Product Specifications
General
Type: GPS Module
Architecture: For Arduino
Default Communication Baud Rate: 9600 bauds (can be modified via software)
Output Frequency: 1Hz (can be modified via software)
External Antenna Interface: SMA
Communication Interface: USB and TTL
Power
Operating Voltage: +3.3 - +5 volts
Operating Current: 40mA
Weight and Size Dimensions
Product Weight: 17g
Product Size (L x W x H): 5.3 x 2.53 x 14.3 cm
Pinout
VCC - Input Voltage (+)
GND - GND (-)
TXD - Data Transmit
RXD - Data Receive
PPS - Clock Pulse Output
Product Review
After testing and taking a look at this Ublox GPS Module, I have found out that this product exhibits many great factors including:
1. The accurate and detailed positioning data given by this GPS module for: tracking, finding out your exact location, satellite communication, etc..
2. The small and compact size of this module so that it could be used in multiple portable projects and cases.
3. The simple software and programming included with this product in order to get the maximum capabilities and functions.
Even though this product can receive satellite signals to get your exact position, it requires a wide, open space to be used in; where there are no obstructions in the way because it could cause a blockage in the communication, thus, not giving you any data at all. Additionally, I highly recommend any external antenna (SMA interface) for a better signal communication when you are blocked by certain objects or buildings. It isn't necessary to this module's operations but it will be a big advantage to you if you have one.
Ublox Neo-7N GPS Module Sample Code
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
static const int RXPin = 4, TXPin = 3;
static const uint32_t GPSBaud = 4800;
TinyGPSPlus gps;
SoftwareSerial ss(RXPin, TXPin);
void setup()
Serial.begin(115200);
ss.begin(GPSBaud);
Serial.println(F("Ublox Neo-7N GPS Module Test"));
Serial.println();
void loop()
while (ss.available() > 0)
if (gps.encode(ss.read()))
displayInfo();
if (millis() > 5000 && gps.charsProcessed() < 10)
Serial.println(F("No GPS detected: check wiring."));
while(true);
void displayInfo()
Serial.print(F("Location: "));
if (gps.location.isValid())
Serial.print(gps.location.lat(), 6);
Serial.print(F(","));
Serial.print(gps.location.lng(), 6);
else
Serial.print(F("INVALID"));
Serial.print(F(" Date/Time: "));
if (gps.date.isValid())
Serial.print(gps.date.month());
Serial.print(F("/"));
Serial.print(gps.date.day());
Serial.print(gps.date.year());
else
Serial.print(F(" "));
if (gps.time.isValid())
if (gps.time.hour() < 10) Serial.print(F("0"));
Serial.print(gps.time.hour());
Serial.print(F(":"));
if (gps.time.minute() < 10) Serial.print(F("0"));
Serial.print(gps.time.minute());
if (gps.time.second() < 10) Serial.print(F("0"));
Serial.print(gps.time.second());
Serial.print(F("."));
if (gps.time.centisecond() < 10) Serial.print(F("0"));
Serial.print(gps.time.centisecond());
else
Serial.println();
}Banggood Product Page
Check out the product here: https://goo.gl/YLzeszAmazing opportunities
Also, be sure to check out PCBWay, a leading manufacturer and distributor in PCB design and manufacturing. They have amazing prices and excellent quality in their services, so don't miss out on them! Plus, PCBWay has an amazing website, online Gerber viewer function and a gift shop so make sure to check out their links below:
PCBWay Free Online Gerber Viewer Function: https://www.pcbway.com/project/OnlineGerberViewer.html
PCBWay Gift Shop: https://www.pcbway.com/projects/gifts.html
Be sure to check out the Arduino Ublox Neo-7N GPS Module Project by clicking here.
Enjoy! Contact us for any inquiries!
R. Scott Coppersmith
Dilshan Jayakody
