1PCB for ESP32-CAM
You need yo solders the headers to the pcb, six cables: 2 for power (VCC and GND) and four for control the stepper motor. I put small capacitor in the power connector of the ESP32-CAM.
2Stepper Motor
I presented the engine in the 3D model, a mark where the screws will be. Then use the drill to make the holes.
3Connectios
Be sure to run the wires through the 3d piece before crimping the connectors.
4ULN2003 and USB pcb breakout
From the usb pcb you have to have two power cables, VCC / GND for the ULN2003, and VCC / GND for the ESP32-CAM.
5How it work and how i made it.
Guille
