Latest Electronics Update
03/16/2020 at 22:42 • 0 commentsI think I have the power issue figured out and a few other problems that crept in.
Heat: If the motor runs at 5v, it does get hot. I added a 6Amp dropping diode in series with the 5V so now it runs on 4.3V which is about equivalent to a charged 1S battery.
I also discovered some of the motors I ordered were the same size physically but didnt' have any power at 5v. Those needed 7.4v (2S battery size) so if you order those motors, you can use this supply and just dial it to run all the electronics with 7.4Vdc. Use Vin on the arduino and it will step that down to 5V.
It's not UL rated :( so don't use this one, but find something similar....
https://www.amazon.com/gp/product/B07R4NK3D1/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1
Here are the updated parts I used on the latest Coast Guard Rescue ship:
Hobbypower Rc 10a Brushed ESC Motor Speed Controller 1/16 18 24 Car Boat Tank W/o Brake(Pack of 2 Pcs)
https://www.amazon.com/gp/product/B00JXI3H6Y/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
SHNITPWR 5V 8A 40W Power Supply Adapter AC/DC Converter 100V~240V AC to DC 5 Volts 8 Amps Transformer with 5.5x2.5mm DC Tip for WS2812B WS2813 LED Pixel Strip TV Box USB HUB Raspberry Pi Arduino
https://www.amazon.com/gp/product/B07RJPV36C/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1
ELEGOO for Arduino Nano V3.0, Nano Board CH340/ATmega328P Without USB Cable, Compatible with Arduino Nano V3.0 (Nano x 3 Without Cable)
https://www.amazon.com/gp/product/B0713XK923/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
diymore 5pcs Nano Expansion Prototype Shield I/O Extension Board Module for Arduino Nano V3.0
https://www.amazon.com/gp/product/B07BLX9RHJ/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
I will post a schematic soon...
Coast Guard Rescue Trailer :)
03/16/2020 at 04:58 • 0 commentsI have the CG VB flying nicely now. I had to add an ESC (thing RC airplane) and a diode to drop the voltage from 5 to 4.3V and it is flying very nicely now..... I will post schematics soon.
https://www.youtube.com/watch?v=cbXBGx_uQsQ
My 9 year old son did that trailer from our iPad :)
He is just loving any toy I 3D print from an old 70's design!
Power Issues
02/29/2020 at 20:58 • 0 commentsSo the little RC motors are drawing more current than I expected. I have a 5Amp 5Volt supply and now the speed controller IC is shutting down during flight. I have some RC speed controllers on order and will be installing those and then I'll post the code to run the Vertibird.
https://www.amazon.com/gp/product/B07L2T6MHB/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
The Ship is done and once the powe issue is solved, I will post a video.
Coast Guard Rescue moving forward
02/17/2020 at 15:41 • 0 commentsI have the Coast Guard ship printed and will have it all put together this week....
