1-Hour Board KiCAD Tutorial
An example of a microcontroller breakout of the MSP430G2553 from Texas Instruments
Board I designed to teach KiCAD to students and coworkers. It's an incredibly simple breakout for the MSP430 that, under perfect circumstances, 'can' be put together in under an hour. To do it right takes more like two, but sadly the silkscreen limits me to one hour, and we all know the silkscreen doesn't lie ;)
Files on GitHub if you want to build your own, plus I have a few extra that should be on Tindie shortly!
NOTE: There is NO WAY to program this board without external hardware. You would need either an existing MSP430 dev kit or other programmer (highly recommend MSP-EXP430G2ET)
hobbylobbyhours.us wrote 06/13/2024 at 13:28 point
I designed a straightforward breakout board for the MSP430, perfect for teaching KiCAD to students and coworkers. The board is simple enough to be assembled under ideal conditions in less than an hour, though doing it properly usually takes about two hours. However, due to silkscreen constraints, we have to stick to a one-hour assembly time.  <a href="https://hobbylobbyhours.us/"> Click here</a>
hobbylobbyhours.us wrote 06/13/2024 at 13:27 point
I designed a straightforward breakout board for the MSP430, perfect for teaching KiCAD to students and coworkers. The board is simple enough to be assembled under ideal conditions in less than an hour, though doing it properly usually takes about two hours. However, due to silkscreen constraints, we have to stick to a one-hour assembly time. Click here: https://hobbylobbyhours.us/
Dan Maloney wrote 12/11/2019 at 16:48 point
I've been teaching myself KiCad lately, mostly using YouTube videos. How does your tutorial work?
Tom Nardi wrote 12/12/2019 at 03:13 point
Consider me interested as well. I get as far as routing when working on my own, things never seem to go how I want after that.
Andrew Kowalczyk wrote 12/12/2019 at 03:13 point
It's meant to be an interactive workshop where everyone makes this board. I go through all the basic steps of creating a schematic, generating a netlist, and putting together a board file live, but what I found was that if I do it in an hour most people get very far behind, so I'm still refining it (should probably be more like 2-3hrs so everyone can follow along). It looks like I'll be presenting this again in the next few months for a club I was in at RIT, hoping to get a recording of it next time.
