Semyon
A small simon game using the 8 pin STC15F104W, written in 8051 assembly using the SDAS(ASXXXX) assembler from the SDCC toolchain.
Watch me learn to code in 8051 assembly, to use the SDCC toolchain and to work with the dubious yet lovely STC15F104W microcontroller by creating a simon game using all three skills.
This project has mainly an educational purpose, in which I learn many new skills. These are described more elaborately in the logs, where also most of the progress will be recorded.
Currently done:
  • Being able to program the MCU.
  • Build the game's hardware.
  • Learn how to use the toolchain.
  • Write the game logic.
  • A rewrite of Semyon's code, using byte operations this time and timer interrupts rather than loops.
Currently I have a working game, which is moderately entertaining to play. This is the main milestone I've marked for myself.
So what now? Here are a few ideas which might or might not see daylight:
  • Beautify the game to make it more attractive and fun to play, by e.g. PWM the LEDs to get 'soft' light and fade effects.
  • Add a speaker - add sound to this thing.
  • Add features such as high-score counter, fun game-over animation etc.
  • Make a proper PCB.
  • Write additional games to this thing, such as a basic Whac-A-Mole clone.
Additional ideas are welcomed.
Semyon.CE3
Schematic of the circuit made with BSCH by suigyodo (www.suigyodo.com).
ce3 - 18.38 kB - 10/13/2019 at 23:35
Download
  • 1 × STC15F104W STC 8051 derivative MCU
  • 1 × male 4pin header I recommend a 90 degrees one
  • 4 × tactile switch
  • 1 × on/off switch
  • 1 × 1uF capacitor A smaller one will suffice
View all 8 components
  • Splitting the code to files properly
    HummusPrince08/22/2020 at 00:38 0 comments
    When the code has grown big enough, it made sense to split it into several files. So I've split it into files which make sense together. How can it be done?
    First, one must have define files. Akin to header files in C, these are used to define constants - such as SFR locations - and macros - such as SFR assignments.
    These files are pure assembly files, and as it seems that ASXXXX is agnostic to file extension, I'll go with ASXXXX examples and call these "define.def" and "macro.def".
    These are used in other assembly files using the .include directive, just like C preprocessor #include.
    The cruedest way to get all my files together is to create a capital assembly file which includes all these files. Here is "semyon.asm" where it all goes together:
    .module semyon
    ;Def file includes
    .include "define.def"
    .include "macro.def"
    ;Asm file includes
    .include "main.asm"
    .include "intv.asm"
    .include "inth.asm"
    .include "dseg.asm"
    .include "io.asm"
    .include "delay.asm"
    .include "pwm.asm"
    The "include" directive just copies the included files into the caller file. Unsurprisingly, it gets assembled just as good as assembling it all in one file.
    But now doing it properly
    This approach is not good. The conceptual problem is that it's not doing what I intended - I didn't want it to simply copy and paste my code together, but to assemble it in pieces and then assign all the addresses and tie the hex file together.
    The practical problem is that ASXXXX is not smart enough to trace bugs into the included files. A bug in "io.asm" will come out as a bug in "semyon.asm" in line 12, which is where the problematic file is included. It leaves you guessing where in that file the error has occurred, and I'm not masochistic enough for that.
    Nope, the proper way mandates that I assemble each file independently. It makes sense to include all the ".def" files in each ".asm" file then, but some labels are cross referenced - for example, "main.asm" calls for functions from "io.asm". This can be solved by assembling all the files with global flags.
    This is the makefile:
    build:
        as8051 -losga main.asm
        as8051 -losga intv.asm
        as8051 -losga inth.asm
        as8051 -losga io.asm
        as8051 -losga delay.asm
        as8051 -losga dseg.asm
        as8051 -losga pwm.asm
        aslink -f semyon
        packihx semyon.ihx > semyon.hex
    The "los" flags are the old output files flags. The "g" and "a" flags make user-defined and undefined symbols global, respectively (see docs.). It means that the output files expect to assign these at linking time.
    Linking
    The linker is called aslink (sdld in the sdcc version) and is quite simple. It can get directives from a file, using the "-f" flag.
    The directives are simply structured: Linker flags, output file name, list of input files, and the reminder of the flags, mostly link-time symbol value assignments.
    My linking file "semyon.lnk" is looking like that:
    -mxiu
    semyon
    main
    intv
    inth
    delay
    pwm
    dseg
    io
    -b CODE = 0x0090
    -e
    the -mxiu flags means generate map file, hex base, intel hex output, and update the list files, respectively. See more.
     "semyon" is the name of the output file, the rest are the input files (extensions get ignored).
    "-e" is end-of-file marker flag.
    About the .area directive
    The mysterious .area directive which bugged me makes sense now when multi-file code is concerned - the linker should know how to put the assembled files together, at what addresses and so on.
    The "intv.asm" file, which includes the interrupt vectors, should be strictly located in predefined addresses using the ".org" directive. Thus the area it got, called INTV, must be defined ABS, which means that the addresses must be manually assigned.
    Most of the code however goes in the CODE area, which got the REL flag. That means each file to whom this area was assigned will be concatenated upon the other files in that area, and the ".org" directive is prohibited.
    However, the REL areas must begin somewhere. Originally I wanted it to be at 0x90, after all the interrupt...
  • Using macros
    HummusPrince07/31/2020 at 17:34 0 comments
    Suppose you want to enable or disable external interrupts with certain configurations. You'll have to wiggle some SFR bits for the purpose, probably involving multiple SFRs.
    For me, it's looking thus:
    ;this is ext_int_enable
        orl TCON, #0x05     ;IT1|IT0 - falling edge only
        orl IE, #0x05    ;EX1 | EX0
        orl AUXR2, #0x30    ;EX3 | EX2
    ;this is ext_int_disable
        anl AUXR2, #~0x30    ;EX3 | EX2
        anl IE, #~0x05    ;EX1 | EX0
    This is quite ugly. I want to write it down only once, and than use it couple of times. It makes the code more readable as the purpose of code snippets is made clear to the reader, and reduces the nuisance of writing the whole thing multiple times, reducing bugs and errors introduced by non-careful typeing.
    Sure I can treat these as functions, with calls to their label and returns, but it will miss the point - putting aside the overhead of the function call, which can grow quite large for configurations-rich code, this is not the conceptual Idea I wanted to use in the first place.
    What I really want is that the assembler will replace each of these tags:
    ext_int_enable
    with the code snippet:
    I want it to be replaced directly everywhere the code where the tag appears. I want it to simply delete the tag and paste the relevant snippet instead, in the source code.
    For those of you familiar with C, this is akin to using preprocessor macros (conceptually you can achieve it with an inline function too, given you forcethe compiler to inline).
    Good assemblers, such as ASXXXX which SDAS is based upon, support macros which act just that way. The way to use these with SDAS looks thus:
    ;ext_int
    .macro ext_int_enable
    .endm
    .macro ext_int_disable
    .endm
    Calling macros is almost trivial. In the last post I defined my external interrupt handler thus:
    ext_interrupt_handler:
        reti
    The inside is ext_int_disable, which can simply be called as a macro defined earlier:
        ext_int_disable
        reti
    The assembler replaces the ext_int_disable symbol with the internals of the macro definition above before assembling it. Quite neat IMO.
    Macro arguments
    Say I want to do something cleverer than static configuration of SFRs, e.g. configuring a timer to some value:
        mov TL0, #(0x10000-count)&0xff
        mov TH0, #((0x10000-count)>>8)&0xff
    Where count is the number of timer cycles I want. I might want to use this in several places with different cycle count (that are constant in the code), or rather change this value upon assembly with variable flags (say, different values for different main-clock frequencies).
    One must pass the value to the macro with each use, some how. Luckily, ASXXXX is smart enough to do it quite trivially, by adding the arguments with commas to the macro definition:
    .macro t0_set_count, count
    .endm
    The use is similar. Possible use I had in my code:
    delay_debounce:
        t0_set_count, 0x0010
        sjmp delay_activate
    delay_display2:
        t0_set_count, 0x2000
        sjmp delay_activate
    delay_display:
        t0_set_count, 0x5000
        sjmp delay_activate
     Notice that the values are constant. They can't change on the fly, only during assembly time. To change these values midrun, one must use functions rather than macros. Other possible solution is using a macro with static variables instead of the "count" argument, and change these variables between macro calls.
    Advanced macros
    Assume one want a macro even more elaborate. For example, I want to choose sleep-mode upon calling some macro. I might want it to look something like this
    .macro ext_int_get_input, pd_flag
    ext_int_get_input_beginning:
        clear_ext_int_flags...
  • Peripherals and Interrupts
    HummusPrince02/14/2020 at 23:29 0 comments
    So after having a working version of Semyon I wanted to familiarize myself with use of the special hardware present in the device. That is, timers, external interrupts, and special power modes.
    Timers
    So the STC15F104W has 2 timers, called T0 and T2.
    T0 is really a 16 bit auto-reload timer. One can disable auto-reload or use other timer modes like the 8051 traditional 8-bit auto-reload timer. The traditional control bits for the timer exist.
    T2 is a skinnier version, only functioning as a 16 bit auto-reload timer. It is totally non-compatible with T2 present in the 8052 MCU, and has no bit controls - one has to fiddle with the whole control registers themselves.
    None of these has a prescaler except for the 12 clock prescaler for legacy support, which is kinda lame. However, given the auto-reload feature, one can easily use overflow interrupts to get that exact functionality without giving up any clock cycle precision.
    The first target for changes was the delay calls. The DJNZ loops are simple but this is a classic place to use a timer at. The delay functions now looked thus:
    delay_debounce:
        mov r7, #0x01
        sjmp delay_loop
    delay_display2:
        mov r7, #0x05
        sjmp delay_loop
    delay_display:
        mov r7, #0x16
    delay_loop:
        mov TL0, #0x00
        mov TH0, #0xc0
        delay_loop_2:
            setb TR0
            jnb TF0, .
            clr TF0
            djnz r7, delay_loop_2
        clr TR0
        ret
    This is really setting the timer, and continually polling it. The timer is set to initial value of 0xC000, which is effectively a 14-bit timer which overflows faster. The loop is repeated R7 times, and thus granularity is achieved.
    The next victim must be the seed generation. As mentioned in previous logs, it incremented the LFSR, pooling user input in-between. Replacing it with a time is classic too:
    initialize:
        ;This is the initialization phase of semyon.
        ;It should also generate the seed value for PRNG.
        mov V_LED_CNT, #1
        mov V_LED_MAX, #1
        mov TL0, #0x01
        mov TH0, #0x00
        mov TMOD, #0x00
        mov AUXR, #0x81
        setb TR0
        initialize_seed_loop:
            mov a, P3
            orl a, #P_LED_ALL
            cjne a, #0xff, initialize_ret
            sjmp initialize_seed_loop
        initialize_ret:
            mov a, P3
            orl a, #P_LED_ALL
            cpl a
            cjne a, #0x00, initialize_ret
        clr TR0
        clr TF0
        mov V_SEED_L, TL0
        mov V_SEED_H, TH0
        lcall delay_display
        mov V_STATE, #S_DISPLAY_SEQUENCE
        ret
    That is lots of timer configurations, then enableing the counter and polling user input, then waiting for user to release the buttons, and using the timer value as the seed.
    This makes the seed to increment about 47 times faster. It is almost feasible to use a 24-bit LFSR!
    External interrupts
    In STC15 family there are 5 external interrupts - the traditional INT0 and INT1, and INT2, INT3 and INT4 which are only falling edge activated. In STC15F104W, P3.2 to P3.5 are mapped to INT0 to INT3 respectively, which means they can be used to get user input.
    So I declared the relevant interrupt vectors:
    .org 0x0003     ;ext0
    _int_GLED:
        mov V_INTERRUPT_LED, #P_N_LED_G
        ljmp ext_interrupt_handler
    .org 0x0013     ;ext1
    _int_BLED:
        mov V_INTERRUPT_LED, #P_N_LED_B
    .org 0x0053     ;ext2
    _int_YLED:
        mov V_INTERRUPT_LED, #P_N_LED_Y
    .org 0x005b     ;ext3
    _int_RLED:
        mov V_INTERRUPT_LED, #P_N_LED_R
     V_INTERRUPT_LED is a new variable I declared to store a value indicating which button was pressed, and is used in the game logic akin to the way the polled P3 value was used.
    All these external interrupts jump to the same handler, which disables the external interrupts:
        reti
    Power and Clock Control
    Waiting for external interrupts to happen using an idle loop that polls something still misses the point. What I really want is to enable external interrupts, and then halt the CPU until the interrupt happens.
    There's a register that allows one to do it, called PCON.
    PD and IDL bits...
  • The bugs
    HummusPrince12/29/2019 at 18:43 1 comment
    One thing I've learned from this project is that programming in C keeps the programmer from lots of trouble - it generates the tedious parts of the assembly for you such as switchcase implementations, it assigns variable addresses for you, makes wise use of the registers for you (if it's smart enough) and generally helps one focus on the logic rather than the housekeeping.
    It also keeps you from a big class of bugs. I had many bugs in this project which are not possible to make using a higher language. It turns out that one can make very, um, creative bugs when assembly programming.
    Debug how?
    The STC15F104W has no debug peripherals. It doesn't even have a UART module (if we believe the datasheet), which leaves printf debug out unless I bitbang the UART protocol myself. So what else can one do?
    One possible solution is using a simulator. SDCC comes with a simulator called uCsim. It is a rather simple command line tool that accepts hex files and can do run, step and so on. The executable is called s51. Using it may look something like this:
    > s51 semyon.hex
    uCsim 0.6-pre54, Copyright (C) 1997 Daniel Drotos.
    uCsim comes with ABSOLUTELY NO WARRANTY; for details type `show w
    This is free software, and you are welcome to redistribute it
    under certain conditions; type `show c' for details.
    0> Loading from semyon.hex
    296 words read from semyon.hex
    step
    Stop at 0x000090: (109)
         R0 R1 R2 R3 R4 R5 R6 R7
    0x00 fa 16 bb 11 ad ae 24 88 ......$.
    @R0 53 S  ACC= 0x00   0 .  B= 0x00
    @R1 0b .  PSW= 0x00 CY=0 AC=0 OV=0 P=0
    SP 0x07 88 24 ae ad 11 bb 16 fa .$......
       DPTR= 0x0000 @DPTR= 0x5e  94 ^
       0x0090 e5 40    MOV   A,40
    F 0x000090
    0> run
    Simulation started, PC=0x000090
    Stop at 0x0000c5: (105) User stopped
    F 0x0000c5
    Simulated 2010456 ticks in 1.501994 sec, rate=0.121033
    0> step 2142
    Stop at 0x0000c5: (109)
    0x00 81 75 bb 11 ad ae 24 88 .u....$.
    @R0 29 )  ACC= 0xff 255 .  B= 0x00
    @R1 a9 .  PSW= 0x00 CY=0 AC=0 OV=0 P=0
    SP 0x09 00 98 88 24 ae ad 11 bb ...$....
       0x00c5 08       INC   R0
    F 0x0000c5
    Simulated 36000 ticks in 0.032018 sec, rate=0.101667
    0> dump iram 0x00 0x3f
    0x00 81 75 bb 11 ad ae 24 88 Vw....$.
    0x08 98 00 52 db 25 43 e5 3c ..R.%C.<
    0x10 f4 45 d3 d8 28 ce 0b f5 .E..(...
    0x18 c5 60 59 3d 97 27 8a 59 .`Y=.'.Y
    0x20 76 2d d0 c2 c9 cd 68 d4 v-....h.
    0x28 49 6a 79 25 08 61 40 14 Ijy%.a@.
    0x30 01 01 6a a5 11 28 c1 8c ..j..(..
    0x38 d6 a9 0b 87 97 8c 2f f1 ....../.
    Using uCsim feel very spartan, because of it's crude/practical user interface. Although it should be easy to wrap uCsim in python and do complex things as the docs suggest, I look for something more user friendly. Alas, it doesn;t seem like there are any simulators which are much better.
    Thus for most of the bugs, I used the LEDs as indicators for program state. A very crude printf if you'd like.
    Traps for young players
    The first bug took the longest time to find. I had delay loops that look something like that:
    delay:
    	mov r6, 0x00
    	mov r7, 0x00
    	sjmp delay_loop
    delay_loop:
    	djnz r7, delay_loop
    	djnz r6, delay_loop
    	ret
    The logic didn't work right, but more furstrating was that the delays were non-consistent at all, getting shorter each time, then getting long as intended and repeat ad infinitum. Can you spot the mistake?
    That right, i forgot the # symbol to mark immediate values. Instead of teh immediate 0 I gave it the IRAM address of r0 which is also 0, but r0 was in use by the logic and thus got altered, making the delay really groovy.
    You'll never get such a bug with C - the closest thing would be misinterpreting a pointer as a variable or vice versa, and the compiler might warn you about it.
    The next big bug I had was regarding the jumptable I showed in the previous logs. The code looked like this:
    	mov a, r3
    	jmp @a+DPTR
    jumptable:
    	sjmp light_rled
    	sjmp light_yled
    	sjmp light_gled
    	sjmp light_bled
    The other logic should have light the LEDs consequently using this routine, red-yellow-blue-green, however the red LED lighted once, then the...
  • The code - part 2 - Random colors and buttons
    HummusPrince12/27/2019 at 17:56 0 comments
    My name is Random, Pseudo Random
    We need to create a random sequence to display to the player. Generating real random values for the LEDs is possible, though may be somewhat cumbersome as it means constantly generating random variables and storing them.
    Moreover, it is probably unnecessary. This is just a game, not some crazy bitcoin e-wallet that depends on true randomness to securely store all your money or something.
    Introducing pseudorandomness! We can generate a sequence that looks seemingly random to the unsuspecting eye, but is generated using some sort of deterministic algorithm.
    Magical LFSRs
    One such algorithm is called a Linear Feedback Shift Register, or LFSR in short. The idea is using a shift register of certain length, and shift in the XOR of several bits from the shift register itself (hence the feedback). These bits are usually referred to as the LFSR taps.
    For an LFSR, initial state matters. All LFSRs output a constant stream of 0s when initially loaded with zeros. But when loaded with anything else, a sequence of 1s and 0s will flow out.
    An LFSR is a finite automaton, thus can only output a finite stream of bits before it repeats itself. If the taps are chosen in a certain way, one can get the longest stream possible, which for an LFSR of n bits is 2^n - 1 states.
    For further read, I can recommend the book 'mathematics - the man made universe' by Sherman k. Stein, whose 8th chapter offers a different look on the subject of such maximal bit sequences, concerning medieval indian poetry rhythms.
     Are 16 bits enough?
    Anyway, I've chosen to use an 16-bit LFSR, where each LED value is two consequent bits of the LFSR. It means that all the possibilities for the first 8 LEDs are possible (apart from 8 consecutive LEDS), but the ninth LED and beyond will be determined by these first 8 LEDs in a deterministic way.
    How long will it take until the player would play the same game twice? According to the birthday paradox, after about 256 games there is a 50% probability that some games had identical sequences.
    That result is good enough for me - I don't suspect that any user will play that many game and also remember the sequence behind that. Moreover, I personally get bored after 20 games at most, usually far less. So it must be fine I guess.
    Comparing it to an 8 bit LFSR, the number of possible sequences is 256. The player will begin to see repetitions after 16 games with 50% probability, which isn't that great. The game will probably begin to feel degenerated after 15 minutes of gameplay or so.
    How it really look like
    The LFSR I decided to implement looks thus:
    Notice that it's not what I have described before - this is a Galois LFSR, where the output get xored to multiple bits inside the shift register. I'll shortly explain why I chosen Galois LFSR, but for now it's enough to say that it's basic properties and behaviour remain the same.
    The polynomial should be maximal to get a full sequence - I just took the polynomial from the table in the wikipedia article for LFSRs, and briefly made sure that it is indeed maximal by simple enumeration of the outputs.
    This is how the nice picture translates into code:
    inc_lfsr:
        ;Now with Galois LFSR of 16 bits with polynomial
        ;x^16 + x^15 + x^13 + x^4 + 1 (mask 0xa011)
        clr c
        mov a, r0
        rlc a
        mov r0, a
        mov a, r1
        rlc a
        mov r1, a
        jnc inc_lfsr_ret
        mov a, r0
        xrl a, #P_LFSRMASK_L
        mov r0, a
        mov a, r1
        xrl a, #P_LFSRMASK_H
        mov r1, a
    inc_lfsr_ret:
        ret
    There isn't that much to it. r0 and r1 are the low and high byte of the LFSR respectively (MSB of r1 is the feedback bit). The convenient way to shift them left as one long shift register is shifting each byte, using the C flag to hold the output of low byte and pass it to the higher byte.
    After we shifted them all we're left with a feedback bit, now stored in the C flag. If C is 0, no action is needed and we immediately return. However if it is 1, the...
  • The code - part 1 - Variables and Jumptables
    HummusPrince12/24/2019 at 23:49 7 comments
    Finally we've got there - a working version of Semyon! :D
    I've incrementally built the code, starting with simply flashing the LED's, then flashing them according to a sequence stored in the memory, and when I've had a functioning game logic I only had to add a random sequence generation. All this history (and this first working version) can be found in the git repository of the project.
    Let's have a look at the code.
    Variables and Parameters assignment
    Higher languages such as C hide from the user many many dirty details of their work. It's probably for the better. One of these details is assigning memory addresses to variables. However, writing in assembly, I have no such luxuries. Thus, I had to manually assign addresses to all the variables I use.
    This way of work may seem inherently wrong to programmers who has only worked with high level languages, but strictly speaking about 8051 architecture, these MCUs were designed to be programmed that way. This is also why there are 4 switchable register banks, which are great for assembly programming. Compilers however don't use that feature well, if at all.
    8051 was designd that way because compilers weren't as widespread as they are today - assembly was just the way one would program these things. I don't suspect the designers have believed that their design will be so popular and widespread, and refuse to die even 40 years after it's invention. That's also why there aren't any good, effective compilers for 8051, say a GCC port, despite the huge popularity of the ISA.
    Moreover, the way I assign variables means that my variables will be global. This might pass shivers down the body of many programmers. Though it is technically possible to assign variables on the stack in assembly - that is what the compiler does, basically - this would be quite bulky and cumbersome, and given the fact that the stack is quite short anyway (and no heap to speak of without XRAM available), this is probably the original way to code this thing.
    SFRs and parameters
    Now to some code. First are SFRs which I use:
    ;SFRs
    PCON2 = 0x97
    This can seem weird, as the assembler should already recognize all of 8051's SFRs. Yet, each 8051 derivative adds new SFRs to the original design, which the assembler can't possibly know about.
    Furthermore, some of the more liberal 8051 derivatives dumped some original peripherals, have altered their functionality, or have other SFRs located in the same addresses of the original ones. Timers are convenient victims - for example the STC15F104W has no T1 timer.
    Thus I had to add myself the SFRs that I want to use. Specifically, in STC15 series, PCON2 controls the internal clock divider, which I wanted to modify sometime during development, and it's address is 0x97.
    Later come parameters:
    ;Parameter values
    P_LFSRMASK_L = 0x11
    P_LFSRMASK_H = 0xa0
    ;State values
    S_INITIALIZE = 0x00
    S_DISPLAY_SEQUENCE = 0x01
    S_GET_USER_INPUT = 0x02
    S_GAME_OVER = 0x03
    S_INVALID = 0xff
    These are akin to /#define statements in C. These are simply constants which I use in the code. They have no manifestations as IRAM addresses as variables or SFRs have, but rather that of immediate values.
    The state values are no different. These are the states of the state machine, which must be enumerated someway. Thus they are no different than parameters, except that their exact value doesn't really matter to me.
    Variable and where (not) to find them
    Then come the variables assignments:
    ;Variable addresses
    V_LED_CNT = 0x30
    V_LED_MAX = 0x31
    V_STATE = 0x40
    V_SEED_L = 0x20
    V_SEED_H = 0x21
    ;Bool variables bit-addresses
    RLED = P3.5
    YLED = P3.4
    GLED = P3.2
    BLED = P3.3
    The abstraction we have of variables in our minds boil down to simply a specific address in the memory which we tagged with a name and assigned a certain purpose to. The code is a lot more sensible when writing MOV V_STATE, #S_GET_USER_INPUT compared to MOV 0x40, #0x02 which isn't very meaningful...
  • The Logic
    HummusPrince12/21/2019 at 20:05 0 comments
    The logic of a Simon game is quite simple. It should save a random sequence of LEDs to light, each round appended with another random LED value.
    After appending it, the new sequence should be displayed to the user, and then wait for the user to click the buttons in corresponding order. If the user succeeds in doing so, the random list increments and the show goes on the same way. But if he fails in doing so, then he has lost - the game should be abruptly stopped with some visual signal, the random list is shorted to 1 value and the game begins from zero.
    The basic implementation I thought of has these 4 states, each has it's special functionality:
    There only seem to be 3 variables necessary - The length of the random list, the current index of the user in that list, and the random list itself.
    The first one, which I have called V_LED_MAX, is really the score of the player. The second, which I called V_LED_CNT, is an auxiliary variable used to pass on the random list.
    Though using jumps in the end of each state, I ended up making each state a function, called from a main switch-case that is the state machine. A new variable called V_STATE was added to store the state.
    Looking at it now, using this state machine isn't really adding anything useful apart from making the state machine explicit rather than implicit, hiding at jumps in the code. But given that it's a very simple state machine, and given that V_STATE is updated before ret commands anyhow... meh, it could have been just jumps.
    Anyway, I'll present some assembly code of Semyon in the next log.
  • Blink with SDAS
    HummusPrince10/14/2019 at 20:10 2 comments
    So after I gathered enough information and examples for using SDAS, I gave it a shot.
    The code should light the LEDs one after the other, then turn them off at the same order. The result came out something like this:
    .module blink
    .area INTV (ABS)
    .org 0x0000
    _int_reset:
    	ljmp main
    .area CSEG (ABS, CODE)
    .org 0x0090
    main:
    	cpl P3.2
    	acall delay
    	cpl P3.3
    	acall delay
    	cpl P3.4
    	acall delay
    	cpl P3.5
    	acall delay
    	nop
    	nop
    	nop
    	nop
    	sjmp main
    delay:
    	mov r4, #0x00
    	mov r3, #0x00
    wait:
    	djnz r4, wait
    	djnz r3, wait
    	ret
    In the spirit of the usynth example, the areas are called INTV for interrupt vector and CSEG for the code segment. The code begins in address 0x90 as the interrupt vector address of INT4#, the farthest interrupt here, is 0x83.
    I called the assembler in the command line:
    sdas8051 blink.asm
     While my code had errors, it shouted errors at me. But once the code was functioning, nothing happened. No hex file has appeared, or other output file whatsoever.
    "sdas8051 -h" to the rescue! By looking at possible flags, it looks like I want to add the flags -l, -o, and -s to generate list file, object file and symbol file accordingly:
    sdas8051 -los blink.asm
    Runnig this generated these files, but none are hex. It seems that there's a need for linking now - although there's only one file here.
    The linker is called SDLD, and it's flag list suggests that the -i flag generates an intel hex out of the arguments:
    sdld -i semyon
    This generated a .ihx format file. Looking at it, it looks like some gimp cousin of the intel .hex file with a weird extension. I'm not the only one who hates it, so a short google has showed me that SDCC has a utility called 'packihx' just to make these .ihx files into proper .hex files, mostly by ordering and aligning them.
    Now that I have a blink.hex file I can finally download it to the chip! The lights indeed did their thing on and off, as I wanted them.
    To ease the build, I made for semyon the crudest makefile you've ever seen:
    build:
    	sdas8051 -los semyon.asm
    	sdld -i semyon
    Now that's I can use SDAS correctly, it's time to do write semyon's firmware!
  • The assembler
    HummusPrince10/14/2019 at 18:52 3 comments
    Now that I took care of the hardware, it's time that I'll work my toolchain.
    As mentioned, I want to use an open-source toolchain, and SDCC looks like a good choice. The suite has an assembler called SDAS, a linker, and some other stuff. As I want to use assembler, I must tackle SDAS.
    SDAS is said to be based on the ASXXXX suite of assemblers which supports a hell lot of architectures. Still, I found little to no examples of use, and as it raises errors for sources that work on vanilla 8051 assemblers such as A51, I had to find other kinds of information.
     For more information, I found a webpage with documentation for the original ASXXXX assembler. Specifically, I found the directives page very enlighting. But alone it's not enough for me to write an assembly code from scratch.
    One thing I did was to compile a C file using SDCC and look at the output .asm file. So I've written a basic blink that looks somewhat like this:
    #include <stdint.h>
    #include <8051.h>
    void main() {
        uint16_t i;
        while(1){
            for (i = 0; i == 0xFFFF; i++){}
            P3 ^= 0x04;
     This code was able to compile, but the resulting .hex file did not blink the LED. I probably haven't done it right, as SFRs may need special attention.
    Lets look at the resulting assembly:
    ; File Created by SDCC : free open source ANSI-C Compiler
    ; Version 3.9.0 #11195 (MINGW64)
        .module blink
        .optsdcc -mmcs51 --model-small
    ; Public variables in this module
        .globl _main
        .globl _CY
        .globl _AC
        .globl _F0
     The first thing is defining a module. After it is some special comand for sdcc. Then there are a whole lot of global variables, corresponding to special bits and registers. Note how directives start with a dot sign, unlike vanilla assemblers.
    Then came this:
        .globl _SP
        .globl _P0
    ; special function registers
        .area RSEG    (ABS,DATA)
        .org 0x0000
    _P0    =    0x0080
    _SP    =    0x0081
    _DPL    =    0x0082
    _DPH    =    0x0083
    _PCON    =    0x0087
    _TCON    =    0x0088
     It declares something as an area, probably calling it a registers segment, with the ABS and DATA parameters. The ABS flag means, as I have learned later, using absolute locations for the code, thus the .org 0x0000 directive after it means that this segment of code starts at 0th address. Dunno about the DATA flag though. However it doesn't seem important, as this part only looks like a '#define' section.
    Lets move on. The following lines contain an awful lot of these directives, without any real code, until we find the interrupt vector:
    ; interrupt vector
        .area HOME    (CODE)
    __interrupt_vect:
        ljmp    __sdcc_gsinit_startup
    ; global & static initialisations
        .area HOME    (CODE)
        .area GSINIT  (CODE)
        .area GSFINAL (CODE)
        .area GSINIT  (CODE)
        .globl __sdcc_gsinit_startup
        .globl __sdcc_program_startup
        .globl __start__stack
        .globl __mcs51_genXINIT
        .globl __mcs51_genXRAMCLEAR
        .globl __mcs51_genRAMCLEAR
        ljmp    __sdcc_program_startup
    ; Home
        .area HOME    (CODE)
        .area HOME    (CODE)
    __sdcc_program_startup:
        ljmp    _main
    ;    return from main will return to caller
    Behold, a reset vector! It makes an LJMP to initialisations, which came out null for this piece of code. When it's done, it LJMPs us to the '__sdcc_program_startup' label which directly jumps us to the main function. This is probably akin...
  • The hardware
    HummusPrince10/14/2019 at 10:52 0 comments
    Now that I can download code to the micro, it's time that I design and build the hardware.
    As the MCU has only 8 pins, there is no much choice but multiplexing the LEDs and the buttons. The GPIOs of traditional 8051 are open drain with little to no internal pullup. Though newer derivatives including STC15 series have other options for the GPIO which include push-pull, it defaults to this weak pull-up configuration.
    This is quite useful, as we can pull down the LEDs (with it's in series resistor) with both the GPIO and a tactile switch to ground, connected in parallel to it. Thus the following schematics:
    The 4 pin header to the left is used to get both RX and TX (and GND) from the USB to serial adapted, but also to get 5V of Vcc from it. I used an 90 degrees angled header. The switch on the power rail is used to turn the device on and off, necessary also for programming.
    The values of the resistors were chosen empirically to get good enough brightness, but not too much. The capacitor on the supply line is usually a good practice and the datasheet recommends using one, although you'll get with a smaller one than 1uF.
    I have put it all on a protoboard. Here's the result:
    I made sure that it works by pressing all the switches and see the LED lights up, and also by downloading a code that blinks them all. Good enough, the hardware is simple enough that I built it with no errors whatsoever.
View all 12 project logs
GudrunJones wrote 01/15/2021 at 06:07 point
When your passion becomes a profession, you learn things doing your project. I have been assigned a project like this and I had no idea how to do it successfully. It is great to know how to learn things from the projects that you are doing. Well, I have written a motivating essay for the programmers with the help of essaywritingservice which I hired after reading reviews about it at EduBirdie source because I was told that it is the only source that shares real reviews of the people with us.
