hack some standard replacement batteries for my mobile laboratory
i did the cutouts in the housing
assembled the connector and secured it with hot glue
This is the PCB inside of the power bank adapter. There are 2 identical supplies for the USB ports. You clearly see the inductors of the buck converters.
I want to use the XT60 connector for my project because my solder station (TS100) has an adapter for the XT60 connector.
The distance between the solder points from the battery also fit very well to the pitch of the XT60 connector.
To connect to the battery pack they use a common connection plate and cables.
The next time we adapt the housing for the XT60 connector.
I ordered a Makita replacement battery and an power bank adapter for Makita batteries. It has two USB ports for charing your phone or tablet.
Next step is to disassemble this power bank adapter.
This is the nice one. I also know a website which cover smartphone and mobile related things. here is the website https://tagphone.pk/
First time i saw mobile phone related things there. They cover these type things mostly.
very nice project i like your thinking bro I am also working on a new project which is pretty similar to your one you can see my work here https://emobileaccessory.com/
I wasn’t aware of the power bank but found an adapter on thingiverse for makita batteries. I printed one but only take the battery voltage out. It works great.
Awesome! I've been contemplating something similar for the Miluakee M12 batteries.
Yes! An excellent hack of an existing enclosure. I've been impressed by the 3D-printed designs that allow batteries to clip in, but taking an existing housing and putting your own PCB inside is even better!
Great project! I admire your approach. I'm actually working on a similar project myself. You can check out my work here https://packmysim.com/
