reset mod by @danjovic
08/18/2020 at 07:35 • 0 commentsI've added a modification by @danjovic to the download section. It adds a reset button to the updated schematics. I still haven't come around to actually test my own board, but the first version was already verified by someone else on twitter.
https://cdn.hackaday.io/files/1714467335145664/Danjovic_Reset.zip
https://www.diymodules.org/eagle-show-library?type=usr&id=2105&part=switch-tact.lbr
Boards are in and a small surprise
05/24/2020 at 20:16 • 0 commentsThanks to OSHPark the boards got here quickly, but I'm still waiting on some parts like the regulator, to populate the PCBs. I noticed that one of the resistors seems unnecessary, I've copied it in from the 5V design and forgot to remove that. Maybe I'll put a pull-up resistor on the reset pin in its place - although I do believe there's an internal pull-up resistor anyways, albeit weak.
Someone managed to order and build this project before I even had the chance to solder something together! Turns out there was a minor mistake in the design where two ground plane fills were separated. The V-USB firmware is reported to enumerate - yay :)
@davedarko cool board pic.twitter.com/cHx3ow6cYf
— Dan Watson (@sync_channel) May 23, 2020 -
Tom Fleet works fast
05/06/2020 at 19:02 • 0 commentsand has a very comforting writing style :3
