1Install HID-Project library
Access the Library Manager on Arduino IDE (Tools tab) and search for "hid-project". Then click on Install.
After install the library the HID-Project examples should be available
2PC Joystick Adapter / Foot pedal keyboard
Procedure:
Assemble the circuit using the schematics provided and upload the firmwmare to the board.
Materials:
- 1 x Arduino Pro Micro
- 1 x DB-15 female connector
- 4 x 120 Ohms resistor
- 4 x 100nF capacitor
Firmware:
PC Joystick - https://raw.githubusercontent.com/Danjovic/ControlFreak/masterf/PC_Joystick/PC_Joystick.ino
Foot Pedal - https://raw.githubusercontent.com/Danjovic/ControlFreak/master/Foot_Pedal/Foot_Pedal.ino
Schematic:
3Simple PC Joystick with DigiSpark
Procedure:
Materials:
- 1 x Digispark
- 2 x 120 Ohms resistor
- 2 x 4,7nF capacitor
Firmware:
https://raw.githubusercontent.com/Danjovic/ControlFreak/master/digi-PC_Joy/digi-PC_Joy.inoSchematic:
4SEGA controllers (Master System, Genesis 3 and 6 button)
Procedure:
Assemble the circuit using the schematics provided and upload the firmware to the board.
Materials:
- 1 x DB-9 male connector
Firmware:
https://raw.githubusercontent.com/Danjovic/ControlFreak/master/Sega_Controller/Sega_Controller.inoSchematic:
5NES and SNES (and clones)
Procedure:
Materials:
- 1 x Digispark
- 1 x SNES controller socket (alternative 1)
- 1 x NES controller socket (alternative 2)
- 1 x make DB-9 male connector (alternative 3)
note: It is possible to use an extension cable instead of controller sockets.
Firmware:
https://raw.githubusercontent.com/Danjovic/ControlFreak/master/NesSnes/NesSnes.inoSchematic:
6Atari 2600 controllers
Procedure:
Materials:
2 x 1nF capacitorFirmware:
https://raw.githubusercontent.com/Danjovic/ControlFreak/master/Atari2600/Atari2600.inoSchematic:
