Run Stremio on Raspberry Pi with a kiosk look
The step by step instructions have been provided. For demo watch the following video
Download the Zip files containing the binaries from the Releases section of the git (https://github.com/shivasiddharth/Stremio-RaspberryPi).
Place the downloaded zip in the /home/${USER}/ directory and unzip the file.
Buster Users:
sudo sh -c "echo 'deb http://ftp.us.debian.org/debian/ buster main contrib non-free' >> /etc/apt/sources.list" sudo sh -c "echo 'deb http://deb.debian.org/debian buster main contrib non-free' >> /etc/apt/sources.list" sudo apt-get update
Bullseye Users:
sudo sh -c "echo 'deb http://ftp.us.debian.org/debian/ bullseye main contrib non-free' >> /etc/apt/sources.list" sudo sh -c "echo 'deb http://deb.debian.org/debian bullseye main contrib non-free' >> /etc/apt/sources.list" sudo apt-get update
Replace x.x.xxx with the version numbers on the file.
64-Bit Users:
cd /home/${USER}/Stremio-x.x.xxx-arm64-64-bit/
32-Bit Users:
cd /home/${USER}/Stremio-x.x.xxx-armhf-32-bit/
View all 5 instructions
Hi just making you aware i had to add the
[trusted=yes] between deb and the source link for this to work as the sources are unsigned. But got it working in the end thanks so much.
Dmitry
Brayden DeVito
Yes, delete it Cancel
You are about to report the project "Install Stremio on Raspberry Pi", please tell us the reason.
