This is door is pretty much the only reasonable way I can get into my house, so some extra precautions will be needed to avoid accidentally locking myself out. This can happen if the inner side cam is in a position that does not let the mechanism move freely.
Conversely, I also wanna be able to get out quickly if something goes wrong. The manual latch keeps working, and the pulley can be easily twisted by hand to move the bolt. I want to keep that "feature", so I hope it will still be possible once the motor box is mounted and the belt under the required tension.
Ivan Stepaniuk
kmatch98
Otto Gloeckner
MasterOfNull
