« Back to project details
Reading the SD card
04/06/2020 at 05:13 • 0 commentsWith the aid of a logic analyzer I Have found that the chip select signal was coming from another pin than the expected.
Now the SD card is working.
First boot
01/04/2020 at 16:30 • 0 commentsIt took me a long run to adapt the code, but I could finally boot in on the Blue Pill.
Steps involed:- Download and install STM32 duino
- Include directives for every hardware dependent instruction (same code can still be compiled to Mega328 based Arduino)
- Fiddle with one configuration defitinion for SDFat library
- Adapt the code to compile for newer PCD8455 display library
