Distance measurements with Sonar sensor
04/08/2020 at 18:45 • 0 commentsIt is a bit of a challenge to get accurate distance readings with sonic sensors. Sonic sensors report stable readings when faced a flat surface and there is no obstacles between sonic sensors and a target. The following image shows distance readings to a wall. Both sensors read 27" distance:
Once I turn sensors away from the wall I get:
Debugging the source code for a public release
04/08/2020 at 03:36 • 0 commentsI have a few issues with the source code. As soon as I get a stable version, the code will be uploaded to the github.
Roman
