It works!
12/19/2020 at 01:03 • 0 commentsA NodeMCU (ESP8266) paired with a DRV8833 Dual MOSFET H-Bridge comfortably drives the DC motor
This is the last iteration of the motor mount / enclosure:
Back from the shelf
10/30/2020 at 18:51 • 0 commentsAfter some time abandoned, the lock had the pulley installed but no motor. I just finished the enclosure for the motor, ready to 3d-print!
3D Printed adapter
04/04/2020 at 23:52 • 0 commentsWhen I was testing the idea, I thought I could use the original cylinder with the key in it, like on the retrofit kits. I got to learn the hard way that a pin tumbler lock does not operate well under the axial load of a belt. Nuki and other systems that work with the original key are mounted on top of the lock and avoid this, but I wanted to keep the contraption as flat as possible, since this is a rim lock and it's already bulky.
I then partially copied the lock in CAD, on top of which I designed a mounting plate to fit two small bearings and support the short axle for the belt pulley and actuating cam.
Got this printed this with PETG (because it turned out that's what my brother had in the printer at the moment). Feels really solid, especially when assembled. The bearings press-fit nicely, lucky me.
Latch action from the inside
04/02/2020 at 01:01 • 0 commentsThis lock does not actuate the latch from the inside, it makes no sense since it has a dedicated plunger for that. After considering actuating the plunger electrically, I decided it was easier to modify the internal latch mechanism to operate from the inside in the same way it operates from the outside.
I riveted a screw into this lever arm so it is reachable by the inner side cam. The lever is normally only operated by the front side cam, not on the picture. Both inner and outer lock cylinders are coaxial.
The rivet gets pushed by the cam on the inside side cylinder. The original pin tumbler cylinder is behind that cam wheel with the two screws on (only one visible) -
Designing 3D-Printed the motor box
04/01/2020 at 18:45 • 0 commentsI am now in the process of designing and printing a motor mount/box and associated electronics.
Ivan Stepaniuk
