200407 - 3dPrint process
04/07/2020 at 16:46 • 0 commentsA military authority in Romania (ACTTM) will be checking the #masca3D for certification soon. Meanwhile more makers are building their own masks. Gabriel did a nice video that shows how the 3d printing process works. This entire print took about 3h30min to complete:
His results are brilliant too:
200406 - Active Filters
04/06/2020 at 19:00 • 0 commentsAnother idea was to impregnate the cotton pads with anti-microbial chemicals, let them dry, then use them in the mask. When breathing, the the humidity in air would transfer to the chemicals, making them humid and active. I considered the following:
- Methylene Blue
- Rivanol
- Betadine
Sadly, all these are slightly toxic when inhaled, so it’s definitely not an option for a face mask filter. But then Ionut sent me this link in Nature.com.
The study shows that a saline solution can act as antimicrobial agent for a similar scenario – single use masks. The filters can be soaked in a saturated saline solution, left to dry, then inserted in the #masca3d filter container. The exhaled air will reactive the hygroscopic salt crystals and enable them to kill viruses. Other salts can be used as well and may have a better yield (Sodium bicarbonate).
200405 - Filters under the microscope
04/06/2020 at 19:00 • 0 commentsYou all know about FFP2 masks like the one below:
There are also wet wipes that some suggested they could be used for filters (packed in several layers). How do all these compare? Here are some microscope pictures, showing the differences. All of them are taken against a powerful light source, so any openings in fabric would show right away.
For all three materials the same settings were used: same background light intensity and distance from source to probe, same microscope magnification.
The Wet Wipes have some big problems, and I don’t think they are suitable for air filtering: the fibres are rare, light protrudes straight through (so will the particles), dragging it even slightly will cause more openings. Also, unless it is washed and dried, there will also be emollients and chemicals clogging the fibres and eventually getting to your lungs. I wouldn’t use this.
The cotton pads have thin and dense fibres. Most important they are long so it is unlikely they will easily detach and fly to your lungs. Light doesn’t get through, meaning the filter has no openings, and the absorbed light going through the opaque disk indicated a good thickness.
The FFP2 Mask comes with long plastic fibres. These will surely work great for trapping incoming particles since an electrostatic effect will easily develop on plastic (also on cotton). They are not so dense as the cotton pads so small particles can find a way easier then through the cotton pads. Also more light propagates through the opaque material as in the case of the cotton disk. How’s the winner here? Check the photos and decide for yourself. It is obvious the cotton disks are a nice alternative, easy to procure and easy to replace. The mask’s containers allow for two stacked disks, doubling all this and exceeding the FFP2 by far.
But there are many other options here. The containers can be customised for any filter combination, depending only on what it can be sourced on the local market and stock availability. For sensitive applications, instead of the existing containers, you can use HME filters , here’s an example made by Teo, who used two Draeger HME filters. Their datasheet indicates stopping 99.99% of viruses and bacteria. And they fit right away, with no other modifications:
200403 - How comfortable is it after 2hours?
04/04/2020 at 17:47 • 0 commentsI did a few tests to determine how comfortable the mask is when wearing it for a longer time. After 2hours there were no marks on my face, breathing was ok (yet, I could feel the air being limited due to filtration), there was a little condensation inside but the filters were still usable (not even a little moist). The rubber is important for comfort and so is the sponge band used to seal the mask to the face. Video in Romanian:
Lots of makers started building their own. You can go for plain white or add some colour, here are some ideas:
Ready to print your own #masca3d?
200402 - Makers started to build their own #masca3d
04/03/2020 at 08:37 • 0 commentsMakers started to print their own variants of the sealed 3D protection mask.
Here's one made by Ovidiu, the inventor of Chargie: https://chargie.org .Another video made by Cristi, discusses how the mask fits his face, and possible improvements:
A few pics with Cristi's results:
200402 - Testing the sealing
04/03/2020 at 08:30 • 0 commentsHere’s a video (in Romanian) about how 3D printing is done, how well are welded together the layers that make up the mask, a water test, images under the microscope and finally, a test with a thermal imaging camera that shows where the air comes in and where the air goes out to illustrate the face sealing performance.
200401 - first print
04/03/2020 at 08:25 • 0 commentsThe design is ok, I just tested the first print. I like the very compact design and that it is so comfortable when wearing.
Radu Motisan
