This is a custom Minecraft PE server based on Nukkit.
MinecraftOS 0.2 (release date 2/27/20). A super easy Minecraft PE server!
Version 0.2 released!
View project log
Here are the files: MinecraftOS, Etcher, and sdcardformatter
Steps:
1. Install and run the programs
2. Start the programs.
3. In sd card formatter choose your drive and click format.
4. Exit the program.
5. Once in Etcher, insert your sd card, then click the select image button.
6. Find and double click MinecraftOS.img
7. Insure you have the correct drive selected, unless you want your other drives wiped.
8. Click FLASH!!!
9. Accept the administrator prompt.
10. Leave your computer alone for a while.
11. Pull out the sd card.
Make sure the C: drive is never selected. If it is, it can ruin your pc. Also, never eject or remove your drive while it is flashing.
Simple! Plug in Ethernet and power!
View all 5 instructions
Enjoy!!
Thaddaeus
Dennis Siegel
ziggurat29
Yann Guidon / YGDES
Yes, delete it Cancel
You are about to report the project "Super Easy Minecraft PE Server", please tell us the reason.
Enjoy!!
