Green inchdigits for a change
10/08/2026 at 09:55 • 0 comments![]()
I had a couple of boards left over so about a year ago I ordered a batch of green inch high 7-segment displays to use up the boards and have a change from the boring red displays. They both have the same pinout. They duly arrived and I made up one board. But you know the familiar story, it didn't work when first powered up. I tried a few things then put it aside in frustration.
Last week, with more time on my hands, I decided to debug it once and for all. I connected it to an Uno and fired up my digit scrolling sketch which appears to shift digits to the left at 2 Hz (but of course it's actually periodically incrementing every digit by 1). Using a Hantek USB scope which I hadn't unpacked for a long time (another sad and familiar story) and the OpenHantek program, I found that the waveform on the clock line was high all the time except bursts of low going pulses at 2 Hz. On the data line, the bursts were absent but there was a large dip of the level at 2 Hz. Here is the part of the circuit:
Since there weren't any multiplexing waveforms on the digit or segment lines, I decided that the TM1637 IC was faulty and decided to replace it. So I used the hot air gun to desolder it and then soldered in a new TM1637. Hah! Same fault. This time I figured that the only possiblity left was C4 being too high in value and obliterating the pulse train. Without the initialisation commands the IC probably didn't start multiplexing. C4 with R4 form a simple noise filter, so I desoldered C4, and the circuit starting working. So I replaced C4 with a new 100 pF capacitor. What happened? Who knows, maybe I picked up the wrong SMD component. Unlike SMD resistors, SMD capacitors have no value markings. I'll have to be careful to use the correct tape in future.
I put the extracted IC on the remaining board and that worked too. So now I have two more working displays.
Inchdigits reloaded
11/14/2022 at 22:30 • 0 comments![]()
The original board works exactly as desired. This is not surprising as the circuit has been well tested by the many cheap displays using the same chip but have smaller digits. Even the higher forward voltage of 2 diode junctions per segment was taken care of by the TM1637 chip.
However I made a mistake, I put buttons on the PCB. I thought it would be an advantage, being able to use the TM1637 not just as an output device, but also as an input device. But the size limited the places I could use the board. I was too eager to use as much of the 100x100 limit for cheap boards as I could.
So I redid the board to hold the display only and no larger. I was not ready to lose the input capability, so I brought a subset of the input lines to a connector. With 4 segment lines and 2 keyboard lines, 8 buttons can be deployed, which should suffice for most purposes.
The design files are in a new Github repository. As with the first design it is a swap in replacement for the cheaper smaller displays, even the order of the power and signal lines in the connector is the same.
Ken Yap
