AVR ISP Pogo adapter
I was annoyed to always have to solder a 6pin connector to my boards to use my ISP programmer. So made an adapter with Pogo pins.
This is a little adapter to make programming Atmel MCUs easier.
A little tool to simplify programming AVRs using the ISP. I wanted to be able to program my Atmel MCUs without always having to solder a 6pin male connector to my boards. To ensure proper contacting all 6 contacts I decided to go for pogo pins. This little adapter is stable and I don't have to waste a connector on each board and I do not need to provide space for the connector in a housing either.
  • 1 × 6pin male ISP connector
  • 2 × small pieces of perfboard
  • 6 × pogo pins
  • 2 × 3pin headers
  • Putting everything together
    MaBe42 • 12/18/2019 at 22:14 • 0 comments
    I soldered the pogo pins to one of the perfboards.
    The typical ISP connector (6-pin male) I soldered to a second perfboard.
    On the opposite side of the second perfboard I soldered the two 3pin pin headers. They do not have any electrical function. They just provide mechanical stability.
    Then I soldered the ends of the pogo pins to the ends of the pins of the ISP connector (kind of a butt coupling).
    Finally I soldered the stabilizing pin headers also to the first board and cut away a small piece of the board near the ISP connector to mark pin 1.
View project log
Christoph Tack wrote 05/05/2020 at 20:21 • point
I put a 490107670612 SKEDD connector on a flat cable.  I don't have to hold it still while programming.  I don't have to check the orientation of the connector when programming.  It doesn't require a mating connector on the PCB.
