l01 to receiver and transmitter- explore whether 32K samples per second on gyro would improve stability
Hooked up a test bed (pic) where a stuck a metal rod through the center of gravity along the motor 2-4 axis and suspended it in a box. So far the 1 and 3 motors have been spun up with the motors tab command on cleanflight. While sitting on one of the up/down arrow keys to control one of the motors speed it is hard to keep the drone relatively level, even holding on to the metal rod and doing flight control ops yourself just isn't very stable - I guess my reaction time just isn't fast enough. Once the motors are spun up around half way it feels like it takes some real force on the metal rod axis to tilt the platform - lot of angular momentum.
This platform will help debug and tune the PID controllers nicely.
10-19-19 -- Been doing some testing with only one motor active in my testing rig, found out my esp required a 5 volt input servo signal so I put a level converter between my esp32 and the drone escs - also moved battery to bottom of drone. Added some weight on one of the arms (picture included in gallery) so that the motor had to be spun up to about a 1250 servo command to levitate the drone arm. The arm stays level and moves up and down slightly keeping the drone level to +/- 1 degree. The servo command to the drone varied between 1256 and 1258. Played around with PID gains with a program that I wrote to interactively change setting while drone is running - looking forward to getting the opposing motor hooked up and spinning next. Looks like adjusting gains to minimize PID loop integral is a good way to start in tuning process.
10-21-19 -- Got rid of CC3D flight controller and controlling all four motors with esp32 board now (I can reset the escs and spin up all four motors now)! Did a quick test on my testbed with two motors active and the esp32 leveling the drone. A graph is included of the attitude that the esp32 calculates from the mpu9250 gyroscope and accelerometer data being processed with a complimentary filter - the output is in degrees. The PID output is the sum of the P, I and D terms on the graph and added to one of the motors base throttle speed and subtracted from the other. The graph shows and oscillation of about one hertz in the +/- tilt of the axis with the two active motors of about 1 degree. I believe that it may have been a mistake to build the testbed in a box with closed sides. I'm going to try a new testbed not in a box so the propwash of the propellers can flow away from the test setup - it is possible that part of the 1hz oscillation is in part due to avoidable aerodynamic affects - the flow in the box seems very turbulent and unsteady.
10-22-19 -- The box was a bad idea, thought it would be a little bit safer but concentrating the propwash into a resonate cavity was not good - now there are two uprights supporting axis rod and propwash blows over table. The new graph shows the tilt being much better controlled. Got more tuning to do looks like maybe the Igain is a little high.
Original project description
10/16/2019 at 16:31 • 0 commentsThis is the original project description that was posted when the project was first started a couple weeks ago. I want to rework the description but figured to keep the original as a log entry.
---------------- log entry 09/27/2019------------------
This is an esp-idf project with an ESP32 acting as a flight controller and receiver for F450 quadcoptor drone and an esp8266 D1 mini as radio control transmitter.
I did a project recently with an mcp6050 gyroscope and accelerometer, impressed with the capabilities and ability to keep a reasonable integral of inexpensive mems sensors I decided to find something to control. Some ebay searches pretty quickly lead me to consider building a quad coptor. I soon found a kit containing f450 frame, brushless motors, electronic speed controllers and props for a little over $50. They even threw in a CC3D flight controller module, which while not part of the original plan helped firm up a development strategy. My plan is to develop stable platform that will hover (and return) to one spot before trying to focus on 'flight' concerns.
I've been hobbying around with esp devices for a few months now and have decided to use an esp8266 D1 mini as my transmitter base station and an esp32 as my receiver and flight controller. At first the flight controller aspects will be shared with the CC3D flight controller that I got with my kit package. I hope to integrate the CC3D functionality into the esp32 as we go along, but there is a lot of learning to do here that I can reverse engineer with the CC3D and cleanflight.
Transmitter requirements :
Two way comms to at least 200 feet
be able to sustain packet rate of at least 10/sec (hopefully 50/sec)
collect data from a couple joysticks, switches and a display
return blackbox data from flight controller at packet rate to serial portUsing a webpage as input and a TCP connection between transmitter did not work out, I have familiarity with the IP and was able to test it out in a few hours. Packets started getting backed up at a 300msec launch rate, maybe this could be improved but probably not by a order of magnitude. A couple of browser joysticks on a cell phone might have been nice. The project is now heading in a transmitter to flight controller receiver interface using espnow framed wi-fi station/access point connectivity and i2c interface to ground station hardware (physical joysticks, switches and display). Tests showed a 3x range improvement over my router without the connection and tethering hassles, and much much better packet rates. The espnow protocol is directly between the esp devices to their mac addresses with crc checks and limited handshaking.
The joysticks being, temporarily, used are pretty horrible. They have a huge dead spot at the center where the output resistance doesn't change for about 15 degrees each side of center and the rest of the range is used up well before coming to limit of travel, so the whole usable range is about 15-40 degrees each side of center. The joysticks center position resistance varies considerably and needs to be calibrated and they return to center.
A data acquire task loop is run in the transmitter to read voltage values from an ads1015 every 20msec. The readings are used to update local values for throttle, yaw, pitch and roll. The yaw, pitch and roll are 10bit values coming from the adc, the center rest position value is subtracted, the result adjusted by a chosen gain and added or subtracted (depending on orientation of joystick) to 1500. The throttle does not return to center so its reading (after calibration offset) is accumulated (and multiplied by chosen gain) and added to 1000.
Events are scheduled to run espnow_send every 20msec and a callback for espnow packets received. The espnow_send transmits a string congaing the throttle, yaw, pitch, yaw and other parameters. The callback string received from the flight controller contains telemetry (blackbox) data which is forwarded to the console serial port for collection by attached pc for analysis.
Flight Controller and receiver requirements :
Acquire gyro/accel data and transmitter inputs to control motor speeds
Return telemetry data to transmitter ground stationThe current goal of the project is use the CC3D flight controller with an esp32 receiver interface. The CC3D has a nice interface to simulators such as cleanflight that allow easy setup of ESPs, mems and motor calibration, pids and filtering and telemetry data collection as long as connected (these features will help get started a lot quicker and provide a great debug assistance). The esp32 receiver will need to talk to the CC3D flight controller to supply transmitter data and to obtain telemetry data and write pid, filter and status registers.
When the CC3D flight controller is attached to cleanflight and you snoop on the port with an intermediary (interceppty worked for me - or using three usb dongles) you can see binary data being transferred which turns out to be MultiWii Serial Protocol (MSP), full documentation is hard to find but can be pieced together and checked against snoop data to come up with a good msp.h file. The actual motor control path parameters (throttle, yaw, pitch, roll, motor speeds) all seem to be blocked read only with the MSP interface, at least with my version of CC3D (the version didn't work with later versions of software so I used cleanflight to download firmware backwards until the CC3D booted up). I have gotten one of the CC3D serial ports hooked up to my esp32 to read mcp parameters from the CC3D, and even to negotiate an esp32 hookup directly to cleanflight.
The motor control path variable can not be written with MSP with my version of CC3D and I do not want to use servo pulses to import my throttle, yaw, etc.. values to the flight controller. Decided to use the SBUS semi-digital protocol for this purpose, my version of CC3D also does not support the sbus_invert cli command so an inverter had to be built from an 2N2222 and two resitors. To help debug the development of the SBUS interface I wrote two C programs on my desktop to write SBUS protocol packets for 16+2 channels and another to monitor and decode SBUS packets. The esp32 program has demonstrated SBUS packet transmission to the CC3D flight controller as monitored by the cleanflight transmitter tab and flight simulator.
So, at this point, I can have my CC3D flight controller on my desk hooked up to my desktop and walk 150 feet down the street with my ground station sending throttle, yaw, pitch and roll information. Still need to verify that the other CC3D port can also be used so that the esp32 can have SBUS and MSP running at the same time with the flight controller - just sending a dummy packet right now.
My F450 drone kit has literally just arrived from it's slow trip across the pacific, actually it took exactly two weeks - about half of the estimated delay (I still don't have any batteries so I just ordered some 3s's from amazon - things cost 60% of what the whole drone cost - find it amazing that a small battery like that can put out 80Amps!). Got a lot of work to do building this thing and not make it look like a kludge, but just got a new soldering iron and plan to look at some youtube F450 builds before smashing the thing in uncontrolled ascent to ceiling (considering various mechanical tethering options). Having the cleanflight interface for initial setup will save a lot of time.
First Quick Flight
10/10/2019 at 21:45 • 0 comments---------------Log 10-10-19------------------
Had a nice hover for a little while outside today. Daughter finished up soldering last night. During some preliminary tests we discovered that out propellers were all on the wrong shafts - who would have figured the 'R' numbered propellers would be on the clockwise rotation motors? We did the esc calibration on the cleanflight motors tab and then spun up the motors with the props a bit to see what would happen - we had the unit pretty well tied down but it was obvious that any sort of controlled flight would not be possible in that mode.
Today it took us a while a while to figure out how to arm the quadcopter, partly because we didn't know it had to be done. We tried some initial lift offs and it was worse than direct motor control! Shortly figured out that we hadn't thought about orientation of flight controller board mounting relative to front. After we got this taken care of next test flight had it jump up and hover pretty well.
Pulling data from MPU6050
10/04/2019 at 21:59 • 0 comments----------- Log Entry (10-04-19) -------------
Got done building and testing a 50msec loop in the esp32 flight controller that reads three axes of acceleration data, from a mpu6050, and filters it through a 4 pole butterworth. Also wrote an acceleration calibration subroutine. Tried several different cut-off frequencies, 0.25, 1, 4 and 10 Hz. The output displays roll and pitch in degrees and the z-axis gravity. Just sitting on my desk running the 1Hz filter pitch and roll outputs were always within +/-0.2degrees and z-axis from 0.9994-1.005g. Tilting board 45 degrees gave me 45 degrees roll or pitch and .707g z-axis. 1Hz filter was steadier than the 4 or 10Hz filters and the 0.25Hz just felt a little too slow.
Started work on 20msec loop that will read 1KHz gyroscope outputs and process that data trough the integrators and PID that will eventually supply the motor outputs, the ESCs that came with my kit only take servo inputs so I will eventually have to deal with that.
My daughter and I have kit mostly all built up to the point where we need to start doing some soldering. Added a DC-DC converter to supply esp32 and CC3D.
Planning Next Steps
10/03/2019 at 16:48 • 0 comments----------- Log Entry (10-03-19) -------------
Its time to outline data aquisition, filtering and control goals and implementation stages. As a first guess this is what is being experimented with first.
Acquisition : Gyroscope data will be stored in fifo at 1KHz rate, accelerometer data gathered at 20msec interval at which time data is processed through filtering, control loop and downloaded. Other data such as magnetometer, barometer, laser range finder, gps, etc. may also be collected if new hardware is added.
Filtering : The MPU6050 accelerometer data I am familiar with has a large high frequency component that we do not want getting into our feedback control loop, we should be designing toward a two pole low-pass filter with a cutoff frequency somewhere in the range of .5-2Hz. The gyroscope data will be used for the higher frequency flight adjustments, the lower frequency drift component may need to be filtered out. It may turn out to be useful to notch filter the servo motor control outputs for any observed system sympathetic resonance.
Feedback Control : Three 1KHz PID loops are necessary to control the yaw, pitch and roll axis which will use the gyroscope data. The inputs for each of these loops will be the result that we desire on each on each the integrated gyroscope axis - which can be imagined as something like the angle that we would like. The output of these loops will be combined up to generate servo commands to each of the four motors. Suppose for example we would like to move forward - the transmitter sends a servo pitch value that specifies a desired forward tilt to the craft. The control loop will speed up the back rotors, lifting the back of the drone (and creating force in x axis) until the gyroscope catches up to the forward tilt command, the speed and stability of this transaction is determined by the P, I and D loop multipliers. Gyroscope data is useful to keep the craft in a desired attitude (not rotating on x (yaw), y (roll) or z (pitch) axes).
The accelerometer data provides information to the control loop that helps to imply an xyz point that we wish to maintain. For example, if the wind is blowing the gyroscope would not notice it (unless the drone was being twisted) but the accelerometer would notice an x or y acceleration. This can be somewhat controlled out with accelerometer data PID loops whose output is feed into the gyroscope PID loops just like transmitter pitch or roll inputs (ie I'm getting pushed to the right by a force so lean into it - P gain is how much to lean, I gain is how much to recover from a previous uncorrected push and D gain tells to loop closure to slow down once you start getting close). In software, PID loops are very simple - an error signal is generated at the input which is the difference between the angle that you want the quadcopter to be in and the angle that the gyroscope measures that it is in. The error then follows three paths. The P(roportional) path is simply multiplied by the P gain. The I path has an accumulator which is the sum of all previous error inputs which is multiplied by I(ntegral) gain. The D(erivative) path is the difference between the current error signal and the previous one which is then multiplies by the D gain. The output of the loop is the sum of these three, PID, paths which are combined with the other gyroscope PID loops outputs to generate motor speed commands. Tuning the loop gain parameters can either be done by simulation or tuning the actual system flight response.BlackBox Telemetry : A data packet will be sent to the ground station for collection every 20ms (50 times per second). The payload frame will contain the filtered acceleration 3 axis data, slots for future use (magnetometer, status, estimated altitude, etc) within the first 50 bytes. Initially, 150 bytes will be reserved for the raw gyroscope datar, eventually we will use bits in a configuration word to determine the configuration of the payload (if for example we would like to collect raw motor servo data).
Milestones : First target is to collect all necessary data and blackbox it down to the ground station every 20mssec. The accelerometer data will be filtered. The gyroscope data will be sent down as raw byes from the mpu6050 fifo read. First test flights will probably be with the CC3D flight controller doing the actual work and the data being collected by the esp32 flight controller only reporting gyroscope and accelerometer data. Next step will be to start programming CC3D flight controller with PID gains of 1,0,0, which basically shuts off PID and sends input data to motors. Then lastly control motors directly from esp32 flight controller.
Further testing/add display/eliminated sbus inverter
10/02/2019 at 15:47 • 0 comments----------- Log Entry (10-02-19) -------------
Managed to get rid of the SBUS inverter by switching to the second uart port (uart3 in cleanflight) on the CC3D (labelled flexiport instead of main port). Also have uart1 configured as configuration/msp port at 115,200 buad which I hope to use to send telemetry/blackbox data down to ground station transmitter. In cleanflight it looks like only one serial port can be configured serial rx at a time, when a configured both uart1 and uart3 to serial rx only uart1 was active. When uart1 was configured configuration/msp uart3 started working as serial rx which I configured to sbus.
Further communications testing looking very promising two way espnow between rx and tx and sbus to flight controller.
Added ssd1305 display to ground station transmitter for real time display of throttle, yaw, pitch and roll. I really dislike the cheap joysticks and am looking for replacement - I added the display to help me get used to the play on these controls, they have to be moved a lot off center before value changes at all and then it maxes out with very little further travel.
Cleaned up power supplies
09/29/2019 at 16:56 • 0 commentsI was getting a little bit of noise in the cleanflight transmitter tab - every few seconds my throttle, yaw, pitch and roll values would jump around a bit even though the controls on the ground station were not touched. For the sbus signal inverter I was using the 3.3v from the esp32 module. To add a 5 volt level to my system had to go external because there appears to be no way to get the esp32 module or the cc3d flight controller board to source +5volts. I added the +5v from a usb to serial dongle and now the sbus interface has had no errors in the half hour I observed. I include a link to video of the setup as it current is controlling a drone simulator on the cleanflight transmitter tab page.
https://drive.google.com/open?id=16zrWSgeVZqAOGRBdouZs-SjIfwVNKjcI
One nasty that did occur as I was writing the sbus code for the esp32 module. I had the code ported from the esp8266 to the esp32 and it looked to be just about running, I was testing it with my desktop linux sbus_monitor program and noticed that about 5% of packets were showing up bad. The esp8255 D1mini did not show any packet loss. When I plugged the sbus into the cc3d there were no received packets (and no way to find out why apparently). Went back to the sbus_monitor program to debug packet loss and discovered the following in the table shown below the text.
The esp32 module programmed with a sbus baud rate of 102,000 does not show any packet loss as far as I can see. Interestingly the cc3d sbus connection does show sbus packet confusion at 101,000 and 103,000, the port does not register any activity at 100,000 or 104,000 baud. Which is to say that the cc3d is much more sensitive to baud rate than my desktop. This problem would have been VERY complicated to debug without the linux sbus_monitor program. cleanflight doesn't seem to have much in the line of port packet monitoring or diagnostics (except for the usb port).
As was mentioned earlier the esp8266 modules appeared to have no problem with the 100,000 non-standard baud rate generation and I don't know if other esp32 modules are off by the same amount.
SBUS Serial Port Buad Rate ESP32 Port Packet Loss Percentage to sbus_monitor program Packet Loss to CC3D SBUS port 95,000 100% 100% 98,000 ~10% 100% 100,000 ~5% 100% 101,000 ~1% ~~20% 102,000 ~0% ~0% 103,000 ~1% ~~20% 104,000 ~5% 100% 105,000 ~10% 100% 110,000 100% 100%
