13D Modeling
My build started in Fusion 360. First modeling everything that needed to fit within the back and arranged them somewhat to fit tightly. I left room for a raspberry pi, which I did not model because I measured the space between the components and found it would fit. Saved a little bit of time there.
There are definitely areas to improve the shell. Like where the top plane meets the raised ridge lines, the cross section is rather small.
Lastly, I designed some strap components for the pack.
All things improve with time, however it'll work for now! So on to step two!
Oh well before that, let me know if you have any questions about the modeling, I'll do my best to answer them! :)
23D Printing
To print bolt holes, offset from the plane of the printer, I created 4 cylinders and aligned them a layer or two below where the hole would start to print. Each cylinder is a solid model, two layers thick. Once sliced, support will not need to be generated, since the slicer will treat it as a bridged surface and then build the hole on top of the surface.
3Assembly of Pack Components!
I started with a two pin Molex connector, which the batteries from Batteryspace.com comes with as an optional add on for their batteries. Snipping all of the usb lines, and connecting power and ground to the molex connector with those solder-in-heatshrink jumpers
The power lines are for the following:
- USB C for Raspberry Pi4
- Micro USB for Touch Screen
- Output for the Neopixel LED's in my tvhead.
Sorry, the photo is not great, I took it after the fact. In the back, you can see the two solder-in-heatshrink jumpers. The molex connector is rather blurry on the right side of the photo. The Black usb in back, is power and the blue usb is touch data going to the pi. The grey cable is the power line for my tvhead, and the black cable is the usb power line for the raspberry pi.After everything was soldered together, I started to place the components in the shell of the pack. The build is simple, connecting a raspberry pi HDMI and usb to the touch screen. That's all that's really needed besides power.
4Sewing the Backpack straps
I then had some help holding the pack up to my back while I figured out how high to put the plastic strap tensioners.
Then I sewed the tensioners in place. Don't worry if you get them in the wrong spot at first, its a bit of trail and error because everyone's body is different. -
5Website Positive Message Data Collection
During the first half of message collection, I asked my Instagram followers for their messages. However, I wanted to establish something longterm. So I created a database on my wix website.
To do this, go into your wix site and click the plus next to collections. Don't forget to give you collection a name.
It should look something like this if completed.
// import the wix libraries for handling HTTP functions and the wix data handling library import {ok, notFound, created, serverError} from 'wix-http-functions'; import wixData from 'wix-data'; //Create a function for external use, this is a request, called readPositiveText, it can be called anything you like export function get_readPositiveText(request) { let options = { "headers": { "Content-Type": "application/json" } }; //This is block of code asks wix to query all of the database and return it in json format, place your database name in query("database_name") return wixData.query("tvheadinput") .find() .then( (results) => { if(results.items.length > 0) { options.body = { "results" : results.items } return ok(options); } }) }
Once that is saved, you can now poll your database using an http get request or for wix, typing out the following address which is linked to the export function. Mine is located at the following link.
https://www.natedamen.com/_functions/readPositiveText
The output should look like this if done correctly.
BOOM! Anyone can now submit a positive message through your wix website and can read it back through get request. Time to filter all of this text so even if someone types in something terrible, it won't be displayed.
6From Website to Python, preprocessing for NLP
# This code Reads in the json from my webpage, then converts it to a pandas dataframe, then adds a new column to the dataframe with just the positive text #import the pandas library import pandas as pd #Using pandas, create a new dataframe from the json response of my website posTextJjsonDataFrame=pd.read_json(r'https://www.natedamen.com/_functions/readPositiveText') #the response needs a bit of cleaning so lets create a new pandas series to hold the cleaned up text newCol= pd.Series([]) #iterate through the main dataframe, adding the results to the place holder series for index in range(len(posTextJjsonDataFrame.results)): newCol[index]= posTextJjsonDataFrame.results[index]['positiveText'] #print(newCol[index]) #finally insert the series containing just the positive text as a new column in original dataframe posTextJjsonDataFrame.insert(1,'Positive_Text', newCol)
Printing out the Dataframe raw from the json state yeilds the following:
But now with cleaned text if we print the new column
print(posTextJjsonDataFrame.Positive_Text)
we will see the following
7The base Twitch Python Chatbot
import socket import cfg import re import time sock = socket.socket() sock.connect((cfg.HOST,cfg.PORT)) sock.send("PASS {}\r\n".format(cfg.PASS).encode("utf-8")) sock.send("NICK {}\r\n".format(cfg.NICK).encode("utf-8")) sock.send("JOIN {}\r\n".format(cfg.CHAN).encode("utf-8")) chat_message = re.compile(r"^:\w+!\w+@\w+.tmi.twitch.tv PRIVMSG #\w+ :") def chat(s,msg): s.send("PRIVMSG {} :{}\r\n".format(cfg.CHAN,msg).encode("utf-8")) def getMSG(r): mgs = chat_message.sub("", r) return mgs def getUSER(r): try: user=re.search(r"\w+",r).group(0) except AttributeError: user ="tvheadbot" print(AttributeError) return user while True: response = sock.recv(1024).decode("utf-8") print(response) if response == "PING :tmi.twitch.tv\r\n": sock.send("PONG :tmi.twitch.tv\r\n".encode("utf-8")) else: mess= getMSG(response) who = getUSER(response) #print(who +": " +mess) if mess.strip() == "!love": chat(sock, "I love you " + who +"!") time.sleep(1/cfg.RATE)
Like all good things, chatbots. Well this one is really just a chat scrubber to recognize specific keywords and do things based off of them.
The first thing is import the libraries we will be using. Sockets to actually connect and send messages over the internet to twitch. A configuration file of my twitchbot auth token, twitchbot name, the twitch channel we are connecting into, and a delay time specific to make twitch not angry with us. The Regular Expressions library for handling the messages to and from twitch. The Time library for handling delays in message sending.
The Next step is create a socket and connect it to twitch. Sending it the Host name and Port in a single package.
Using the re library to section out certain parts of the messages twitch sends us.
Lets create a new function that allows us to chat a little easier. Create two variables for the socket and messages to be passed in and then the socket send function with proper configuration for twitch messages.
The next two functions allow for twitch messages from socket receive to be passed in and searched to parse out the message and the user who typed it.
Lastly we set up a loop to listen to the socket, send a pong back if pinged, to keep our connection alive, and if it's a message read the message and who it is from.
Finally if we receive a message that matches a particular set of characters, then we do something. In this case we send some love to the one who asked for the command. Don't forget to delay our messages out to twitch, otherwise our connection to the server will be terminated.
Next we will actually use this section of code to create commands that will change which messages are displayed on the positivity pack!
8Swapping between the Images with OpenCV python
import socket import cfg import re import time # import Numpy and Open CV for python import numpy as np import cv2 # These commands set the screen to full on whatever display is being used. Don't use if you dont mind it being in a window that can move around cv2.namedWindow("PositiveMessage", cv2.WND_PROP_FULLSCREEN) #cv2.moveWindow("PositiveMessage", screen.x - 1, screen.y - 1) cv2.setWindowProperty("PositiveMessage", cv2.WND_PROP_FULLSCREEN,cv2.WINDOW_FULLSCREEN) #loading some of the images in and resizing them to the dimensions of the screen, which isn't really needed but hey whatevas message1= cv2.imread('photos\img_2.1.1.png') message1= cv2.resize(message1,(1024,600),interpolation = cv2.INTER_AREA) message2= cv2.imread('photos\img_2.1.2.png') message2= cv2.resize(message2,(1024,600),interpolation = cv2.INTER_AREA) message3= cv2.imread('photos\img_2.1.3.png') message3= cv2.resize(message3,(1024,600),interpolation = cv2.INTER_AREA) message4= cv2.imread('photos\img_2.1.4.png') message4= cv2.resize(message4,(1024,600),interpolation = cv2.INTER_AREA) message5= cv2.imread('photos\img_2.1.5.png') message5= cv2.resize(message5,(1024,600),interpolation = cv2.INTER_AREA) message6= cv2.imread('photos\img_2.1.6.png') message6= cv2.resize(message6,(1024,600),interpolation = cv2.INTER_AREA) message7= cv2.imread('photos\img_2.1.7.png') message7= cv2.resize(message7,(1024,600),interpolation = cv2.INTER_AREA) message8= cv2.imread('photos\img_2.1.8.png') message8= cv2.resize(message8,(1024,600),interpolation = cv2.INTER_AREA) message9= cv2.imread('photos\img_2.1.9.png') message9= cv2.resize(message9,(1024,600),interpolation = cv2.INTER_AREA) message10= cv2.imread('photos\img_2.1.10.png') message10= cv2.resize(message10,(1024,600),interpolation = cv2.INTER_AREA) message11= cv2.imread('photos\img_2.1.11.png') message11= cv2.resize(message11,(1024,600),interpolation = cv2.INTER_AREA) message12= cv2.imread('photos\img_2.1.12.png') message12= cv2.resize(message12,(1024,600),interpolation = cv2.INTER_AREA) message13= cv2.imread('photos\img_2.1.13.png') message13= cv2.resize(message13,(1024,600),interpolation = cv2.INTER_AREA) message14= cv2.imread('photos\img_2.1.14.png') message14= cv2.resize(message14,(1024,600),interpolation = cv2.INTER_AREA) message15= cv2.imread('photos\img_2.1.15.png') message15= cv2.resize(message15,(1024,600),interpolation = cv2.INTER_AREA) message16= cv2.imread('photos\img_2.1.16.png') message16= cv2.resize(message16,(1024,600),interpolation = cv2.INTER_AREA) message17= cv2.imread('photos\img_2.1.17.png') message17= cv2.resize(message17,(1024,600),interpolation = cv2.INTER_AREA) message18= cv2.imread('photos\img_2.1.18.png') message18= cv2.resize(message18,(1024,600),interpolation = cv2.INTER_AREA) message19= cv2.imread('photos\img_2.1.19.png') message19= cv2.resize(message19,(1024,600),interpolation = cv2.INTER_AREA) message20= cv2.imread('photos\img_2.1.20.png') message20= cv2.resize(message20,(1024,600),interpolation = cv2.INTER_AREA) message21= cv2.imread('photos\img_2.1.21.png') message21= cv2.resize(message21,(1024,600),interpolation = cv2.INTER_AREA) message22= cv2.imread('photos\img_2.1.22.png') message22= cv2.resize(message22,(1024,600),interpolation = cv2.INTER_AREA) message23= cv2.imread('photos\img_2.1.23.png') message23= cv2.resize(message23,(1024,600),interpolation = cv2.INTER_AREA) messages = [message1,message2,message3,message4,message5,message6,message7,message8,message9,message10,message11,message12,message13,message14,message15,message16,message17,message18,message19,message20,message21,message22,message23] #Creating a variable that we can swap messages to displayimage = message1 #Creating our socket and passing on info for twitch sock = socket.socket() sock.connect((cfg.HOST,cfg.PORT)) sock.send("PASS {}\r\n".format(cfg.PASS).encode("utf-8")) sock.send("NICK {}\r\n".format(cfg.NICK).encode("utf-8")) sock.send("JOIN {}\r\n".format(cfg.CHAN).encode("utf-8")) #handling of some of the string characters in the twitch message chat_message = re.compile(r"^:\w+!\w+@\w+.tmi.twitch.tv PRIVMSG #\w+ :") #Lets create a new function that allows us to chat a little easier. Create two variables for the socket and messages to be passed in and then the socket send function with proper configuration for twitch messages. def chat(s,msg): s.send("PRIVMSG {} :{}\r\n".format(cfg.CHAN,msg).encode("utf-8")) #The next two functions allow for twitch messages from socket receive to be passed in and searched to parse out the message and the user who typed it. def getMSG(r): mgs = chat_message.sub("", r) return mgs def getUSER(r): try: user=re.search(r"\w+",r).group(0) except AttributeError: user ="tvheadbot" print(AttributeError) return user while True: #listen to twitch messages incoming response = sock.recv(1024).decode("utf-8") print(response) #pong the pings to stay connected if response == "PING :tmi.twitch.tv\r\n": sock.send("PONG :tmi.twitch.tv\r\n".encode("utf-8")) else: #otherwise get the user and message mess= getMSG(response) who = getUSER(response) # If the message matches one of the cammands do something if "love"in mess.strip(): #Sets the image to be displayed to our image 1, do the same for every message displayimage = message1 elif "values" in mess.strip(): displayimage = message2 elif "dont" in mess.strip(): displayimage = message3 elif "perect" in mess.strip(): displayimage = message4 elif "future" in mess.strip(): displayimage = message5 elif "friends" in mess.strip(): displayimage = message6 elif "community" in mess.strip(): displayimage = message7 elif "neighbor" in mess.strip(): displayimage = message8 elif "another" in mess.strip(): displayimage = message9 elif "together" in mess.strip(): displayimage = message10 elif "gift" in mess.strip(): displayimage = message11 elif "nice" in mess.strip(): displayimage = message12 elif "look"in mess.strip(): displayimage = message13 elif "got" in mess.strip(): displayimage = message14 elif "beautiful" in mess.strip(): displayimage = message15 elif "breathe" in mess.strip(): displayimage = message16 elif "united" in mess.strip(): displayimage = message17 elif "heart" in mess.strip(): displayimage = message18 elif "weird" in mess.strip(): displayimage = message19 elif "okay" in mess.strip(): displayimage = message20 elif "aware" in mess.strip(): displayimage = message21 elif "be" in mess.strip(): displayimage = message22 elif "play" in mess.strip(): displayimage = message23 # add in a countdown to change to a random display after a period of time of no chat interaction #add a delay so twitch doesn't get mad at our bot time.sleep(1/cfg.RATE) #displays the image output to the fullscreened window cv2.imshow("PositiveMessage",displayimage) #Setting this wait key to 1, converts the output to video, only showing the image every 0.1 seconds. allowing for the display image output to be set to various images cv2.waitKey(1) #Closes all the windows cv2.destroyAllWindows()
9Code Rewrite to include the Atltvhead Gesture Recogntion Bracer Project
New Code Improvements are:
- Socket is nonblocking
- Machine learning Gesture recogntion added
# PositivityPack.py # Description: Recieved Data from ESP32 Micro via the AGRB-Training-Data-Capture.ino file, make gesture prediction and tell it to twitch # Display an image that changes according to what is said in twitch chat or after 30 seconds # Written by: Nate Damen # Created on July 13th 2020 # Updated on July 15th 2020 import socket import cfg import re import time import random import numpy as np import pandas as pd import datetime import os, os.path import tensorflow as tf import serial import cv2 import traceback #PORT = "/dev/ttyUSB0" #PORT = "/dev/ttyUSB1" PORT = "COM8" serialport = None serialport = serial.Serial(PORT, 115200, timeout=0.05) #load Model model = tf.keras.models.load_model('../Atltvhead-Gesture-Recognition-Bracer/Model/cnn_model.h5') # These commands set the screen to full on whatever display is being used. Don't use if you dont mind it being in a window that can move around cv2.namedWindow("PositiveMessage", cv2.WND_PROP_FULLSCREEN) #cv2.moveWindow("PositiveMessage", screen.x - 1, screen.y - 1) cv2.setWindowProperty("PositiveMessage", cv2.WND_PROP_FULLSCREEN,cv2.WINDOW_FULLSCREEN) #loading some of the images in and resizing them to the dimensions of the screen, which isn't really needed but hey whatevas message1= cv2.imread('photos/img_2.1.1.png') message1= cv2.resize(message1,(1024,600),interpolation = cv2.INTER_AREA) message2= cv2.imread('photos/img_2.1.2.png') message2= cv2.resize(message2,(1024,600),interpolation = cv2.INTER_AREA) message3= cv2.imread('photos/img_2.1.3.png') message3= cv2.resize(message3,(1024,600),interpolation = cv2.INTER_AREA) message4= cv2.imread('photos/img_2.1.4.png') message4= cv2.resize(message4,(1024,600),interpolation = cv2.INTER_AREA) message5= cv2.imread('photos/img_2.1.5.png') message5= cv2.resize(message5,(1024,600),interpolation = cv2.INTER_AREA) message6= cv2.imread('photos/img_2.1.6.png') message6= cv2.resize(message6,(1024,600),interpolation = cv2.INTER_AREA) message7= cv2.imread('photos/img_2.1.7.png') message7= cv2.resize(message7,(1024,600),interpolation = cv2.INTER_AREA) message8= cv2.imread('photos/img_2.1.8.png') message8= cv2.resize(message8,(1024,600),interpolation = cv2.INTER_AREA) message9= cv2.imread('photos/img_2.1.9.png') message9= cv2.resize(message9,(1024,600),interpolation = cv2.INTER_AREA) message10= cv2.imread('photos/img_2.1.10.png') message10= cv2.resize(message10,(1024,600),interpolation = cv2.INTER_AREA) message11= cv2.imread('photos/img_2.1.11.png') message11= cv2.resize(message11,(1024,600),interpolation = cv2.INTER_AREA) message12= cv2.imread('photos/img_2.1.12.png') message12= cv2.resize(message12,(1024,600),interpolation = cv2.INTER_AREA) message13= cv2.imread('photos/img_2.1.13.png') message13= cv2.resize(message13,(1024,600),interpolation = cv2.INTER_AREA) message14= cv2.imread('photos/img_2.1.14.png') message14= cv2.resize(message14,(1024,600),interpolation = cv2.INTER_AREA) message15= cv2.imread('photos/img_2.1.15.png') message15= cv2.resize(message15,(1024,600),interpolation = cv2.INTER_AREA) message16= cv2.imread('photos/img_2.1.16.png') message16= cv2.resize(message16,(1024,600),interpolation = cv2.INTER_AREA) message17= cv2.imread('photos/img_2.1.17.png') message17= cv2.resize(message17,(1024,600),interpolation = cv2.INTER_AREA) message18= cv2.imread('photos/img_2.1.18.png') message18= cv2.resize(message18,(1024,600),interpolation = cv2.INTER_AREA) message19= cv2.imread('photos/img_2.1.19.png') message19= cv2.resize(message19,(1024,600),interpolation = cv2.INTER_AREA) message20= cv2.imread('photos/img_2.1.20.png') message20= cv2.resize(message20,(1024,600),interpolation = cv2.INTER_AREA) message21= cv2.imread('photos/img_2.1.21.png') message21= cv2.resize(message21,(1024,600),interpolation = cv2.INTER_AREA) message22= cv2.imread('photos/img_2.1.22.png') message22= cv2.resize(message22,(1024,600),interpolation = cv2.INTER_AREA) message23= cv2.imread('photos/img_2.1.23.png') message23= cv2.resize(message23,(1024,600),interpolation = cv2.INTER_AREA) messages = [message1,message2,message3,message4,message5,message6,message7,message8,message9,message10,message11,message12,message13,message14,message15,message16,message17,message18,message19,message20,message21,message22,message23] #Creating a variable that we can swap messages to displayimage = message1 # header for the incomming data header = ["deltaTime","Acc_X","Acc_Y","Acc_Z","Gyro_X","Gyro_Y","Gyro_Z"] #define Gestures, current data, temp data holder gest_id = {0:'wave_mode', 1:'fist_pump_mode', 2:'random_motion_mode', 3:'speed_mode'} data = [] dataholder=[] dataCollecting = False gesture='' old_gesture='' t=0 ot=0 #Creating our socket and passing on info for twitch sock = socket.socket() sock.connect((cfg.HOST,cfg.PORT)) sock.send("PASS {}\r\n".format(cfg.PASS).encode("utf-8")) sock.send("NICK {}\r\n".format(cfg.NICK).encode("utf-8")) sock.send("JOIN {}\r\n".format(cfg.CHAN).encode("utf-8")) sock.setblocking(0) #handling of some of the string characters in the twitch message chat_message = re.compile(r"^:\w+!\w+@\w+.tmi.twitch.tv PRIVMSG #\w+ :") #Lets create a new function that allows us to chat a little easier. Create two variables for the socket and messages to be passed in and then the socket send function with proper configuration for twitch messages. def chat(s,msg): s.send("PRIVMSG {} :{}\r\n".format(cfg.CHAN,msg).encode("utf-8")) #The next two functions allow for twitch messages from socket receive to be passed in and searched to parse out the message and the user who typed it. def getMSG(r): mgs = chat_message.sub("", r) return mgs def getUSER(r): try: user=re.search(r"\w+",r).group(0) except AttributeError: user ="tvheadbot" print(AttributeError) return user #Get Data from imu. Waits for incomming data and data stop def get_imu_data(): global serialport if not serialport: # open serial port serialport = serial.Serial(PORT, 115200, timeout=0.05) # check which port was really used print("Opened", serialport.name) # Flush input time.sleep(3) serialport.readline() # Poll the serial port line = str(serialport.readline(),'utf-8') if not line: return None vals = line.replace("Uni:", "").strip().split(',') if len(vals) != 7: return None try: vals = [float(i) for i in vals] except ValueError: return ValueError return vals # Create Reshape function for each row of the dataset def reshape_function(data): reshaped_data = tf.reshape(data, [-1, 3, 1]) return reshaped_data #Create a way to see the length of the data incomming, needs to be 760 points. Used for testing incomming data def dataFrameLenTest(data): df=pd.DataFrame(data,columns=header) x=len(df[['Acc_X','Acc_Y','Acc_Z']].to_numpy()) print(x) return x #Create a pipeline to process incomming data for the model to read and handle def data_pipeline(data_a): df = pd.DataFrame(data_a, columns = header) temp=df[['Acc_X','Acc_Y','Acc_Z']].to_numpy() tensor_set = tf.data.Dataset.from_tensor_slices( (np.array([temp.tolist()],dtype=np.float64))) tensor_set_cnn = tensor_set.map(reshape_function) tensor_set_cnn = tensor_set_cnn.batch(192) return tensor_set_cnn def gesture_Handler(sock,data,dataholder,dataCollecting,gesture,old_gesture): dataholder = get_imu_data() if dataholder != None: dataCollecting=True data.append(dataholder) if dataholder == None and dataCollecting == True: if len(data) == 760: prediction = np.argmax(model.predict(data_pipeline(data)), axis=1) gesture=gest_id[prediction[0]] data = [] dataCollecting = False return data,dataholder,dataCollecting,gesture,old_gesture def message_changer(displayimage, messa): #otherwise get the user and message mess= getMSG(messa) # If the message matches one of the cammands do something if "love" in mess.strip() or "love" == mess.strip(): #Sets the image to be displayed to our image 1, do the same for every message displayimage = message1 elif "values" in mess.strip(): displayimage = message2 elif "dont" in mess.strip(): displayimage = message3 elif "perect" in mess.strip(): displayimage = message4 elif "future" in mess.strip(): displayimage = message5 elif "friends" in mess.strip(): displayimage = message6 elif "community" in mess.strip(): displayimage = message7 elif "neighbor" in mess.strip(): displayimage = message8 elif "another" in mess.strip(): displayimage = message9 elif "together" in mess.strip(): displayimage = message10 elif "gift" in mess.strip(): displayimage = message11 elif "nice" in mess.strip(): displayimage = message12 elif "look"in mess.strip(): displayimage = message13 elif "got" in mess.strip(): displayimage = message14 elif "beautiful" in mess.strip(): displayimage = message15 elif "breathe" in mess.strip(): displayimage = message16 elif "united" in mess.strip(): displayimage = message17 elif "heart" in mess.strip(): displayimage = message18 elif "weird" in mess.strip(): displayimage = message19 elif "okay" in mess.strip(): displayimage = message20 elif "aware" in mess.strip(): displayimage = message21 elif "be" in mess.strip(): displayimage = message22 elif "play" in mess.strip(): displayimage = message23 return displayimage if __name__ == "__main__": #flush the serial port serialport.flush() while True: t=time.time() try: #listen to twitch messages incoming response = sock.recv(1024).decode("utf-8") except: data,dataholder,dataCollecting,gesture,old_gesture = gesture_Handler(sock,data,dataholder,dataCollecting,gesture,old_gesture) if gesture != old_gesture: chat(sock,'!' + gesture) #print(gesture) old_gesture=gesture if t-ot > 30: displayimage = random.choice(messages) ot=t cv2.imshow("PositiveMessage",displayimage) cv2.waitKey(1) continue else: if len(response)==0: print('orderly shutdown on the server end') sock = socket.socket() sock.connect((cfg.HOST,cfg.PORT)) sock.send("PASS {}\r\n".format(cfg.PASS).encode("utf-8")) sock.send("NICK {}\r\n".format(cfg.NICK).encode("utf-8")) sock.send("JOIN {}\r\n".format(cfg.CHAN).encode("utf-8")) sock.setblocking(0) else: #print(response) if response == "PING :tmi.twitch.tv\r\n": sock.send("PONG :tmi.twitch.tv\r\n".encode("utf-8")) else: displayimage = message_changer(displayimage,response) cv2.imshow("PositiveMessage",displayimage) cv2.waitKey(1) #Closes all the windows cv2.destroyAllWindows()
