Some time ago I made 3rd revision of the generator. I've just uploaded design files, description and measurements. I achieved some improvements, the most important change is the output amplifier (already described in the last design log).
Most of measurements are done using librevna. It has harmonic mixing mode which allows to make some measurements above 6GHz (although be careful with measurements of active devices and fundamental frequency is still there). Calibration was done using PCB test fixtures as shown below (SOLT or TRL possible).
VCO
One of the VCOs was
tested – 3-3.5GHz. Output level was tested with LibreVNA,
previously calibrated using good RF generator. The level is near to
0dBm in the whole frequency range. The results look ugly because 1.
LibreVNA is not spectrum analyzer and shows the unwanted tones, 2. no
shielding, 3. no closed loop PLL, just VCO alone so the low frequency
noise is not filtered by PLL.
Example measurement:
VCO 3-3.5GHz, at 3GHz, 50R added in series, measured value with added
10dB attenuator - power -1.5dBmThe second test of
VCO is S11 at output. I simply measured VCO using VNA while it
oscillates but I’m not sure if it’s good method. It seems that
the VCO output has low impedance (probably it makes sense – it’s
OC circuit) so adding 50R in series at the output decreases S11.
VCO 3-3.5GHz, at 3.5GHz, 50R added in series, S11 away from
oscillation frequency - about -10dB
VCO selection switch
Not tested but
expected to be not worse than filters switch
Variable attenuator
Typical application
of BAP64Q 4-diode attenuator – 2.7dB insertion loss, 23dB
attenuation at 3.5GHz.
Full off:Full on:
2-3.5GHz amplifier
Initially there was
a weird shape of gain characteristic.
It disappeared after
removing some decoupling capacitors – instead of 2.2pF parallel
with 47pF, only 2.2pF was left. It looks like some resonance was
caused by the 47pF capacitors parasitic inductance (C707 and C703
removed).
Simulation for
comparison:
Doubler
It’s hard to test
because I’ve no proper equipment for the task. I tried testing is
in connection with amplifier to drive it with reasonable level and
output filter to have only one tone – then the signal is measured
with a HP 33330B detector. Power of the signal with amplifier is
compared with power of the signal after doubler and filter.
Loss of the doubler
is probably about 10dB (13-16dB including with filter)
Also I did simulation in spice which confirms about 10dB loss and confirms that doubling works best with not too high input power, less than 10dBm.
Filters
Filters were
measured and the results were ok, loss better than 5dB on FR4, only
center frequencies should be slightly increased.
Switches for filters
Only one diode
tested. The switch was redesigned. Two PIN diodes in series provides
better attenuation when off and have not bad insertion loss when on.
Larger pieces of copper between the diodes are to partially
compensate diodes inductances by adding some capacitance (works in simulation, not sure if also
in real world).
onoff
Output amplifier
Previous version of
4-7GHz output amplifier was very similar to 2-3.5GHz amplifier but
didn’t work as well and I couldn’t determine why it differs so
much from simulation. I failed to find a way to tune it so that gain doesn't drop that bad at 7GHz. Insufficient output level in was the major issue in rev2.
New amplifier was
designed, measured and tuned.
Gain of 3 amplifiers
connected (note: 2x 10dB attenuator installed – real gain is
22-27dB).
Output filter
Low pass output
filter was removed because it probably didn’t work well (acc. my
inaccurate measurements, too much loss at 7GHz and poor attenuation
above).
PLL
Improvements of PLL
filter was important for phase noise. Initially, with both PLLs
performing poorly I couldn’t get any results with RBW set to 1kHz.
Dedicated software
was used for the design, together with testing, trails errors.
With both filters
for both PLLs (1st and 2nd LO) RBW 1kHz makes
more sense. The filter removes a low of low frequency noise (which is
large, especially in the prototype without any shielding)
I've made a new revision of the project. See LO1rev2_design_pack.zip for KiCad design, various simulations, design description. It's mostly redesigned, a little simplified although still I didn't try to avoid silly design decisions so don't expect high performance or usefulness of the design.
Short summary of changes:
In general, more components are wideband, previously there were mostly three signal paths for each sub-band (4-5, 5-6, 6-7GHz)
VCOs - Changed to a normal Clapp oscillator, I had some problems with this topology in 1st revision but it seems to be working OK if parasitics are reduced (tight layout, only single tuning diode). It works (that's all I can tell about it's quality).
Attenuator for gain control - Simple 4 diodes attenuator IC. It's simpler and works better because it's wideband (previously three circuits with distributed elements).
Amplifiers - 2-3.5GHz and 4-7GHz amplifiers are similar. I used some resistive matching to avoid bad SWR which was a problem in previous design. In my previous design lossless components were used for matching so in order to reduce gain at lower frequency (to get flat gain over frequency) a lot of power had to be reflected. In the rev2 design the power at lower frequencies is mostly dissipated in resistors (kind of a simple non-reflection filter at the input). I had too much gain before frequency doubler so I added attenuator and not enough gain after the doubler so I've cut a hole in PCB and inserted 4th gain block.
Frequency doubler - It's a wideband doubler, based on marchand balun. It was quite a fun to make an useful balun on poor man's substrate, this part mostly forced substrate thickness for the whole design. Details in documentation. Insertion loss is about 10-15dB which is sufficiently good for me, considering simplicity and price.
Switches for filters - The first design in rev2 was very good in simulations but totally useless in real life (parasitics...). I made a simpler switches to reduce insertion losses (cut the old from PCB and replaced with a new one on self made PCB). The best solution would be to use a real, integrated circuit switch instead of building it from diodes (7GHz is too much).
Filters - Only small adjustments, mostly the same as rev1.
Added low pass filter at the output - not sure if it helps or not (may be even harmful because of high losses @7GHz, @FR-4
PLL and ALC similar to rev1.
Unfortunately I've not much possibilities of measurements above 6GHz (up to 6GHz I use arinst-ssa, although it has undefined performance above 3GHz), also measurements in the circuit (without cutting out a measured block or making a new copy) are inaccurate (SWR of connections matters a lot) so I'm highly uncertain about performance of particular circuits. The whole synthesizer provides about 7dBm max over the 4-7GHz range, if I can trust a 20$ power meter (I can't actually...).
I closed the level-control loop and the PLL. After a few more small changes it works.
I skipped the second part of output amplifier (was unstable) and the first part seems to work good enough. I also skipped amplifiers after VCOs and added attenuator after 2-2.5GHz pin attenuator (too much gain). Variable attenuators were too sensitive to tuning voltage (at certain frequency and tuning voltage) so I introduced some imbalance as workaround. Other changes are listed in changes_rev1 text file in the project zip.
Recently I had chance to access a good spectrum analyzer for a while so I checked the results. The output signal looks bad (spurs, jitter), partially (mostly?) because I didn't even shield anything. Also I'm not 100% sure if everything is stable and not overdriven. The main tone is about 12dBm, it drops to about 8dBm close to 7GHz but in the remaining part of frequency range the output level is surprisingly flat (maybe about 2dB flatness below 6.7GHz). See the video in "files" (note 10dB attenuator was installed).
1. VCOs - they work (after some tuning, and replacing one transistor)
2. Amplifiers (2-3.5GHz in three ranges) - they are ok, VCOs output signal is higher than expected so maybe I need one instead of two amplifiers or I must add some attenuators
3. Atternuators - they work, attenuation range about 10dB (not much but close enough to simulations)
4. Doublers - they work (2nd harmonic much above the input), no accurate measurements done yet
5. PIN switch - it does something but I can't test it separately with the current PCB layout (maybe I'll attempt it later)
6. Filters - the lowest band looks fine, it's hard to test the others (measurements errors can be bad at so high frequency and currently I can't go above 6GHz)
7. Output amplifier first part (3 stage) - not good, hard to test, seems to be unstable but possibly the problem is caused by test setup (depending of arrangement of coax cables connected to PCB it oscillates or not); possibly it can be useable after some tuning
8. Output amplifier the second part (2 way) - part1+part2 output amplifier is much more unstable than the first part only so I'll skip the two-way amplifier for now; it's bad because of huge out of band gain, especially about 2GHz where it usually oscillates.
So the plan for now is to put all together, without the final amplifier.
The PCB has arrived, now the prototype is mostly assembled.
The fist impressions:
- I checked one VCO and seems that it works surprisingly well
- I also checked one 3-3.5GHz amplifier - it's fine
- The wideband 4-7GHz seems to be fail. First of all it's unstable. Also it's quite difficult to make any meaningful measurements, even with a good VNA (I had chance to use it for a few days) - U.FL connectors are quite bad even at their specified 6GHz and currently I can't test the two stages of the amplifier separately because I don't have connector between them. The problems are likely caused by radial stubs which may couple to each other and also diverge from simulation.
I hope to make more measurements soon.
The main challenge will be to fix the 4-7GHz amplifier (at least up to 4-6GHz where I can currently measure it). The worst case will be to replace it with integrated gain blocks but they are noisy, expensive and boring.
The design of the first version is finished and I'm waiting for PCBs.
I expect that not all the circuits will work as intended and most of them will require some tuning. On the other hand I'm pretty sure I'll be able to make them to work because I did a lot of simulations and also some experiments. I tested some of the used (or similar) circuits, mostly using cheap Arinst SSA-TG spectrum analyzer (up to ~6GHz) and it looks like the simulations really help to roughly estimate how the real world hardware will work. Not all the parts were tested so problems may arise, especially at the highest frequencies.
To be continued...
Design and reports are attached (as zip file) in "Files" section.
By using our website and services, you expressly agree to the placement of our performance, functionality, and advertising cookies.
Learn More
