Thermal Images
12/19/2019 at 07:35 • 0 commentsHere is some images of thermal camera.
a thermal image of a hand:
a thermal image of a cup filled with warm water:
a thermal image of a girl:
a thermal image of a man:
a thermal image of a running computer screen。
The distance is about 1 meter. At different distances, in order to make the measured temperature accurate, you need to adjust the thermal imaging settings, such as reflectance, etc.
Camera Description
12/19/2019 at 06:59 • 0 commentsHardware:
STM32F407xx 700 mAh Battery TP4056 charger chip MLX90640 thermal chip ...
Functions:
1 Thermal imaging of objects 2 Take photos and save them in BMP format 3 Virtual U disk function, can be connected to a computer 4 Data serial port sending function, real-time display of thermal imaging on the computer 5 Low power automatic shutdown 6 Can set thermal imaging parameters such as reflectance, color, temperature range, time, etc. 7 With WIN operating system desktop software, can analyze thermal imaging data
SaberOnGo
