Simple Monster Position using IR Sensors
04/01/2020 at 21:38 • 0 commentsI wanted to show you some basic field Monster position detection, for it I built a simple prototype using IR sensors. The code for detection can be found named "MonsterZoneDetection_IR". As you can see a transparent sheet serves as a place for the card to lay down and since IR light passes through this sheet it does not get detected as a card. When a card is placed on top of a sensor it gets triggered and outputs a digital high signal.
Alternative Version Demonstration
02/14/2020 at 04:37 • 1 commentThis alternative version of the Duel Disk uses buttons to detect card positions and zones. This makes the prototype much lighter and portable without compromising functionality.
Augusto
