The goal of this board is to have a complete computer-system on one PCB. It has no bus for expansions but has enough I/O to play with. The first serial port uses RTS/CTS handshaking, the second serial port doesn't. The console is on the first serial port. All components, except the CPU are trough-hole components, so easy to build. For the CPU a PLCC trough hole IC-socket is used.
A DS3234 RTC module from Dead-on is necessary for full functionality of the monitor. This module is shown in the middle of the picture below. On the right the micro SD-card module with levelconverter 5V to 3.3V is shown. On the left the serial TTL (5V) to RS232 module.
The Dead-on RTC DS3234 module is very expensive, so I designed my own module with a more commonly available battery. See picture below.
On the next picture an example how the enclosure could be with the mounted LCD
Scrumpel 7d is certified opensource hardware by the Open Source Hardware Association.
Nick Brok
Just4Fun
Igor
Dean Netherton
