SMART Response XE BASIC
Turn a SMART Response XE terminal into an 80's flavour pocket computer
I am trying recreating a small pocket computer like the Canon X-07 I owned long ago and was very fan of.
I have seen the Smart Response XE Reverse Engineering project a few month ago and found that terminal of some interest. I then bought a couple of them on Ebay and started playing with. I first recreated the schematic of the board. I am now realizing the adaptation of a BASIC interpreter to make the terminal a small pocket computer. I am trying recreating a small pocket computer like the Canon X-07  I owned long ago and was very fan of.
Smart_Response_XE.pdf
Schematic of the SMART Response XE terminal. Result of some reverse engineering on one of my terminal. I can't be 100% sure that there are no errors.
Adobe Portable Document Format - 188.40 kB - 01/04/2020 at 17:01
Preview
  • Just a little update
    fdufnews07/30/2021 at 14:31 0 comments
    Current state
    I have added two new statements
    PEEK(address) returns the content of memory cell at address
    POKE(address, value) write value in memory cell at address
    PEEK and POKE mainly help playing with the registers.
    Added a scrolling buffer which ease displaying DIR and LIST screen by screen.
    Work in progress
    Currently, I am working on adding file manipulation inside BASIC programs.
    I plan to add statements like open, read, write (binary and text)
  • You can save your program now
    fdufnews08/07/2020 at 20:04 1 comment
    I have just commited the updated software to my github.
    The save/load/delete/dir functions are working like a charm. There is only one limitation no subdirectories allowed. I have made some tests with subdirectories but dir was always crashing. Regarding the application, I think it is of little importance.
    I have adapted the already existing functions that were written for an external EEPROM
    So:
    SAVE "MYPROG.BAS, creates a file MYPROG.BAS  containing a dump of the basic program space.
    LOAD  "MYPROG.BAS", loads the file MYPROG.BAS in memory and it can be executed
    DIR, displays card content on the screen
    DELETE "MYPROG.BAS", does what it means.
    I have added two new functions
    UNMOUNT, close the SD card and frees the memory in order to eject the card
    MOUNT, open the card and keep it ready for use
    MOUNT is automatic after a reset and when recovering from SLEEP
    UNMOUNT is automatic before entering SLEEP
    So the card can be extracted while the terminal is sleeping and the card recognized at wake up.
    The status line has been slightly modified in order to display the status of the SD card.
    The card reader is incorporated into the terminal.
    The inside of the terminal is now a big mess of wires
    Edit: Made a little modification. As I want to add some statement to use data files I have added support for the extension to the filename. Now .BAS shall be added to save, load and delete.
  • The SD card finally wins the challenge
    fdufnews07/29/2020 at 12:06 0 comments
    It took long as I was balancing from one solution to the other.
    The incorporated Flash was small and difficult to manage as it was needing a large buffer in RAM but it had the advantage of being already inside the terminal
    On the other end the SD card was large enough to store many files, the block allocation and wear leveling was managed by the card itself but the terminal needed to be modified.
    I finally choose the SD card. It has another advantage, the card can be extracted from the terminal and the files can be saved and edited on any computer which is great I think.
    I have made some modification in the terrminal:
    • desolder the Flash
    • Connected a SD card reader
    • Made some read/write tests
    It works very well.
    I am currently working on the software side implementing the SAVE and LOAD command. This commands are already implemented for an external I2C EEPROM. I am looking at keeping the same syntax to make the interface media independant.
    The card reader is currently connected with flying wires. The next step will be mechanical modification in order to seamlessly integrate the reader on one side of the terminal.
  • Project is not dead
    fdufnews04/21/2020 at 06:26 0 comments
    Project is not dead but I currently have no satisfying solution concerning the file system. Also, with COVID-19, I am confined at home and take that time doing some work on my house.
    I have also considered replacing the flash inside the terminal with an SD card reader. It has some advantage the card handle the problem of allocating the blocks and the wear leveling, The SD card can also be extracted from the terminal and the files read or edited on any computer.
    Apart from that, I have noticed that the standby mode is really efficient. My terminal is in stanby for months now (I think since mid of february) on a pack of NiMh batteries and I power it on from time to  time to look at the battery level. The batteries are slowly draining out but the terminal is still functionnal.
    To be continued......
  • Just a quick update
    fdufnews02/02/2020 at 18:23 0 comments
    Well no great progress this time.
    The main progress was on the status line. Previously there was a problem with the voltage of the battery now fixed with small modification in the initialization of the ADC.
    The way status is managed has evolved. Previously, status was updated in the loop() function but the status line was not updated sometimes. I have moved the call to printStatus function in the functions that are reading the keyboard in host.cpp. In host_readLine, that is used for the command line and in host_ESCkeyPressed that is used during execution so now informations are also updated while the program is running. But in order to not slow down the software too much the status line is only updated every 2 seconds.
    I have also corrected the function that compute BASIC memory usage. Previously, memory used by variables was not taken into account.
    As usual, the code is on my github.
    Next step will be saving and loading programs into the Flash memory of the terminal.
    Edit: just found a bug in genbitmapRLE.py. The array size, in the generated file, was wrong, it was still the size of the bitmap not the one of the compressed file.  The size of the firmware has suddenly lost 10kB.
  • Story of a whim (and a splashscreen)
    fdufnews01/11/2020 at 22:27 0 comments
    The whim
    When I received my terminals, I first powered them to see if they were operational. I liked the terminal startup screen and found it really attractive. There was a little picture of the terminal in level of gray.
    So today I decided there was no reason why my terminal didn't have one.
    The Problem
    The problem is that a bitmap the size of the display is quite a large amount of bytes.
    I first reproduced the bitmap of the original startup screen with GIMP. And, of course, found the file really large.
    To simplify the software in the Arduino the picture was coded 3 pixels in a byte as the display expected it. The file was still large.
    The solution
    The second step was to find a way to compress the file in a way that allows it to be displayed with the limited power of the Arduino while significantly reducing the size of the file. For this I decided to choose an RLE compression. This type of compression is easy to program and it does not require a large buffer because decompression can be performed on the fly. To simplify data handling, the length of a run was limited to 254 bytes so the length can be stored on a single byte.
    The file is a succession of bytes coding the size and the value each on a byte.
    In order for the software to handle any size of picture, the width and the height of the picture are added at the beginning of the file.
    // Original file LogoSMART2.data
    #include <avr/pgmspace.h>
    const uint8_t bitmap_logo2_rle[384/3*136+4+1] PROGMEM ={
        0x80, 0x01, // image width=384
        0x88, 0x00, // image height=136
        0X82,0x00,0X23,0xff,0X5C,0x00,0X01,0x1f,0X22,0x00,0X01,0x03,0X01,0xe0,0X5B,0x00,
        0X01,0xe0,0X01,0x09,0X21,0x49,0X01,0x40,0X01,0x1f,0X5A,0x00,0X01,0x1f,0X01,0x01,
        0XFE,0x00,0XFE,0x00,0XF3,0x00,0X00,0x00
    As a remainder, the name of the original picture is inserted as a comment in the header
    The array is named bitmap_+<name of the output file>.
    The first four bytes of the array are the size of the picture
    Following are pairs of size, value, size, value as explained before.
    The file ends with a pair of 00.
    The tools
    I have written a short python script to convert a picture in RAW format into a .h file that can be compiled with the software.
    Here are the steps to generate the file:
    1. Create the picture with GIMP using only 4 colors
    2. Convert it to indexed palette
    3. Export to RAW (.data). Two files are generated image.data, image.data.pal (the second is of no use, it can be discarded)
    4. Using the python script a image.h file is generated
    The syntaxe of the script is:
    python genbitmapRLE.py <image.data> <image.h> <width> <height>
    image.data : name of the picture in RAW format
    image.h      : name of the generated .h file
    width          : width of the picture (see note)
    height        : height of the picture (see note)
    Note : as RAW files does not contain any information on the geometry of the picture it is necessary to add it by hand.
    The result
    The source picture is 384 x 136 pixels in 4 level of gray.
    After encoding in "display format" the file is 384 x 136 / 3 = 17408 bytes large
    After RLE compression the file is 7164 bytes large. This is still quite a large number of data but the ATmega128RFA1 has 128kB of flash so there is currently no problem.
    This solution is quite efficient. The full screen picture is displayed in a fraction of a second (I have not made any measure, maybe I will do it one day)
  • First modifications to BASIC
    fdufnews01/06/2020 at 16:03 0 comments
    Adapting Arduino BASIC to the SMART Response XE terminal was quite easy as the interface was  limited to a pair of functions that were easy to replace with the ones in the Low Level Library.
    But the display is not that large and the limitation imposed by its graphic controler lead to some problems. The contraint is that font width shall be multiple of 3. You can have small fonts that give many lines with many characters difficult to read (for my eyes at least) or large fonts that are easy to read but with less lines with less characters. It made me want to be able to change the font at any moment.. The low level library alreay defines 4 fonts
    Font
    name
    Font
    size
    # of char
    per line
    # of lines
    per frame
    Comment
    NORMAL9 x 84217fill screen
    SMALL
    6 x
    6417fill screen
    MEDIUM12 x 163288 unused lines
    LARGE15 x 162588 unused lines
    As the larger fonts leave 8 lines I decided to do the same for the smaller ones. The 8 unused lines will be used to display some information on screen.
    The cpp file in which the interface with the host is defined was upgraded in order to be able to change the font on the fly. I first defined a structure that holds parameters depending on the font size. And replaced all the constants with members of the structure.
    The terminal has some "special" keys. I used the menu one to launch a function with which I can change the font.
    The 8 unused lines are located at the bottom of the screen. They display the status of the terminal. Actually, battery level, font used and memory usage.
  • Terminal modifications
    fdufnews01/05/2020 at 09:43 0 comments
    In order to have a little more interaction with the terminal, I used provisions that had been planned in the terminal by the designers.
    • adding a piezo speaker, the designers have made provision for a piezo speaker in the terminal. There is room for some resistors, a transistor and a piezo speaker
    • adding an LED, there is also room for an LED and an optional transistor.
    These modifications are described on my github in the hack directory
    Concerning the BASIC language, there is already support for note generation and BASIC gives access to the I/O with the PIN statement. You can easily make your BASIC programs blink and beep as you wish.
    The LED is located on the top side so it can be seen from the front face and its legs are folded back in order to connect to the pads on the components side
    The front face is drilled but the hole does not open on the front face. The black coating of the film that makes the front face is scratch from the inside so the LED can be viewed. By doing so you don't have to perfectly align the LED position with the front hole.
    I have also added an extension connector in order to have access to some signals
    The left part of the top row is compliant with the FTDI download cable pinout.
  • The starting point
    fdufnews01/04/2020 at 16:39 0 comments
    Some words on the hardware used
    The SMART Response XE terminal was designed years ago as an interactive terminal used in colleges. It is now a bit obsolete and can be purchased on Ebay for a tenth of its original price. For a few dollars you have a keyboard, a screen, and a ATmega128RFA1 processeur (an ATmega128 with wireless interface). The processor has 128kB of program Flash, 16kB of RAM and 4kB of EEPROM. The terminal integrates also a serial Flash that can be used too. As it is an ATmega, with minimum work, the software can be designed in the Arduino IDE giving access to all the existing softwares and libraries that were developed in the Arduino ecosystem.
    I have bought 2 terminals and opened one to reverse engineer the schematic with the help of some hires pictures found here.
    Some words on the softwares I rely on
    The library I use is based on bitbank2 work. He has made a library that handles all the low level of the SMART Response XE Terminal. It manage the keyboard, the display. Some word on the display. It is probably the weakest link in this system, it has a good resolution but two drawbacks.
    • pixels are written three at a time
    • it is not possible to read back the frame memory
    These two limitations prevent from making elaborate drawing as when setting a pixel you can modify two others.
    These limitations are the reason why I will first work on text interface only for the BASIC.
    The BASIC I will use is based on Robin Hedwards work. He has made an Arduino BASIC that works well and it needs not too much adaptation to work with the terminal.
View all 9 project logs
Chris S wrote 11/18/2024 at 09:11 point
Hi, so is it just direct connection of the U2's pins with any SD/uSD interface that is around ? thx
fdufnews wrote 11/18/2024 at 13:24 point
Exactly. More details here
https://github.com/fdufnews/SMART-Response-XE-schematics/tree/master/hack
don.vukovic wrote 01/08/2020 at 19:21 point
Is there enough Flash memory available to get the RF working with Basic ?
fdufnews wrote 01/09/2020 at 07:44 point
Sure. Basic is currently using around 30kB. I am not too much interested with the RF part that's why there are no information on it.
Bitbank2 who has made the low level Library I am using has also written a bootloader with OTA update using the RF block maybe you can find information here https://github.com/bitbank2/SMART_bootloader or on his blog http://bitbanksoftware.blogspot.com/2018/09/my-adventures-in-writing-ota-bootloader.html
fdufnews wrote 02/03/2020 at 14:00 point
Found that https://github.com/Marzogh/ATmega128RFA1 it may interest you
ptrav wrote 01/05/2020 at 22:50 point
Well, Arduino BASIC is not a bad option for such a small memory footprint. Terminal BASIC is quite heavy for 16kB of RAM.
How is the keyboard quality on these devices? Is it a silicone membrane with plastic buttons on the top? Is there a positive tactile feedback, or it is more like a remote control? Would that be possible to post some pictures/comments?
I wanted to try one, but shipping a device from the US is twice as expensive as the device itself.
fdufnews wrote 01/06/2020 at 08:37 point
The keyboard quality is good. It was designed to be used by students so it was necessary to have a "rugged" design. The plastic of the case is very thick and makes it a sturdy product but it still keeps a very pleasant contact in the hand
The keyboard is based on metal dome with plastic keys. You can see 5 of the domes on the picture showing the position of the LED on the top of the PCB. There is a positive feedback, by pressing the keys you feel a slight mechanical resistance with a gentle click.
Concerning the price, shipping is actually a bit expensive. It is more interesting buying 10 terminals than one (but you don't always need 10).
fdufnews wrote 01/09/2020 at 07:36 point
Here is a link to a document with pictures of the terminal
https://fccid.io/QCISRP03/Internal-Photos/Internal-Photo-1334882.pdf
ptrav wrote 01/05/2020 at 10:36 point
Nice project! You may want to check: https://hackaday.io/project/164645-terminal-basic-programmable-calculator
What is the screen resolution and how do you source your LCD?
fdufnews wrote 01/05/2020 at 11:36 point
Thanks for your interest.
The screen resolution is 384x136. The screen is part of the terminal no need to source anything apart from the terminal itself. Search SMART Response XE on Ebay and you will understand.
Concerning the project you gave a link to, I am already following it but I have not found any source of the BASIC I can adapt to the platform I am using. To be more precise, I don't have a lot of time to devote to this project and I found the setting up of the development chain a little complicated (especially since I don't really want to install Netbeans)
