Different messengers are widely spread now. But unfortunately, most of them focus on mobile devices or x86-based desktops. So, Raspberry Pi users are limited in using modern messengers. Recently we’ve posted a step-by-step instruction on How to run Skype on Raspberry Pi . Today we’re telling you how to run another very popular messenger on Raspberry Pi – Telegram.
Telegram is a messaging app with a focus on speed and security. It’s super-fast, simple, secure and free. Moveover it was developed by our compatriot Pavel Durov.
Raspberry Pi test stand configuration
Model |
Raspberry Pi 2 Model B |
Raspberry Pi 3 |
Frequency |
1000 MHz |
1200 MHz |
Memory |
1 GB RAM |
1 GB RAM |
Operating System |
Raspbian Jessie from November 2015 |
Raspbian Jessie from May 2016 |
Software |
Telegram for Linux 32 bit Eltechs ExaGear Desktop for Raspberry Pi 2 |
Telegram for Linux 32 bit Eltechs ExaGear Desktop for Raspberry Pi 3 |
Telegram installation instruction
Install ExaGear Desktop
1. Download ExaGear Desktop archive with installation packages and license key. Open Terminal (command line) and unpack the downloaded archive using the following command:
$ tar -xvzpf exagear-desktop-rpi2.tar.gz |
2. Install ExaGear Desktop:
$ sudo ./install-exagear.sh |
Launch guest x86 system
3. Enter the guest x86 system using the following command:
$ exagear Starting the shell in the guest image /opt/exagear/images/debian-8-wine2g |
Now you are in x86 environment that can be checked by running the ‘arch’ command:
$ arch i686 |
5. It is recommended to update apt-get repositories on the first launch of the guest system:
$ sudo apt-get update |
Install Telegram
6. Download Telegram archive for Linux 32-bit from the official Telegram site https://desktop.telegram.org. You can do it using a browser or typing wget in Terminal:
$ sudo apt-get install wget xz-utils gconf2 $ wget http://updates.tdesktop.com/tlinux32/tsetup32.0.10.19.tar.xz |
7. Unpack Telegram archive:
$ tar -xJvf tsetup*.tar.xz |
Run Telegram
8. Run Telegram:
$ Telegram/Telegram |
Final notes
It is worth to note that with ExaGear Desktop you can run other x86 apps on Raspberry Pi devices. ExaGear also supports other ARM-based devices such as Odroid, Banana Pi, Beagleboard, Cubox, Jetson, Cubieboard etc.
Get my ExaGear Desktop
The original article is Telegram on Raspberry Pi
Dmitry
