Wiring goggles
01/23/2020 at 14:34 • 0 commentsRemoved the circuit board, soldered wires directly onto the LCD contacts.
Applying 3V from the coin cell that came with the goggles darkens them, but they 'fade' back to visible quite slowly. I might have to short them together to get this to happen quicker so I can use the sort of 'invisible' frame rates I will need
3D Active goggles
01/23/2020 at 14:32 • 0 commentsBought some Active 3D goggles. Went for Toshiba branded as I thought they might be a bit more robust - wrong!
