Lighting with Tiny bit Tutorial 3.1: LED light
Tiny:bit microbit robotis a robotic car for the micro:bit education market.
It is compact, easy to assemble, and easy to move in tight spaces. The Tiny:bit smart car is based on the micro:bit development board design and uses the online code programming of MakeCode Editor.
  • 1 × Robot Kit for Micro:bit to Learn Programming STEM Education
  • 1
    1. Preparation
    1-1.The position of the LED lights in the robot car
    1-2.Learn about the principle of LED
    Programming method:
    Mode 1 online programming: First, we need to connect the micro:bit to the computer by USB cable. The computer will pop up a USB flash drive and click on the URL in the USB flash drive: http://microbit.org/ to enter the programming interface. Add the package: https://github.com/lzty634158/Tiny-bit to program.
    Mode 2 offline programming: We need to open the offline programming software. After the installation is complete, enter the programming interface, click【New Project】, add package: https://github.com/lzty634158/Tiny-bit, you can program.In the picture shown below, the two white squares circled by the red wire frame are the colorful lights on the Tiny-bit.
    Principle:  LED light (red, green, blue) are packaged in the LED module. We can mix different colors(256*256*256) by controlling the brightness of the three LEDs.
  • 2
    2.Learning goal
    2-1.Learn how to use RGB lights graphically program building blocks
    2-2.We will make two LED lights of Tiny-bit light up white by programming.
  • 3
    3.Search for block
    The following is the location of the building blocks required for this programming.
View all 5 instructions
