BroBOT
Low-cost collaboration robotic arm, robot with built-in cable,6Axis
bbBB
A cooperative robotic arm with a smooth surface and a human-friendly shape. I don't like too many cables, so all the power lines pass through the inside of the arm -- of course, this puts too many difficulties on the structure, I should be glad to solve these problems :)
Dan Maloney wrote 10/08/2019 at 15:35 point
Bruh...
Very cool look. The renders make it look like carbon fiber will be used for the main part of the upper and lower arms. Will those be load-bearing elements? Or will that all just be a skin over, say, an aluminum structure?
BB wrote 10/09/2019 at 01:08 point
谢谢你的鼓励。手柄是由内ABS +外的碳纤维,这是重量轻且坚固的。
