'Same Pulse' Video Walkthrough
12/08/2019 at 17:15 • 0 commentsVideo for walkthrough and experience the interactive art installation:
Concept Video of the project
12/08/2019 at 17:04 • 0 comments'Same Pulse' Concept Video:
Exhibition
12/08/2019 at 16:53 • 0 commentsDate: 22/11/2019
Set up for the exhibition:
Motion Graphic
12/08/2019 at 16:40 • 0 commentsDate: 10 / 10 / 2019 - 6 / 11 / 2019
Motion Graphic Video, Made in Adobe After Effect.
3D Printed Heart
12/08/2019 at 16:30 • 0 commentsDate: 12 / 9 / 2019 - 27 / 9 / 2019, 2 / 10 / 2019
Designed 3D heart and 3D printed out. First 3D heart will be hard and
small. After that, lecturer Ron provided soft material to print the heart.•3D Heart using cura software to print out.
•Soft 3D material to printed 3D Heart.
Prototype to the actual:
Technical Part
12/08/2019 at 14:56 • 0 commentsDate: 14 / 8 / 2019 - 17 / 8 / 2019
Testing for capacitive sensing, LED strip and dc motor. Used random jumper wire and breadboard
•Touch on the copper tape to activate capacitive sensor.
•Test on two LED, placed LED with the L298N. Included DC motor.
Date: 27/ 9 / 2019
Included audio speaker and stick with capacitive sensor. And tested with the heart beat light. Speakers are making vibrate effect for people to feel the heart beating when placed the palm on the board.
•Capacitive sensor combine with the speakers.
•Tested for LED combine with 3D heart look, it beautiful.
Date: 11 / 10 / 2019 - 16 / 10 / 2019
Combined and connected two Arduino boards with the speakers into the touch sensor's wood board.
•Technical part combine.
•Install into the touch sensor board.
•Two Arduino board, speaker, Led strip and wires.
•Breadboard changed to the veroboard.
Date: 18/ 10 / 2019 - 26 / 10 / 2019
Pre-set up the art installation look. Measurement the distance of the projector and the visual that matched with the 3D heart.
•Pre-set up and test.
•Keep solving problem.Date
28 / 10 / 2019 - 8 / 11 / 2019
Pre-set up, used masking tape to tape all the wires and get wire neat and less messy. The problem is the wires too messy and the code cannot sent normally. Before the problem solved, the LED light will jump to random color when I touched. This problem I have to said because I found this simple problem took a week ago. It wasted my time a lot.
•Solved problem.
•Try to include sub-element like DC motor for heart beat.Date: 28 / 11 / 2019
Exhibition that day, I placed all the Arduino's boards and wires to a small board to easy carry and look neat and clean.
•Make sensor board smaller.
•Easy to take and put. -
Touch Sensor Wood Board
12/08/2019 at 10:41 • 0 commentsDate: 9 / 8 / 2019 – 5 / 9 /2019
I have mockup or test and measurement the sensor’s
board. I have tried two time for found
out the right measurement.•The mock up of the sensor board used cardboard.
•Measurement and design.
•Measure for putting the projector into the sensorboard.
Date: 5 / 9 / 2019 – 9 /9 / 2019
Also tested and applied automata
into the sensor for the touching vibration feel like heart beating but
it gave me the vibration feeling too soft.•Using MDF material and cnc cut through the shape.
•Before is using automata concept to test the touch beating effect and it work to soft for beating.
Date: 11 / 9 / 2019
•Mock up testing set up.
•Measurement of the installation.
•Mapping measurement for 3D Heart size match with the motion
Date: 11 / 11 / 2019- 22/11/2019
•Add the instruction board and brown fabric into sensor board.
•Lock the phone inside.
