Check out the new trailer done by my 9 year old son Jonah :)
https://www.youtube.com/watch?v=cbXBGx_uQsQ
All the STL files for 3D printing can be found here:
https://www.thingiverse.com/thing:4147823
The Coast Guard Rescue Ship is also ready to print:
https://www.thingiverse.com/thing:4161609
Here is a video of the prototype:
Here is one of the final version flying:
https://www.youtube.com/watch?v=0eCAvSWgvUw
Closer View of Lift off:
https://www.youtube.com/watch?v=Nr07fGhRxoQ
To wire and build the pivoting dome, solder at least 18ga wire to 2 of the terminals on the male microphone plug. Then fill the hole with epoxy to assure the wires nor plug will twist out.
Here is a schematic that should work well....
Assemble the pivoting motor and audio jack as shown below. The latest STL files on Thingiverse are a little different than the prototype pictures shown here:
The spring helped with oscillations while flying.
Wire the controller potentiometer as shown below:
Use a rubber band to make the throttle handle on the left always move back to 0 speed if the handle is let go.
Wire the 2 pots to A0 for throttle and A1 for Forward/Reverse.
Put the helicopter motor together and glue the chopper together:
Start putting it all together...
Finished product.....
I am working on the next phase now. This is the one I had as a kid :)
Luke J. Barker
nerd.king
Jan Neumann
stefan.schnitzer
Hi Luke,
Not sure if you are still monitoring this but did you post the updated schematic and code for the enhanced version with the ESC?
Thanks and best wishes,
Peter
