My entry to this year's Hackaday Superconference badge hacking competition is once again a custom designed plastic enclosure for the PCB. I'm including a model for the cartridge door / back, all the light pipes for LEDs, and buttons and D-Pad for the control interface. I've tried to expose all of the correct ports with enough space around to plug cables in.
I had to enter the badge enclosure in the "hardware" category, for lack of a better category, and so didn't win a damned thing.
Man, I worked so hard on this! I worked for a week and a half, and then each night until 6am. Each day I'd wake up after 4 hours of sleep and then still have 2 hours of time waiting for the 3d printer before I could run off to the show, which meant I missed all of the mornings and didn't arrive until 1pm or later (5:30 on Friday).
Now that the show is over, probably nobody will ever touch this badge again, since they aren't for sale or anything.
Perhaps this was not a good use of my time.
For completeness sake, I made some last adjustments to the model to help the buttons to not bind. I'm not going to bother to print it.
It's all on GitHub. Go get it if you care.
Here are pictures of the next to final version.
Front view; notice there is not a grille for the speaker. I didn't bother to populate the lightpipes, since they just blur out the LEDs. You can put them if you want.I call this the "three cheeks" version.Bottom View; the HDMI port seems a bit more recessed than I'd like.Side View; notice the power switch. Sometimes it works. I don't think That's my fault, the switch used is pretty shitty, and mounted in a strange recess for some reason.Side view; USB side.Cartridge port and cartridge
I like this enclosure a lot and will probably try to print it soon. What kind of filament did you use for the light pipes? How long did it take to print for you? Thanks!
IIRC, prints were originally something like 16-20 hours, but I drastically increased the speed for printing of rafts, support, and infill and got it closer to 9, but at some loss of quality.
I think this is awesome! How's to say what is an isn't a good use of time, but I certainly enjoy seeing your legacy of great badge enclosures!
