1Project demo
2Prepare the Bodies
For this project we used cheap Halloween decorations that can be found in a dollar store and turned them into fully functioning robots.
For step one of making the skull a robot, we cut its head off from the stand with a small hacksaw.
3Assemble the Electronic Part
We used a pan/tilt kit with two servos, the Arduino Uno and the HM-10 bluetooth module.
Skully requires the additional SG-90 servo motor.
See the attached schematics.
4Make the Housing
For housing, we used a cardboard gift box with a wooden lid.
We attached a battery pack with a on/off switch inside the box using double sided tape and cut a hole on the side of the box so the switch can be accessed from the outside.
We drilled a small hole in the lid for the wires that connect the LEDs and the servo motors to go through, and attached the pan/tilt mechanism on the lid.
5Attach Ghosty or Skully to the Pan/tilt Mechanism
To attach Ghosty or Skully to the pan/tilt mechanism, we used disposable forks. To attach Ghosty or Skully to the pan/tilt mechanism, we used disposable forks. The Skully's fork is shorter.
6Make the Red Eyes
We made the red eyes using LEDs.
7Connect the Servo Motor to Skully's Jaw
For Skully, we used another servo so he could move his mouth while he laughs, which looks awesome but requires a little bit more work that Ghosty.
8Upload the Arduino Code
Download the Arduino code from here https://www.robbie-app.com/Robbie_A1.ino
Connect your Arduino UNO to your computer using the USB cable.
Upload the code to the Arduino UNO
Download the iRobbie-A App to your iPhone from Apple AppStore
Run App, choose Face Tracking, connect your iPhone through Bluetooth to the Arduino, enjoy!
Hi, I always wanted to try similar thing out. :) Very cool project .
Meanwhile i am trying to do Home automation by making a stepper motor switch on a physical switch over BLE. I want to run this over battery . So your project is a very good start.
Could you tell me how long the battery power lasted . Coz I am thinking to use less power consuming Arduino compatible chip like ATtiny85.
