teensymoog- modwheel.pdf
Adobe Portable Document Format -
73.21 kB -
03/31/2020 at 22:24
Preview
teensymoog - front panel.pdf
79.73 kB -
03/31/2020 at 20:07
Preview
teensymoog - body - layer 2.pdf
69.47 kB -
03/31/2020 at 20:07
Preview
teensymoog - body - layer 1.pdf
69.11 kB -
03/31/2020 at 20:07
Preview
teensymoog - side panel.pdf
58.28 kB -
03/31/2020 at 20:07
Preview
minimoog - facade.svg
The face plate with all markings, functions, holes for pots and switches.
svg+xml -
204.16 kB -
03/20/2020 at 14:00
Preview
minimoog - panneau lateral.svg
The lateral plate with LFO, pitchbend and mod wheel. Hot-bent.
svg+xml -
57.65 kB -
03/20/2020 at 14:00
Preview
minimoog - capot arrière inferieur.svg
The panel that hides the inside and on which plugs are mounted. Hot bent.
svg+xml -
37.50 kB -
03/20/2020 at 14:00
Preview
minimoog - capot arrière supérieur.svg
The rear side of the front panel.
svg+xml -
5.29 kB -
03/20/2020 at 14:00
Preview
