Build a COVID-19 shield with a device that estimates skin temperature and indicates if a person might have a fever.
preview.gifPreview of the animated screenGraphics Interchange Format - 1.87 MB - 03/28/2020 at 13:20 |
Solder the pins to the breakout board of the thermal sensor. Connect the 5 pins of the thermal sensor to the first 5 pins of the GPIO on the Raspberry Pi:
Screw the display to the Raspberry Pi and connect the HDMI ports with the bridge plug that came with the display.
Create a nice case to hold everything in place :)
The software has been written en tested on Raspbian Buster.
Go to the GitHub page and follow the instructions in the README file. It gives a detailed description on how to compile and install the software.
I'm making one for my wife with an interlock on her side of the blanket....
I know there are days when my face feels hot and flushed, typically when I have allergy symptoms. I wonder what surface temperature I'd be showing on days like that.
There are some very useful and interesting things I read in this post very similar to Vanity Medical spa as you can see here.
