1Buy all the parts you need at the same time, and as soon as the filament arrives, start printing​
2When the Steel Rods arrive, measure them, cut them, and shave them for the parts needed
This is the only fabrication required.
3When the Raspberry Pi arrives, install Raspbian on it
4When the rest of the parts arrive, assemble your rover without the wheel systems on it
Assemble the chassis, rocker and bogie arms, and differential.
5Using the RPi, program ID's for the Servo Motors. Complete the Rover Software configurations on your RPi
6Install the servos and wheels, should now have a mechanically complete rover.
7Put together your power and control module, and configure your Network for your RPi and Router.
Ameer
