A walking, talking, task performing - social robot.
Project 13 has been discontinued. The technology that was required to see this project come to life became extremely difficult to develop, and I see no reasonable way forward. Especially around the area of autonomous navigation around an indoor environment. I have taken a lot of the technology that showed up in Project 13 and transferred it over to Stronghold CMD. I will look to make use of the robot for Project 13 in Stronghold CMD. Wiping out the autonomous navigation for user controlled navigation. This is not so much a failure at the project so much as it is a re-invention of the project. So head over to Stronghold CMD in the projects section to see the progress that I have made. Enjoi!
I released the software for Project 13 which you can download and give a try on your own. Visit the Project Downloads section to the left to try it out yourself.
Download the latest release of the software from the Projects Downloads link on the left side of this project page.
Install the software to your Hard Drive.
Read the Project 13 - Installation and Setup.pdf to setup an instance of the program of your own and get started trying out Project 13.
This looks like a fun project.
Are you aware of the present effort (mainly by myself) to improve the Eddie firmware?
The "Open Propeller 8" was started in order to make the Eddie firmware compatible with the new Arlo hardware.
While my original intention was to just port the firmware to the new hardware, I decided I had made enough improvements to the firmware it was worth the effort to upgrade the firmware used with the older hardware.
IMO, I improved the way the Ping sensors are monitored. The original firmware triggered all the Pings at once which was likely to cause interference between the sensors. I modified this to continual monitor the sensors with a delay between each reading to allow the echo of the previous sensor to subside.
The "PING" command now is acted upon immediately by return the last readings from the sensors. So not only are the Ping results much more accurate, the readings are turned faster than when using the original firmware.
I also added an "ARC" command which allows the robot to travel in a curved path. The Eddie control board can also be used to control servos now.
I hope you check up the above link and give the new firmware a try. I don't have an Eddie board to test the firmware but I did test it with an h-bridge similar to the one used by the Eddie board.
Saabman
timetopretendshow803
A.L
Sounds like a good project Duane. Eventually I will want to move to Arlo hardware (or whatever is around at the time I upgrade) so this project would be very helpful in making that transition. But what I think is holding me back is the fact that there is no solution I have found to power the Kinect on the Eddie (control board or wires). If Parallax had a solution to that problem that would make my day.
I will keep your project in mind when I find some free time to give your firmware a go I'll let you know how it turns out.
